Is there a small footprint ftoa (float to ascii) for SAM family?
6 posts / 0 new
I have an app for the SAMD21 (which I hope to port to other SAMx processors in the family) which needs to convert floating point numbers to ASCII strings.
With a design goal of a small memory footprint, I *really* don't want to use sprintf / %f and -u _printf_float.
Before I go and write my own version of ftoa (float to ascii), I ask: are there any equivalent functions in ASF or easily incorporated that have small memory footprints?
I'm not looking for full-scale, full precision printing: the float values are non-negative, with about four fractional digits, and the integer part never gets bigger than 16 bits.  Given that, it's not hard to write a conversion routine.  But I'm always open to using tested library functions than rolling my own...
Take a look at: https://www.quinapalus.com/qfplib.html
(Be aware of the license terms...)
Thank you for the pointer!  (And for the suggestion to look at the licensing -- my stuff is all MIT license, so it may not be a good mix.)  Ironically, for all the functions QFPLib provides, there are none listed about conversion to a string!
So I went ahead and wrote my own:
(NOTE: the "insert code" dialog is screwing up badly -- forgive the courier text...)
// print six digits to the right of the decimal point
#define FTOA_PRECISION 1000000
 * \brief cheap float to ascii conversion
 * Restrictions:
 * - output is written to a static buffer.  The caller must copy the contents
 *   to somewhere before the next call to cheap_ftoa()
 * - doesn't handle negative numbers, but it's easy to add if your application
 *   requires that.
 * - Results with anything that overflows an int are undefined.
 * - Results with Nan and Inf are undefined
static const char *cheap_ftoa(float x) {
  static char buf[20];
  int c = (x * FTOA_PRECISION) + 0.5; // handle rounding
  int d = c / FTOA_PRECISION;         // the integer part
  int f = c - (d * FTOA_PRECISION);   // the fractional part
  sprintf(buf, "%d.%06d", d, f);      // the "06" must equal log10(FTOA_PRECISION)
  return buf;
Using cheap_ftoa(), I could eliminate the -u _printf_float linker flag with the resulting reduction in code size:
With -u _printf_float:
    `0x00006188                _etext = .`
Eliminating -u _printf_float:
    `0x00003648                _etext = .`
In other words, it saved over 11K bytes of program space.
In my testing no matter how I write sprintf() it uses 20424 bytes, and gcvt() uses 12676 bytes...
/* gcvt */
//Global:
char* gcvt(double d, int len, char *str);
void double_to_char(double d, char * str) {gcvt(d,10,str);}
//in Main():
double_to_char(d,str);
https://www.quinapalus.com/qfpli...
(QFPIO - ascii to float AND float to ascii in 800 bytes.)
(beware license!)
