ATtiny1616 SPI Driver from Atmel Start
8 posts / 0 new
Maybe someone out there can help me figure out Atmel Start.  I'm trying to instantiate the SPI_0_Init driver using the SPI buffers and interrupts.  At one point Atmel was generating the code for SPI_0_write_block(), SPI_0_read_block(), ... etc.  But now Atmel Start will only generate SPI_init() function.  What am I doing wrong?
James.
I suggest to take a look at this thread:
I just did what you said - went to the start site. elected to create a project, picked 1616, added "SPI". I see:
Surely those are the functions you are talking about?
How does your experience differ from mine?
PS the config:
Nothing is changed from default - I simply selected "Driver: SPI" and it delivered all the above as you see it.
Thanks Moe123, that is useful information for sure.  I'll use that once I get past this step.
But right now, Atmel Start will not even generate the SPI driver, the only function it generates is SPI_0_Init().  At one point it was generating the read_block, write_block, etc functions, but it isn't doing that anymore.  I think I have all the settings the same and I've played with them.  I even tried completely deleting the SPI driver and adding it to the project again.  But I can't get all those functions to be generated by Atmel Start.
James.
PS I wonder why anyone would ever elect to do SPI with interrupts (the time in/out of an ISR is likely more than sitting in a block on transfer completion!)? But ours is not to reason why!
Thank you very much for looking at this.
I just duplicated what you did and yes, I do now see those functions in the .h file.  Maybe they were always there, I was using the Doxygen output to look for them and there they were not being generated for some reason.  Even now, the write_block and read_block functions are missing from the doxygen output.  And yes, I regenerate it after each update.
Anyways I seem to have what I need now.
James.
Just to be fair....I do NOT like START.  I learned from the good folks here I can create what I need simply by reading the datasheets and some experimentation.
with regards to START and the TINY series there is a thread from me a while ago with LARRYVC regarding issues with START and the Tiny's.  Don't know where it is.
Lastly.  I too have found the Doxygen output to be somewhat lacking as well.  Is what it is maybe?
I also tried what you asked for and I also obtained the same results as Cliff so based on that and your ability to also replicate the results I am guessing pilot error?
JIm
See Tip #5 in my signature (below, may not work on mobile.
