XMEGA RC Accuracy?
6 posts / 0 new
I have an XMEGA A3BU xplained development board. I want to use this chip because it can do hardware quadrature decoding and I'm using a motor with very high encoder tick frequency (250KHz).
For my PID loop I want to have a fixed controller frequency of 500Hz so I am using software interrupts on TC0.
I can't seem to get my ISR to fire at the right frequency. I expect a period of 2ms but I'm getting 1.93ms. The default clock is the on-chip 2MHz RC. I've also tried using the on-chip 32MHz RC. Both RC clocks give me this same weird ~4% discrepancy in frequency.
I'd expect the RC clock to not be perfect, but better than 4%. I'd also expect the two RC clock's not to have the exact same discrepancy.
The dev board only has a 32768Hz external crystal, which isn't fast enough to use with PLL to get a good system clock.
Am I missing something? Does anyone have advice?
I'm using a modified form of the ASF quickstart code from "TC Example 1 - XMEGA-A3BU Xplained" in Atmel Studio 6. I can post my code if necessary.
If you have an external 32768Hz crystal, you can use "DFLL" to increase the accuracy of 32MHzRC.
Well, that doesn't seem too bad....here is the mega88PA,  the results for your Xmega chip may be tighter; have you tried doing a cal?
XMega is supposed to be good enough for async serial without calibration.
I have been using USART without external crystals since xmega was released.
It uses a DFLL with an internal 32768Hz and has shipped a lot as a product but has not reported any communication errors.
Digging up that datasheet shows your chip should be within +/-1.5%.  Are you using a decent freq counter with a solid timebase to measure?  Also, be careful you are not "off by one" in some counter/divider setting, especially if working with a small number
