Help to Identify SMD SOT23-5 Marking Code
14 posts / 0 new
Hello Guys
I am trying to identify an SOT23-5 Package IC. Its installed on a Voltage Monitoring Interface PCB. It has following 3 marking codes in 3 different PCBs but with same working in every manner. Please help Identifying
Marking Codes: (Pictures Attached)
AAMF
AA5P
AA81
I this the considerable part is first 2 Letter ie "AA" otherwise the complete marking code would have been same in all PCBs. The remaining 2 letters are some sort of date or lot code.
Please help guys
eHassan
Are you reverse engineering ?
Very often device datasheets will include a Device Marking Table. There is no standard, it seems each manufacturer chooses something at random. sad
{Mods. Please delete this duplicate post https://www.avrfreaks.net/comment/2828111#comment-2828111}
Thanks for the reply. I have done extensive research so far for this component keeping following thing in view
1. PCB has "Voltage Monitoring Interface printed on it so this component could be a Voltage detector or Voltage supervisory circuit. Moreover I have tested this PCB in the equipment and came to that it has some threshold voltage level involved with some sort of timeout period also.
2. All 3 marking codes have fist 2 letters "AA" in common so this AA should be the identification code and rest 2 numbers are date or lot code.
3. Its a SOT23-5 Package so I have looked for codes with sot23-5 package
Now according to my work done so far. It seems it is a Microcontroller Supervisory Circuit with a threshold voltage level and reset options. But still not sure
Please help
eHassan
My advise in the other thread still holds...
Draw out the surrounding circuit even if you have to show the unknown component as a box.
Maybe start here   https://smd.yooneed.one/
Mike Adams
ADI Development, Inc.
http://www.adidev.com
... When it has to actually work.
Well, these are the hits I get from Turuta's "SMD-codes databook":
AA µPA501T          Si-pnp Dual, 60V, 100mA, 180MHz SOT-23-5 28/T12 - 6a Nec
AA µPA571T          Si-pnp Dual, 60V, 100mA, 180MHz SOT-23-5 28/T12 - 6a Nec
AA 74AHC1G00GW      CMOS-Logic 2-input NAND gate SOT-353 28/Log1 Log1 6a Phi
AA HD74ALVC1G14VS   CMOS-Logic Inverting Schmitt-trigger VSON-5 30/Log7 Log7 6a Ren
AA PI74ST1G125CX    CMOS-Logic Bus buffer gate with 3-state output SC-70-5 28/Log14 Log14 6a Per
AA PI74ST1G125TX    CMOS-Logic Bus buffer gate with 3-state output SOT-23-5 28/Log14 Log14 6a Per
AA RN5RT20AA        LVR-IC LDO, -CE, 2V±2%, 150mA SOT-23-5 28vrt VR4 6g Ric
AA SiP823LEU        Vdet-IC 4.63V, MR, Strobe, -Reset PPO SOT-23-5 28vds - 6k Vs
Thanks for your reply Sir. I will work on the part numbers you share and see if they match. If you get any other clue please share.
Thank you very much 😊
eHassan
Thanks Sir. It was very helpful for me. I will work on it. If you get anymore clues please share
eHassan
Yes I do reverse jobs often. You are right about it that there is no standard still if you get any clue please share
eHassan
Here is a strange idea...if you can take one of the chips and tear off the top plastic to look at the die, you might see something under the microscope (this is not likely, and not worth it if not easy for you to try)...maybe you are desperate!
For example here is a 741 opamp
You know I am a kind of guy who likes such reverse jobs like this a lot You are suggesting de-capping and I would love to do that but unfortunately I don't have such setup to do it. I like your suggestion buddy. Thanks for taking time to attach that photo example for me. I loved it 😊
eHassan
Have you drawn the schematic yet?
No I have not. I will soon and share
eHassan
Sometimes you can just take a pair of wirecutters & snip off the top plastic & see the chip....you can see the little electron people walking around
