avr-gcc and avr-g++ are deprecated now.
31 posts / 0 new
FYI, the avr backend of GCC (avr-gcc, avr-g++) has been deprecated for v10, release schedule spring 2020.
If the backend is not re-written to use a different scheme to model condition-code, it will be removed from GCC in v11, release schedule spring 2021.
https://gcc.gnu.org/ml/gcc-patch...
Does this mean anything in a practical sense?
Is GCC support slowly going away (or becoming lower priority) for AVR's?
I suspect Microchip would like me to buy their compiler instead (and give me a 50% off coupon).
This relates to gcc v10. Given that Microchip is still using gcc v5, it would probably take 10 years or more before anyone notices anything.
Anyway, I noticed that code quality has peaked for v8 (when the  ISR fix was added), v9 seems to produce worse code. It seems recent gcc improvements are deleterious for AVR targets, so I predict v10 will be even worse.
Not disappearing though the effort to reach FSF AVR GCC v11 may be significant with a price and cost.
Would ones at Microchip expense for some of that effort?
(Microchip direct or indirect effort for source code modifications, FSF AVR GCC community effort to reach release)
Compiler Tool Chain Development – Embecosm
How much will a tool chain cost to develop?
For most architectures, Embecosm are able to create a proof-of-concept functional tool chain in 3 engineer months.
due to the Embench vice chair is at Embecosm :
Contributors to embench/embench-iot · GitHub
Our Participation in the Open Source AVR® Community - YouTube (Microchip Technology, 2m36s)
Embench™: A Modern Embedded Benchmark Suite
https://gcc.gnu.org/ml/gcc-patches/2019-09/msg01256.html
Forgive me for asking a stupid question, but does this mean there will be no more AVR support after GCC v9.x?
It doesn't affect V9. The announcement says deprecation at V10 and removal at V11
Technically, the removal will likely be carried out right after v10 will have been released, which is in less than 1/2 a year from now.
So how hard will it be for the AVR folk to keep v10 updating chasing various OS changes (assuming we don't care much about the back end.)
Arduino is now shipping gcc 7.4 to try to deal with the latest "64bit only) MacOS (or they're trying to, anyway.)
If you read the documents the deprecation will be avoided if someone implements the requested changes.  Any chance the Atmel folks would do this?
There are two ways of representing the condition codes in the back-end for an architecture: the old-fashioned, deprecated way called CC0 representation and the modern, mandatory for new back-ends, way called MODE_CC representation. As of now, most back-ends have been converted to the MODE_CC representation, but a few of them still use the CC0 representation, as summarized in Status of supported architectures.
It is also about chasing the C/C++ standards, and what if some other language is added.
my projects: https://github.com/epccs
Debugging is harder than programming - don’t write code you can’t debug! https://www.avrfreaks.net/forum/help-it-doesnt-work
Wonder what "Arduino will do" ...
I suppose a commercial compiler won't "Cut" there .. Maybe they have to switch to the "handicapped" version w. bad optimization.
Interesting ....
/Bingo
Note that the change might break some existing code:
Currently the condition code is implicitly clobbered by almost anything.
Most of the inline assembly I've seen does not include cc as a clobber.
If it does arithmetic, it clobbers cc, i.e. SREG.
Also, my recollection is that the ABI does not explicitly state whether function calls can clobber cc.
An obvious solution is to have both inline assembly and function calls implicitly clobber cc.
Meh.  I doubt whether most AVR embedded programmers are that much about new features ("current" avr-gcc is already ~4 major gcc versions behind, and I don't see a huge clamor for updates.  People are still using 2010 WinAVR...)  The people trying to do legacy hardware support "but xyz tool was W95 and doesn't run on anything newer than XP and I found the source but it won't even compile on a modern system and ..." seem more common.
The one place where "old compiler" may start to matter is when in 2026 they start making Arduinos with the as yet unannounced ATWhizzMegaSuper12345 and the compiler can't support it.
Nicknamed the AVR O-Mega.
Inline asm would be by far the easiest of all problems. Just implement the target_asm_clobbers hook.
Maybe it's time to let avr-gcc walk the walk of all mortals. At least that would save me some spare time because then I would no more be tempted to improve it.
Total votes: 2
Wow, if they managed it for the 68K, surely the prospects for AVR are promising...
$85 in less than a day.
The 68K bugzillla was created a little over two months ago:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=91851
https://www.bountysource.com/issues/80706251-m68k-convert-the-backend-to-mode_cc-so-it-can-be-kept-in-future-releases
... and appears to be resolved.
The bounty reached $5000 after little more than a month, and hit a little more than $6000 before being closed.
The bounty is up to $315.
The bounty is up to $535.
Th 68k changes are pretty massive :-(
Bounty is at $565, increasing by $1per day.
With that speed, it will surpass the 68k bounty in about 13 years...
Bounty at $655 today.
The bounty has increased to $1110.
Does anyone know whether someone converted MSP430?  That might be a closer example than the 68k.
The bounty is up to $1470.
I admit I have started reading the GCC Internals Manual.  The entire manual is about 800 pages.
(I'm making no commitment to work on this or claim that I am qualified to do so.)
status: I can now build gcc for avr from checked-out git repo.  I have yet to figure out how to run an uninstalled gcc.
bounty increased to $2020
I have read through a good amount of the GCC internals document and spent a little time going through avr.md.
The existing code seems to use attributes for clobbering cc.
;; '*' because it is not used in rtl generation.
(define_insn "*reload_inpsi"
  [(set (match_operand:PSI 0 "register_operand" "=r")
        (match_operand:PSI 1 "immediate_operand" "i"))
   (clobber (match_operand:QI 2 "register_operand" "=&d"))]
  "reload_completed"
    return avr_out_reload_inpsi (operands, operands[2], NULL);
  [(set_attr "length" "6")
   (set_attr "adjust_len" "reload_in24")
   (set_attr "cc" "clobber")])
bounty is time-limited :
AVR CC0 transition
The top bounty is from the CEO of SparkFun Electronics
15 Years of SparkFun - News - SparkFun Electronics
AVR CC0 transition
I believe they recanted the two year policy.  Not sure what the prior one was.
Hi
You're receiving this because we updated our Terms of Service.
Withdrawal of new Terms of Service
Yesterday, we communicated a change to the Bountysource Terms of Service (ToS) agreement.
These changes have been withdrawn and the ToS reverted to its prior state.
The ToS will be revised and clarified in the future.
Thankyou
Bountysource Team
support@bountysource.com
