coupling tiny with an nrf24
17 posts / 0 new
I'm looking for the cheapest AVR chip that I can use to talk to an nrf24 (Nordic wireless module) . My guess from searching is going to be a attiny.
requirements.
1 Must have SPI for communication.
2 At least two GPIO's
2 1k flash minimum
4 internal or external option to handle 2Mbps SPI speed
Of the requirements above I'm looking simply for the cheapest option and something with availability. Best find so far is the attiny24a. Any advice?
1) I take it you mean SPI (what NRF uses) rather than ISP. For an easy life that rules out most tinys that only have USI.
yes (edited) thx.
"that rules out most tinys that only have USI. "
I'm new to that, what make the USI capable tinys no good for my requirement?
Why would you bother with a nrf24 in this day and age? There’s the nrf51/52 and esp8266/32 devices that have the cpu and peripherals on chip.
Admittedly the programing.  Though I see the ESP8266  can be programmed with Arduino IDE. Secondly I'm not see encouraging prices here.  With a tiny and nrf24 I'm under $3.
ATTINY204 - 8-bit AVR Microcontrollers
The esp stuff is available for under $5USD.
Wow, yeah that's better... Especially with the lower power features. I never used UPDI  before is that viable with AVR studio?
 Going to try these out.
No (UPDI is in recent Atmel Studio 7)
Or, from Atmel Microchip, there's the SAM R21, etc ...
ATMEGA128RFR2 does seem to fit the bill and gets down to $3.80 from mouser, can this be programmed with the ARVISP mkII or like programmer (assuming it programs via SPI like any Atmega128)? If so will I need to some how get studio 6 an update for the rfr2 variant ( ATmega128RFA1  is listed) ?
Product Page says it has ISP & JTAG:
https://www.microchip.com/wwwproducts/en/ATmega128RFR2
yeah guessing the fuse bit are inline with the ATmega128RFA1 (ill have to check the data sheet), guessing I can just program it as ATmega128RFA1.
Found this on a thread " ATmega1284RFR2 is binary compatible with  ATmega128RFR2 and ATmega128RFA1."
Atmel AVRISP mkII is a go though
Issue #AVRSV-4050: User signature on RFR parts can only be accessed by JTAG or parallel programming.
so, Atmel-ICE
No; RFR2 are in Atmel Studio  v6.2.1563
Atmel Studio 6.2 Service Pack 2 (RELEASE NOTES) via AVR and SAM Downloads Archive | Microchip Technology
I've used NRF24L01+ with ATTINY2313 and even ATTINY45
I like them because you can get them on ebay for less than the wire needed to carry the signal otherwise.
Without adult supervision.
Embedded in Chan's pff code is assembly language code to control the USI hardware when used as a SPI master in a ATtiny85, ATtiny681 and, I suspect, many ATtiny uCs that have the USI hardware.
Most instructions for use (pin assignment, etc) are located in the usi.S file (just remove the '.txt' extension from the download).  The usi.h file contains the C function prototypes for the assembly language functions.
Alan
 Edit:  added a line to each file to give author credit to Chan
           added italicized text to put this post in context of the OP's original question
          and if the downloaded file names have a '_0' embedded, get rid of those also.
Petit FAT File System Module
by ChaN
[bottom]
Download: Sample projects for various platforms January 30, 2019
