Faster programming tools using SNAP
13 posts / 0 new
Hi there,
I've been working on some products using the new tinyavr chips, and am finally ready to start some small quantity production. Microchip says the PICkit 4 is a production programmer, but mostly I've found it to be garbage. The Snap is a much more reliable programmer. The more expensive programmers are not in my budget. For older PICs, I've always used the pickit 2 (clones, no less), which was always very reliable and "fast".
Fast in this case isn't actually the programming time - the newer programmers are MUCH faster in the actual programming. It refers to the time these take right from clicking the program button to getting done. The pickit 2 would start right away, however, the new ones take forever to start communicating with the tool. It takes about 12-15 seconds to do just this:
Currently loaded versions:
Application version............0.14.230
Target voltage detected
Then the rest of the "actual" programming takes just a couple of seconds (3-5).
Is there any way/software(such as PK2CMD for pickit 2; IPECMD takes the same amount of time as the GUI IPE/IDE) to get rid of the initial overhead and get right to sending the UPDI commands? It's easy enough for it to know if it fails without having to go through 15 seconds of connecting. This time adds up significantly.
Thanks!
-Sam
This is my atprogram command line.
It is faster because the firmware check is skipped by the first -f option.
atprogram -f -t snap -i UPDI -d attiny1617 program -fl -fs --verify -f FIRMWARE.elf
I often write about 10 to 50 devices, so I use a batch process like this.
I can write continuously by simply replacing the target and pressing the "Y" key.
path = "C:\Program Files (x86)\Atmel\Studio\7.0\atbackend";C:\windows\system32"
@echo off
:yes
@echo on
atprogram -f -t snap -i UPDI -d attiny1617 chiperase
@echo off
echo;
choice /m "Continue? "
echo;
if errorlevel 2 goto :no
if errorlevel 1 goto :yes
:no
exit /b
Thanks! I'm using a mac, so atprogram wasn't something I'd looked into, but will be using windows for production programming anyway, so I'll try this out now.
-Sam
I don't know because I haven't used it, but MPLAB also has a command line tool and may have the option to skip the firmware check.
FYI: You can also speed up repetitive atprogram sessions by starting atbackend separately and then connecting to it by specifying ip and port in atprogram...
Thanks, I'll try that too. I'm also considering using pyupdi instead - it does the job in 3 seconds!
-Sam
samay wrote:
... IPECMD takes the same amount of time as the GUI IPE/IDE)
MPLAB X SDK may enable you to create an alternative to IPECMD.
MPLAB X SDK For MPLAB X IDE | opensource4pic
Might inquire of Ron on how fast this is :
Programming ATmega4809 with UPDI from R-Pi | AVR Freaks
UPDI is one-wire UART with a protocol; so, BSD, Linux, macOS, Windows 10 IoT Core, etc.
Most PC will have a spare UART on a header on the motherboard.
GitHub - ms-iot/python (UWP Python therefore Windows 10 IoT Core)
UP Squared Board - AAEON UP | Mouser
due to Suggested Prototype Boards - Windows IoT | Microsoft Docs
via Overview of Windows 10 IoT Core - Windows IoT | Microsoft Docs
Quick update: atprogram is working well for now. Also, @kabasan's little bat file is very handy - I'll have to end up building something a little more comprehensive finally, but it's doing the job for now.
I've tried to find out how to do this:
but have had no luck yet. executing atbackend just starts the process with out any output on the console, no options or flags seem to do anything. Can anyone tell me exactly how to do this? I know how to specify the ip/port in atprogram, but how do I start atbackend on a specific port, and how do I choose the port? Thanks!
-Sam
You might also want to look at community member 'alank' all in one programmer that simply plugs on to your programming header and programs teh part in a couple seconds with no computer attached.  Not sure if it supports your target, but you can contact him about it.  theres a thread in marketplace for it:
atbackend /? Should give you the options... I think the default port is 4711 or 4911...
:: Morten
Thanks! atbackend /h gave me the options. For anyone else looking, atbackend /connection-port=[xxx] will do the trick.
-Sam
