Whats wrong with this code, ATTINY 1614 periodic interrupt
5 posts / 0 new
I am trying to get the periodic interrupt working to toggle an IO pin on TINY 1614 Timer B.
The timer is not getting a clock, as when I read the TCB1_CNT register it is always at zero.
Can someone please suggest the problem, im going in circles in the data sheet!
Code:
Fuses as follows:
Any takers on this?
Cheers :)
You have not enabled interrupts.
And since the interrupt flag is not automatically released, you need to clear it yourself.
#include <avr/interrupt.h>
#define PIN_TOGGLE  PORTB_OUT ^= (1<<0)
    PORTB_DIR = 0b00000001;
    TCB1.INTCTRL = TCB_CAPT_bm; //////////////// add
    TCB1_CCMP = 0xFFFE;
    TCB1_CTRLA = 1;
    SREG = 0b10000000;
    while (1);
ISR(TCB1_INT_vect)
    PIN_TOGGLE;
    TCB1.INTFLAGS = TCB_CAPT_bm; //////////////// add
It doesn't matter, but I would write:
#define PIN_TOGGLE  PORTB.OUTTGL = PIN0_bm
int main(void){
    PORTB.DIRSET = PIN0_bm;
    TCB1.CCMP = 0xFFFE;
    TCB1.CTRLA = TCB_ENABLE_bm;
    sei();
    while (1);
ISR(TCB1_INT_vect){
    PIN_TOGGLE;
Thanks for your reply.
Noted regarding your version of code, I will learn to use this way. Is the best way to set multiple bits still to use | between definitions?
Say I wanted to set bits 6 (ASYNC) and bit 1 (CNTMODE[2:0]) in TCB1.CTRLB, would you suggest using TCB1.CTRLB=TCB_ASYNC_bm | #define TCB_CNTMODE1_bm; ?
if then I wanted to clear the ASYNC bit what is your suggestion?
I would write like this.
    // setting 0b01000010
    TCB1.CTRLB = TCB_ASYNC_bm | TCB_CNTMODE_CAPT_gc;
    // ASYN off
    TCB1.CTRLB &= ~TCB_ASYNC_bm;
perhaps you know this already but if &=~ is a new construct to you then you may want to read the "Bit Manipulation 101" article found in the Tutorial Forum here.
