notes on fixed versus floating point
9 posts / 0 new
I have no specific questions or requests for comment here.   I thought some peeps here may be interested.
In another thread I started a project which involves designing feedback control for a switched power converter.  My design involves computing the feedback by applying a number of "axpy" (a*x + y) operations.   I wanted to see if I could customize my own fixed point computation that might be faster and more compact than either built-in floating point or fixed point.
For the program I set up, I ran code for all three on my simulator and checked the time to evaluate "mycontrol()".  Here are the results.  Next to the size (in bytes of just the support code) and time (in seconds) are ratios wrt floating point.  N
   float pt: size= 734 1.00   time=0.00191284 1.00
   fixed pt: size=1186 1.62   time=0.00169482 0.89
my fixed pt: size= 146 0.20   time=0.00147237 0.77
Note that the gcc/avr-libc fixed point code is a bit larger than the floating point code.  Also, the performance of the floating point code is not grossly worse than the fixed point.  However, the times include all the "glue" code between binary operations (e.g., function calls, looping, etc).  I should probably try to isolate the binary operation times.
Here is the main program and my "axpy" code (which I call ypax, because it's more efficient to keep y first).   In avr-gcc, long fract is 0.31, long accum is 32.31; in my implementation I use 0.23 for fract and 8.23 for accum, where the notation N.R (e.g., 32.31) indicates N bits for the integer part and R bits for the fractional part.
main.c and fixpt.S follow. I have done testing on the fixpt code but not 100% confident it is fully working.
#include <stdio.h>
#include <stdint.h>
#include <stdfix.h>
#define USE_FIXED 1
int32_t fx32ypax(int32_t y, long fract *a, long fract *x);
float fl32ypax(float y, float *a, float *x) { return y + (*a)*(*x); }
union u_fract { long fract v; struct { uint8_t d, c, b; int8_t a; }; };
union u_accum { int32_t v; struct { uint8_t d, c, b; int8_t a; }; };
static inline int32_t fx32accum(long fract f) {
  union u_fract x;
  union u_accum y;
  x.v = f;
  y.a = 0; y.b = x.a; y.c = x.b; y.d = x.c;
  return y.v;
static inline long fract accum2fx32(int32_t a) {
  union u_accum x;
  union u_fract y;
  x.v = a;
  y.a = x.b; y.b = x.c; y.c = x.d; y.d = 0;
  return y.v;
static inline int8_t fx32toi8(long fract f) {
  union u_fract y;
  y.v = f;
  return y.d;
#if USE_FIXED
#if 1
/* my stuff */
#define myfract long fract
#define myaccum uint32_t
#define myfrtoac fx32accum
#define myactofr accum2fx32
#define myfrtoi8 fx32toi8
#define ypax fx32ypax
#else
/* avr-libc */
#define myaccum long accum
#define myfrtoac(X) (X)
#define myactofr(X) (X)
#define myfrtoi8(X) ((int8_t)((X)*256))
#define ypax(Y,AP,XP) ((Y)+(*(AP))*(*(XP)))
#endif
#else
#define myfract float
#define myaccum float
#define myfrtoi8(X) ((int8_t)((X)*256.0))
#define ypax fl32ypax
#endif
typedef struct {
  uint8_t n, nsb, nsp;;
  myfract *a, *b, *c, d;
} ss_t;
myfract __attribute__((noinline))
ss_eval(ss_t *m, myfract *x1, myfract *x0, myfract u)
  myaccum t, y;
  uint8_t ia, ix, nx;
  uint8_t i, j, n, p, q;
  n = m->n; p = m->nsb; q = m->nsp;
  y = 0;
  ia = 0;
  ix = 0;
  nx = 1 + q;
  for (i = 0; i < n; i++) {
    if (i >= (n-q)) nx--;
    t = myfrtoac(x0[i]);
    t = ypax(t, &(m->b[i]), &u);	/* + B*u */
    for (j = 0; j < nx; j++) {		/* + A*x */
