ATmega8A with EM-18 RFID Module Data Transmission Error
26 posts / 0 new
Hello everyone,
I am working on RFID based system with ATmega8A. I met a problem. I cant receive read data. My circuit schema is below (Figure 1). And I connected TX to RX, SEL to +5V, GND to GND, VCC to +5V for EM-18 module. Also, EM-18 pinout is below (Figure 2). EM-18 working with UART communication. I'm sure I assigned the appropriate registers correctly (UCSRs, UBBR and etc.).
because i can get data with PL-2303 USB-TTL converter. Can you help me?
Figure 1. Circuit Schema
Figure 2. EM-18 RFID Reader Module Pinout
FYI -
This really does not belong in the XMega forum. Hopefully, a moderator will move it.
admcmly wrote:
ATmega8A
So why post it in the Xmega forum?
You mean data from the microcontroller to the PC, or data from the  EM-18 to the PC ?
See this thread for tips on debugging serial comms:
And See Tip #2 (in my signature, below; may not be visible on mobile) for the commonest problem in serial comms ...
Sorry, i am new at this forum.
EM-18 to microcontroller. Thank you i will look this.
Here's a tutorial on how to post replies:
https://www.avrfreaks.net/forum/man-forum-how-reply-post-forum
Thank you
First thing......there is NO RxD line on the EM-18 as you have in your schematic
Second thing..... There are NO CTS or RTS lines on the EM-18 as you have in your schematic
Third thing......you MUST connect the SEL pin to +5v for 232 communications.  Leaving it floating may set it for Wiegand output.
Fourth thing....Are you SURE that the EM-18 outputs TTL level signals?  (I checked, and I know the answer to this)
East Side Jim
  I know, there is no RX pin, only i was connect. And EM-18 have TX pin, i was connect this pin to rx of microcontroller. I was connect SEL to + 5V. And, I new at microcontrollers, When I saw the TX pin, I thought I'd read it from the RX. Is it wrong?
And figure 2 in the OP actually shows that!
Also:
Q1 etc in the schematic is drawn "upside down" - the positive supply should always be at the top; GND at the bottom.
No supply connections (or bypass caps) to the AVR
What frequency is the crystal ?
A schematic should accurately depict the connections you have!
Perhaps you should start with some basics ?
See Tip #6.
First rule of electronics.....Schematics M U S T  represent the ACTUAL Circuit.  When Microchip took over they deactivated our crystal balls and stopped shipments of Flooby Dust, so none of us has our magical abilities anymore.
Correct
In the result, currenct from collector to emitter I think it does not matter. Microcontrollers are not have supply connections in ISIS Proteus. Crystal frequency is 8MHz
Thank you but i must do this circuit. Isn't it hard to actually do?
THen at least draw it properly.
I'm done.  Over and out.......
JIm
Proteus has virtual test instruments. i’d suggest you use them to view the virtual electrons.
You are right.
Okey. Anymore, i will do that. Can you give me ideas why I can't read the data.
Why "must" you - what is forcing you?
Clearly, if you "must" do this, then you need to understand the basics in order to be able to do it!
Is this a school / homework assignment ?
What, exactly, have you tried ?
Have you carefully studied the  EM-18 datasheet to learn how it works, and how to use it correctly ?
Have you searched for Application Notes, examples, tutorials, etc on how it works, and how to use it correctly ?
As already suggested, have you used the simulation, debugging, and virtual instrument features of Proteus to investigate what is happening?
That's not the point.
The point is that a schematic should clearly communicate the design to other human readers.
Communication is far more effective if you stick to the normal, well-established conventions.
That doesn't sound right!
Labcenter wrote:
Proteus Design Suite is found in High Schools, Colleges and Universities across the world, teaching electronics, embedded design and PCB layout to tens of thousands of students each year.
You cannot possibly so a PCB layout if things like supply connections and bypass capacitors are not there!
And, again:
Remember: the schematic that you post is the only information that we have about your circuit!
So put that on the schematic - just as you've put the resistance values on the resistors and the capacitance values on the capacitors.
Firstly, thank you for your reply.
This project for school project. Therefore, i must do this.
Yes, i tried multiple ways. I bought module again, maybe it's broken. And I was read EM-18 datasheet, I tried the circuit there. In the internet have not much documentation for EM-18 applications. I used simulation for this circuit at Proteus. Working there right.
Thank you.
So you should be asking your teachers for help!
It will be far easier for them to help you as they can sit with you, and see exactly what you have, and see exactly what you're doing, and see exactly what's happening - we can do none of that!
You are correct for clearly communication.
I can't see VCC and GND pins at Proteus simulation screen.
You are right, i forgot to add crystal frequency.
you're right but i wanted to ask here first. Thank you for all.
And, presumably, less of a language barrier.
Proteus is nothing to do with Microchip - you need to go to Labcenter for help with Proteus:
Or, again, speak to your teachers - presumably it's the school that has provided you with Proteus ?
I will do this, thank you again.
