How to "goto definition" in Atmel Studio 7?
11 posts / 0 new
Hi, I right click a function (the digitalWrite()) and select "goto implementation", as picture1 illustrated:
Then a .h file (Arduino.h) opened, as the picture2 illustrated:
But that's not what I expected, I want to goto the source code (the .c/.cpp file) of the "digitalWrite" function, can anyone give me an advise?
Best regards.
Arduino projects are built from a sketch object and a core object.
The core object is built once. Subsequent builds only need to compile the sketch part.
The sketch part only needs to know Arduino.h and not the core source code.
If you open the core dependencies, click on its Arduino.h
Then right-click on digitalWrite()
It might show you the core source code.
Untested.
david.prentice wrote:
Arduino projects are built from a sketch object and a core object. The core object is built once. Subsequent builds only need to compile the sketch part. . The sketch part only needs to know Arduino.h and not the core source code. . If you open the core dependencies, click on its Arduino.h Then right-click on digitalWrite() It might show you the core source code. . Untested. . David.
Hi, david,
Thank you for replying. I test right click on digitalWrite() in Arduino.h file, but nothing appears.
Best regards.
I typed my original reply from my breakfast table.
I have just tried on a PC:
1.  opened an AS7 Arduino project
2.  built it.
3.  right clicked: ArduinoCore->Dependencies->Arduino.h
4.  enabled Visual Assist from VassistX menu.
5.  hovered on digitalWrite()
6.  right-clicked on Goto Implementation.
7.  editor opens wiring_digital.c on the digitalWrite() function code.
Visual Assist might slow down your PC but it should work.
You also get the painful prompts when writing code.
I then tried hovering and right-clicking on the sketch.cpp file.
Sure enough it found the correct ArduinoCore file i.e.
C:\Users\David Prentice\Documents\Atmel Studio\ARDUINO_PROJECTS\blinky\blinky\ArduinoCore\src\core\wiring_digital.c
So you don't even need to use ArduinoCore Dependencies
2.  built it.
Hi, david,
I hovering on digitalWrite(), as the following picture illustrated, but nothing appears. I'm puzzling...
As David says, the IDE should be able to do this at the source level.
Does the project actually build?
If it does, a "workaround" to find the definition would be to run the sketch, and step into it using the debugger!
If it doesn't build, maybe that's because it really can't find the definition ... ?
Hi, awneil,
Thank you for replying. I had built the project, but...
This problem make me crazysad, maybe it's time to give up...
Thank you, and David,
Best regards.
It looks as if you have installed VisualMicro
This will guarantee that you will suffer SPAM for evermore.
And any AS7.0 debugging gets trashed.
I would not touch VM with a bargepole.
If an experienced member is brave enough to risk VM she might be able to help.
Note that AS7.0 is a bit crap with importing Arduino sketches.
Since the Arduino IDE works well,.  it is a mystery why anyone might want to import into AS7
So maybe wanggaoteng needs to contact them about this?
https://www.visualmicro.com/page/contact-us.aspx
https://www.visualmicro.com/forums/
Seems you're not the only one: https://www.avrfreaks.net/commen...
@ wanggaoteng  - does this work if you get rid of VisualMicro ?
I've not tried it for anything "advanced" - but it worked for me when I tried it on a simple project.
Does it do 'Go To Definition' ?
The usually-cited answer is for debugging - but that now seems to be going away:
Microchip have some tutorials on importing to AS:
EDIT
clawson gives another reason here: https://www.avrfreaks.net/commen...
No,  the Arduino IDE has no "goto definition" capability.
The standard Arduino functions are well documented.   You can see the calling procedure from the Help menu.
Most Arduino sketches involve C++ class objects with a few standard functions.
The header files contain the class methods and other info.
I have never found this to be a problem.    Most class methods are pretty straightforward.
However,   something like a baremetal ARM project in Keil or AS7 do become unwieldy.    Navigating the Cortex header files for the correct spelled macro do need some assistance.
I would be interested to hear from an experienced VM user.    It might not be bad.
Thanks.
I've not used it - so didn't know.
eg,
https://www.arduino.cc/reference/en/language/functions/digital-io/digitalwrite/
https://www.arduino.cc/en/Reference.digitalWrite
and google can find the source:
https://github.com/arduino/ArduinoCore-avr/blob/master/cores/arduino/wiring_digital.c
