atmega
43 posts / 0 new
intern temp atmega
desouza wrote:
0.5 milliseconds
Every 500 MICROSECONDS?
desouza wrote:
OCR0A = 78; // 5ms
BIG difference between 5 MILLISECONDS and 500 Microseconds.
Add some comments to the code explaining what you are doing.  Is teh ADC set up for free running?  Can't tell as I am not carrying a datasheet with me.
JIm
desouza wrote:
i i want to send the internal temp ever 0.5 milliseconds
Does the temperature change that fast???
desouza wrote:
i dont get it to work
Not a very good problem description, can you be more specific about what is not working.
desouza wrote:
SPI_transmit_data(ADC);
This function does not take arguments!  Does the compiler not complain about that???
No sry i meant 0.5 ms
desouza wrote:
SPDR = ADC;
ADC is a 16bit register, with10 bits valid but SPDR is 8bit, are you getting the 8 bits you want with this?
Perhaps SPDR = (uint8_t) ADC >> 8;  //ALAR is set so send the 8 MSB bits to SPI
Indeed!
@ desouza - standard questions:
  1. What did you expect to happen ?
  2. What is actually happening ?
  3. What testing / investigation / debugging have you done to find our where it's going wrong ?
desouza wrote:
i meant 0.5 ms
Which takes us back to the question of why on earth you want to measure that frequently!
How fast do you think the temperature can change ... ?
ki0bk wrote:
desouza wrote:
SPDR = ADC;
The OP has ADLAR set so I think they are adjusting for 8bit output from the ADC
JIm
Tell why this might be of interest, repeatedly sending the chip temperature.  [I guess it could be an experiment with e.g. steady state, then make some outputs drive a given load, and monitor the temperature rise?]
Would that not set SPIDR to the LSB of the ADC reg? ie.truncate the value
With ALAR set they would only get the LSB two bits of the result in the two MSB bits!?!
Perhaps this would work better:
SPIDR = ADCH;
No ADLAR truncated the two LSB off the result leaving the upper 8 bits in ADCHL
Edit....make that ADCH when ADLAR is set.
Ive change the code a little bit, my main issue is i cant see the internal temp when i try to print it? I haven't connected it with pins or anything i assume it works directly by activating the adc channel 8, it prints out 255 which i suppose is the memory size, but how can i get the internal temp instead?
#include <avr/pgmspace.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <stdio.h>
#include "ADC.h"
#include "serial.h"
#include "timer.h"
uint8_t ReadADC()
	//select ADC channel with safety mask
	ADMUX = (1 << MUX3);
	//single conversion mode
	ADCSRA |= (1<<ADSC);
	// wait until ADC conversion is complete
	while( ADCSRA & (1<<ADSC) );
	return ADC;
ISR(ADC_vect){
	ADCSRA |= (1 << ADSC);
ISR(TIMER0_COMPA_vect){
	printf("%d\n", ADCH);
	ReadADC(8);
void SPI_MASTER(){
	DDRB = (1 << PB0) | (1 << PB3) | (1 << PB5);
	SPCR = (1 << CPOL) | (1 << MSTR) | (1 << SPR0) | (1 << SPI2X) | (1 << SPE); //colckrate = 2 mhz
void SPI_SLAVE(){
	DDRB = (1 << PB4);
	SPCR = (1 << SPE);
uint8_t SPI_transmit_data(){
	PORTB &= ~(1 << PB0);
	SPDR = ADCH;
	while(!SPSR & (1<<SPIF));
	PORTB |= (1 << PB0);
	return(SPDR);
void main (void) {
	timer_init();
	uart_init();
	SPI_MASTER(); //master
	ADC_init();
	sei();
	while (1) {
		SPI_transmit_data();
You know what assume means! smiley
Rather then guessing, here is the datasheet section:
You need to set up the ADC ref to use the internal 1.1v ref.
yes i already did that !
You did?
Oh sry it was in my adc.h file but i had it tho
#include "ADC.h"
void ADC_init(){
	ADMUX = (1 << REFS0) | (1 << REFS1) | (1 << ADLAR);
	ADCSRA = (1 << ADEN) | (1 << ADIE) | (1 << ADPS2) | (1 << ADPS1);
Doing printf within an ISR is never a good idea - certainly not when you're sampling fast!
surprise
And then there is
ReadADC(8);
when ReadADC() doesn't take any arguments.
You'd have thought it would!
Similarly, in #18, El Tangas wrote:
And then there is
ReadADC(8);
@ desouza  : again, did you not get a warning about that?
If there's no warning, could that be because the declaration is:
uint8_t ReadADC()
rather than:
uint8_t ReadADC( void )
desouza wrote:
#include "ADC.h"
void ADC_init(){
BUT the above assignment overwrites what is in the init and sets the  ADC ref back to using VCC as ref!
