sensor error help me
5 posts / 0 new
working right zero cross , But its setting doesn't work properly  OCR1A = map(deger, 22, 1023, 100, 0);    I installed here doesn't work properly the pin output  and not responding  what to do now :(üzgün
Code;
#include <avr/interrupt.h>
#include <math.h>
#define DETECT 2      //zero cross detect, interrupt 0, is physical pin 7
#define GATE 1        //triac gate is physical pin 2 pourrait etre 0 (pin5)
#define PULSE 2       //trigger pulse width 4 if 512 (counts)
#define sensorPin 4
void setup() {
  // set up pins
  pinMode(DETECT, INPUT);      //zero cross giriş
  digitalWrite(DETECT, HIGH);  //enable pull-up resistor
  pinMode(GATE, OUTPUT);       //triac çıkış sinyali
   pinMode(sensorPin, INPUT);
  TCCR1 = 0;
  OCR1A = 100;
  TIMSK = _BV(OCIE1A) | _BV(TOIE1);
  sei();
  attachInterrupt(0, zeroCrossingInterrupt, FALLING);
//Interrupt Service Routines
void zeroCrossingInterrupt() {
  TCNT1 = 0;
  TCCR1 = B00001000;
ISR(TIMER1_COMPA_vect) {
    digitalWrite(GATE, HIGH);
  TCNT1 = 255 - PULSE;
ISR(TIMER1_OVF_vect) {
  digitalWrite(GATE, LOW);
  TCCR1 = 0;
void loop() {
  int deger = analogRead(sensorPin);
You've not given us much to work from.
My guess is: TCNT1 = 255 - PULSE; what do you want this to do?
When I've done triac phase control, I use the timer input capture for the zero crossing and the compare feature to time the triac firing. I don't use overflow.
This is arduino code...
was there not a timer claimed by the arduino platform to generate internal ticks?
yes i bought it from the library, the code I wrote is not working anttny but is works arduino ,I want to visualize my finishing project and want to get a study and  I made fan design with mechanical engineer ansys but I want a module that changes with temperature but it doesn't
I don't know how to change there , I control speed with this OC1A  but I want speed control that changes with temperature but it doesn't work
