AVR ISP MKII
15 posts / 0 new
I loaded a program to Atmega328 using AVR ISP MKII programmer.
The program works fine but when I remove the AVR ISP & just give power to the Atmega328 which is on breadboard the program doesn't work?
How to fix it?
First Fail & then succeed, this is what Engineering teach me.
Make sure you have a pull-up resistor between Reset and Vcc, 10k is common. Also, make sure you have a 0.1uF capacitor between Vcc and Gnd pins.
Are you sure you still have a gnd connection after you remove the ISP?  Did you actually measure the Vcc to AVR gnd with the programmer removed?  While the MKII ISP cable does not supply power, it could be acting as your gnd to the outside world.  Then pulling the cable, essentially removes power (broken gnd).
Any external inputs (switches, sensors ,etc) need to share gnd with the AVR...they can also be "fake" grounded through the ISP.  Pull the cable & they mysteriously quit, possibly affecting the program execution.
How are you sure the program is not running?
Make sure you have ALL chip ground pins are grounded
Make sure AVcc is connected to Vcc.
Are you ISP pins (MOSI,MISO, SCK) used as any part of your program?  If so, are they configured properly?
just to verify: The program works fine ..did you mean to say programmer...or does the actual program operate fine with ISP hooked up?
a clear picture is worth a 1k words, post a clear picture of your setup, please.
I have a Chinese AVRISP mkII that does power the board.  Very strange.  It shouldn't, but it does.
I installed a switch hack on my ISP MKII to pull 5V from it's USB so I didn't need to run around & grab a supply.
I did that but still, the problem exists.
All chip grnd pins are grounded & AVCC is connected to VCC. The program works fine with ISP hooked up. But when I use USB to power the board it doesn't work.
Is R42 the correct value ?
A clear circuit schematic is worth over 2k words, post a clear diagram of your setup, please. {post inline preferred vs attachment}
That's the first time USB has been mentioned. How are you using USB to power your chip? Have you proved that your USB is providing power right at the chip's pins?
There is a problem with the power supply. I connect USB to the power circuit which has a voltage regulator to power the board.
Not much of a fault report - what does "doesn't work" actually mean?
A common issue can be when a debugger/programmer provides a common ground for example. Say you use UART but you only connected TXD/RXD but not Gnd as well - then while the programmer was in place it might provide the AVR-PC Gnd connection that was otherwise missing when the programmer is removed.
OK, but have you actually measured the voltage the chip is getting AT THE PINS OF THE CHIP?
The power supply board has 5v & 3.3v pins so I have checked with both the voltages, there was an issue with the GND pin which I sorted out & now the program runs fine without a programmer.
I've seen too many students forget to hook up gnd somewhere. They remove a parasitic gnd (such as scope probe) & mysteriously things quit working
