Convert uint16_t to float
10 posts / 0 new
Hi everyone,
I'm having problems converting my uint16_t variable to int. What I'm trying to do is, to read the ADC value, which is saved in a uint16_t variable, and convert it to float to read 4.66V instead of 954 (954 of 1023). Here is my code.
void adc_init(){
ADMUX |= (1 << REFS0); //VRef = AVCC
ADCSRA = (1<<ADEN) | (1<<ADPS0) | (1<<ADPS1) | (1<<ADPS2); //ADC Enable. Prescaler = 128 (125kHz)
int main(void){
DDRD |= (1 << 2); //PD2, OUTPUT
adc_init();
while(1){
ADCSRA |= (1<<ADSC); //Start the conversion
while (!(ADCSRA & (1<<ADIF))){
PORTD &= ~(1 << 2);
uint16_t adc_value = ADC;
//printf("%" PRIu16 " ", adc_value);
float total;
total = (adc_value * 5) / 1023.0;
printf("%.2f" " ", total);
So what is the problem?
What were you expecting?
What do you get?
On the output, I'm getting '?' that symbol. And what I'm trying to see on the output is 4.66 for example, that is the volts of 954 out of 1023 ((954*5)/1023). In Arduino they use something like map().
Life is always better if a human can read it:
void adc_init() {
    ADCSRA = (1 << ADEN) | (1 << ADPS0) | (1 << ADPS1) | (1 << ADPS2); //ADC Enable. Prescaler = 128 (125kHz)
int main(void) {
    adc_init();
    while (1) {
        ADCSRA |= (1 << ADSC); //Start the conversion
        while (!(ADCSRA & (1 << ADIF))) {
            PORTD &= ~(1 << 2);
        float total;
You never clear the ADIF flag.
It is much safer to watch the ADSC bit.  Hardware clears ADSC when the conversion completes.
Your code looks ok.   954 * 5 = 4770 which is a legal integer.   4770 / 1023.0 will cast to 4.6628.   And print as 4.67 4.66
I would say (adc_value * 5.0) / 1023; which is a little safer.
We will not argue about div 1023 or div 1024
Arduino map() function:
long map(long x, long in_min, long in_max, long out_min, long out_max) {
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Use as needed.
Thank you for your help, but I want to convert it to float, not to long. I want to have 2 decimals.
There are several printf libs available for the AVR, the one that supports floating point is quite large, so is not the default, did you choose to link your program with the correct lib to get floating point output?
I'll leave it to gcc users to point you to the correct version to link with.
I didn't know there were more than one library to print a floating point variable. Maybe that's the problem.
There's another thing I would like to ask. I have to do change the brightness of a LED but without using PWM, just using a exponential delay on a blinking led. So that, if I would like 50% brightness, I have to put the same delay when the led is on and when the led is off. All I know is theory, but I don't really know how to implement it because _delay_ms() only accepts const int.
You need libprintf_flt.a and -Wl,-u,vfprintf to use float. If using AS7 this is easy, there's a tick box for the latter and "Libraries" for the former.
Start a new thread for a new question.
If this question is resolved, see Tip #5 (in my signature, below; may not be visible on mobile)