Oh okay i changed it, but how am i able to see the internal temperature ?
Post your current version of your code so we can see where you are at. Trusting that you did the right thing(s) is blind faith.
desouza wrote:
i want to send the internal temp ever 0.5 ms via the SPi bus
So what are you sending the data via SPI too?   Surely that is how you "see" it, on the device receiving the SPI data????
Im not sending it to another mcu devie (slave), i just want to use the intern tempsensor in a SPI bus. The problem is i wan't to see if i'm putting the correct intern temperature in the SPI bus. When i try to print the adc value i get 64-128
#include <stdio.h>
#include "serial.h"
#include "timer.h"
uint8_t ReadADC()
	ADMUX = (1 << MUX3) | (1 << REFS0) | (1 << REFS1) | (1 << ADLAR);
	ADCSRA |= (1 << ADEN) | (1<<ADSC) | (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0) | (1 << ADIE);
	return ADC;
ISR(ADC_vect){
	ReadADC();
void SPI_MASTER(){
	SPDR = ADC;
	return(SPDR);
void main (void) {
	timer_init();
	uart_init();
	SPI_MASTER(); //master aktiv
	ADC_init();
	sei();
	while (1) {
	printf("%d\n", ReadADC());
#include <stdio.h>
#include "serial.h"
#include "timer.h"
uint16_t ReadADC(uint8_t chan)
	ADMUX = (chan & 0x0f) | (1 << REFS0) | (1 << REFS1);
	ADCSRA |= (1 << ADEN) | (1<<ADSC) | (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
	return ADCW;
void SPI_MASTER(){
	SPCR = (1 << CPOL) | (1 << MSTR) | (1 << SPR0) | (1 << SPI2X) | (1 << SPE); //clockrate = 2 MHz
uint8_t SPI_transmit_data( uint8_t val)
	SPDR = val;
	return SPDR;
void main (void)
 uint16_t adcVal;
	uart_init();
        ADC_init();
	while (1)
           adcVal = ReadADC(8);
	   printf("%d\n", adcVal);
           SPI_transmit_data(adcVal >> 8);
Start simple - get it working. I removed adc interrupts as they did nothing. I also removed the timer.
Okay thx!! i understand chan, but why do you right shift adcVal with 8? do u put it to channel 8? Oh i used the timers to send the adc value every 0.5ms
Why shift adcVal right 8 bits? Error! Should shift right 2 bits. Otherwise, does it work??
Okay i think so i get value 344!
Why not use ADLAR and then theres no shift?  Does one Really need the last two bits?
JIm
According to the data sheet the resolution is LSB = 1 degree C so if the OP wants temperature shown in steps of 4 deg, then no, but I would want to see 1 deg C steps, so I would want all 10 bits.
But that is me...
if i want to send the value through spi every 1s can i put the transmission inside the isr interuppt or should it be in the while(1) instead? Two diffrent examples ->
ISR(TIMER1_COMPA_vect){
  SPI_transmit_data(adcVal);
void main (void)
timer();
    uart_init();
        //ADC_init();
  sei();
    while (1)
// OR LIKE THIS???
void timer() {
        TCCR1A = (1 << WGM12) | (1 << WGM13); //ctc mode
        TIMSK1 = (1 << OCIE1A);
            TCCR1B = (1 << CS12) | (1 << CS10); //1024
        OCR1A = 15625; // 1s
void main (void)
timer();
    uart_init();
        //ADC_init();
  sei();
    while (1)
You should "never" put things which require a "long" time inside an ISR.
In general, that would include any form of serial comms.
However, you could start the transmission in the ISR - and then wait outside the ISR for it to complete.
This is very common!
Okay so i shouldnt use readADC in the interrupt? So i can use the transmission inside the isr like this?
I just answered that in #32!
Ok i understand but ReadADC only chooses the right adc channel and returns it during the interuppt which seems to work
There’s many ways to solve the problem - some are better than others. I’d suggest you set a flag in the timerisr, then have code in the while loop test for that flag then do the adc then the spi.
I wrote a tutorial on multitasking. It’s in the tutorials section. I also wrote a tutorial on the traps when using interrupts. A quick Google. should find them.
okay
desouza wrote:
    while (1)
      if(flag == 1){
Your indentation is all over the place!
Once the flag is set there, you never clear it ...
Shared variables MUST be volatile!
didn't someone write a tutorial about that ... ?
cheeky
I predict 60.
JIm
What's going on with this thread?
  • The title seems to have been pruned twice, and is now just "atmega"
  • Almost the entire content of the OP has disappeared.
surprise
EDIT
And the code from #37 has disappeared:
Yes, I noticed that as well.  No idea why the OP deleted things.
JIm
EDIT:
I have PM'ed the OP to see if they made the changes and why.
Stay Tuned
