ATmega32 starts first declared function instead main
3 posts / 0 new
Hi!
I have following code:
#define __AVR_ATmega32__
#define F_CPU 8000000UL
#include <util/delay.h>
void secondary(void) {
    DDRA  = 0b00000011;
    PORTA = 0b11111100;
    while (1) {
        PORTA ^= (1 << PA0);
        _delay_ms(100);
int main(void) {
    DDRA  = 0b00000011;
    PORTA = 0b11111100;
    while (1) {
        PORTA ^= (1 << PA1);
        _delay_ms(150);
        _delay_ms(150);
        _delay_ms(150);
        _delay_ms(550);
    return 0;
And then I compile BIN, generate HEX and flash it like this:
avr-gcc -Wall -g3 -Os -mmcu=avr5 -o $(APP).bin main.c
avr-objcopy -j .text -j .data -O ihex $(APP).bin $(APP).hex
avrdude -c linuxgpio -p atmega32 -U flash:w:$(APP).hex:i
The problem is ATmega32 runs secondary() function instead of main(). What am I doing wrong?
You are using the wrong start code. Use -mmcu=atmega32 and remove respective define from the source.
Better pick a correct source to copy/paste from...
Thanks! Wasn't entirely copy/paste...
I used this docs https://gcc.gnu.org/onlinedocs/gcc/AVR-Options.html and evidently get them wrong. Thank You again!
