Unwanted compare flag B in compare A interrupt.
6 posts / 0 new
I'm using Atmega32 8MHZ ( AVR studio simulator) and I  added OCR1A compare match interrupt for timer 1 and also comapre match for timer0
.cseg
.org 0x00
rjmp START
.org 0x0E
rjmp T1_CMA_ISR
.org 0x14
rjmp T0_CM_ISR
.org 0x100
START:
    ldi r16, high(65536-200)
	out OCR1AH, r16
	ldi r16, low(65536-200)
	out OCR1AL, r16
	ldi r16, 0x00
	out TCCR1A, r16
	ldi r16, (1<<WGM12) | (1<<CS10)
	out TCCR1B, r16
	ldi r16, (1<<OCIE1A) | (1<<OCIE0)
	out TIMSK, r16
	sei
MLOOP:
	rjmp MLOOP
T1_CMA_ISR:
	in r17, TCNT1L
	in r18, TCNT1H
	reti
T0_CM_ISR:
	in r17, TCNT0
	reti
So when Compare A match interrupt is starting I see that OCF1B flag is set instead of OCF1A flag in TIFR register.
Can somebody explain why?
You haven't cleared the ocf1b flag.
The ocf1a flag gets cleared by hardware when the isr is entered.
I see the same but isn't this what you might expect? You wouldn't expect to see 0CF1A set in the COMPARE_A handler because:
So OCF1A is already cleared as part of the mechanism that brought it into the T1_CMA_ISR: handler.
So the only real mystery here is why OCF1B is set too. Well the B comparison stuff will sill happen as the timer runs so when TCNT1 matches OCR1B and the timer is running the OCF1B flag will be set. as OCR1B defaults to 0x0000 I guess this happens early. Presumably if you set OCR1B to a value that is HIGHER than OCR1A (0xFFFF say?) then it won't be set when you enter the ISR?
EDIT: yup, just tried that:
START:
	ser r16
	out OCR1BH, r16
	out OCR1BL, r16
	out OCR1AH, r16
	out OCR1AL, r16
(added the 3 lines after START:) and OCF1B is NOT set when it enters the OCR1A interrupt.
Presumably the surprise to you here is the fact that the B channel flagging mechanism actually operates even though you haven't "switched it on"? But that's the point - it does it anyway - the only "switching on" is to tell the CPU whether to take special action when the flag does get set (by setting the OCIE1B bit)
So I set
OCR1BH
and
OCR1BL
registers with same values as OCR1AH and OCR1AH ,
Added compare B interrupt ISR,
BUT! I did not set OCIE1B flag in TIMSK register, So.. CPU will set compare B bit flag , BUT because I did not set OCIE1B flag nothing will happen, CPU just setting bit, nothing else..
right?
The timer sets the compare flag, not the cpu! Otherwise, yes. If you don’t enable the interrupt, the cpu will not respond.
Yes yes Timer not CPU, sorry. Thanks
