Trouble Flashing ATtiny3217 Xplained Pro board with MDB
7 posts / 0 new
Hi!
As the title says, I'm trying to flash a devboard (ATtiny3217 Xplained Pro) from MDB.
I can correctly program it from MPLAB X IDE, I can correctly generate the hex file via make or form MPLAB X itself, but I'm having a lot of trouble trying to flash the board from MDB.
What I've got so far:
- I can open MDB from the MPLAB X files
- I can set the device correctly with "device ATTINY3217"
- I can run "hwtool" with the debugger connected and I get:
>hwtool
index Description
0 EDBG CMSIS-DAP(ATML2835031800001955)
- Next I should set the programming tool, I've tried "hwtool EDBG" but the program always returns "null"
- I've tried everything I can remember (hwtool "PICkit3", "ICD3", "RealICE", "SIM", "PM3", -p, -p 0) but nothing works
Then I do "program <path to hex>" and the program says "Programming failed".
Does anyone know how I should go about this? I should say again that I can correctly program the board from within MPLAB X.
Cheers!
Have you tried "atmelice" ?
help deviceandtool ?
MDB Reference: help - Developer Help
I did and unfortunately, the script still answers "null" and fails to program the device.
That command didn't help. I've tried to run "hwtool supported" and the output is the following:
>hwtool supported
List of supported tooltype:
licensedprogrammer (for Licensed Debugger)
I've also tried "hwtool licensedprogrammer" and it still answers "null".
At this point I'm thinking it would be quicker and cheaper to just spin a new version of the board with an Atmega microcontroller...
Try:
device ATtiny3217
set communication.interface UPDI
hwtool edbg
mraardvark wrote:
Try:
device ATtiny3217
hwtool edbg
Awesome, that worked! Thanks!
Is this documented somewhere?