      t = ypax(t, &(m->a[ia++]), &x0[ix+j]);
    x1[i] = myactofr(t);
    if (i < p) nx++;
    if (i >= p) ix++;
    y = ypax(y, &(m->c[i]), &x1[i]);
  return y;
const uint8_t n1sb = 1;
const uint8_t n1sp = 3;
#if USE_FIXED
long fract a1[] = {
  -0.0001000lr, +0.0017301lr, -0.0056214lr, +0.0000000lr, +0.0000000lr,
  -0.0035122lr, +0.0157545lr, -0.0226529lr, +0.0295285lr, -0.0023164lr,
  -0.0035122lr, +0.0044595lr, -0.0181410lr, +0.0000000lr, -0.0152183lr,
  +0.0431653lr, -0.0151720lr, -0.0152183lr,
long fract b1[] = {
  -0.0034256lr, +0.0024538lr, +0.0037149lr, -0.0001916lr, +0.0003384lr,
long fract c1[] = {
  -0.0133252lr, +0.0434246lr, -0.0332937lr, +0.0754853lr, -0.0336192lr,
#else
float a1[] = {
  -0.0001000, +0.0017301, -0.0056214, +0.0000000, +0.0000000,
  -0.0035122, +0.0157545, -0.0226529, +0.0295285, -0.0023164,
  -0.0035122, +0.0044595, -0.0181410, +0.0000000, -0.0152183,
  +0.0431653, -0.0151720, -0.0152183,
float b1[] = {
  -0.0034256, +0.0024538, +0.0037149, -0.0001916, +0.0003384,
float c1[] = {
  -0.0133252, +0.0434246, -0.0332937, +0.0754853, -0.0336192,
#endif
myfract get_meas() {
  static uint8_t ix = 0;
#if USE_FIXED
  static long fract vals[] = {
    +0.002lr, +0.003lr, +0.004lr, +0.005lr, +0.006lr, +0.007lr, +0.008lr,
    +0.008lr, +0.007lr, +0.006lr, +0.005lr, +0.004lr, +0.003lr, +0.002lr,
    -0.002lr, -0.003lr, -0.004lr, -0.005lr, -0.006lr, -0.007lr, -0.008lr,
    -0.008lr, -0.007lr, -0.006lr, -0.005lr, -0.004lr, -0.003lr, -0.002lr,
    +0.020lr, +0.030lr, +0.040lr, +0.050lr, +0.060lr, +0.070lr, +0.080lr,
    +0.080lr, +0.070lr, +0.060lr, +0.050lr, +0.040lr, +0.030lr, +0.020lr,
    -0.020lr, -0.030lr, -0.040lr, -0.050lr, -0.060lr, -0.070lr, -0.080lr,
    -0.080lr, -0.070lr, -0.060lr, -0.050lr, -0.040lr, -0.030lr, -0.020lr,
    +0.200lr, +0.300lr, +0.400lr, +0.500lr, +0.600lr, +0.700lr, +0.800lr,
    +0.800lr, +0.700lr, +0.600lr, +0.500lr, +0.400lr, +0.300lr, +0.200lr,
    -0.200lr, -0.300lr, -0.400lr, -0.500lr, -0.600lr, -0.700lr, -0.800lr,
    -0.800lr, -0.700lr, -0.600lr, -0.500lr, -0.400lr, -0.300lr, -0.200lr,
#else
  static float vals[] = {
    +0.002, +0.003, +0.004, +0.005, +0.006, +0.007, +0.008,
    +0.008, +0.007, +0.006, +0.005, +0.004, +0.003, +0.002,
    -0.002, -0.003, -0.004, -0.005, -0.006, -0.007, -0.008,
    -0.008, -0.007, -0.006, -0.005, -0.004, -0.003, -0.002,
    +0.020, +0.030, +0.040, +0.050, +0.060, +0.070, +0.080,
    +0.080, +0.070, +0.060, +0.050, +0.040, +0.030, +0.020,
    -0.020, -0.030, -0.040, -0.050, -0.060, -0.070, -0.080,
    -0.080, -0.070, -0.060, -0.050, -0.040, -0.030, -0.020,
    +0.200, +0.300, +0.400, +0.500, +0.600, +0.700, +0.800,
    +0.800, +0.700, +0.600, +0.500, +0.400, +0.300, +0.200,
    -0.200, -0.300, -0.400, -0.500, -0.600, -0.700, -0.800,
    -0.800, -0.700, -0.600, -0.500, -0.400, -0.300, -0.200,
#endif
  if ((++ix) >= (sizeof(vals)/sizeof(vals[0]))) ix = 0;
  return vals[ix];
volatile uint8_t d_num;
void put_cmmd(myfract u) {
  int8_t nn;
  nn = myfrtoi8(u) + 32;
  if (nn > 62) nn = 62;
  if (nn < 1) nn = 1;
void mycontrol() {
  myfract x0[5], x1[5];			/* state buffers */
  myfract *xp, *xn, *xt;		/* prev, next, temp */
  myfract u, y;
  ss_t m;
  m.n = 5; m.nsb = n1sb; m.nsp = n1sp;
  m.a = a1; m.b = b1; m.c = c1; m.d = 0;
  xp = x0;
  xn = x1;
  for (uint8_t i = 0; i < 128; i++) {
    u = get_meas();
    y = ss_eval(&m, xn, xp, u);
    put_cmmd(y);
    xt = xn; xn = xp; xp = xt;		/* swap prev,next */
int main() {
  mycontrol();
  while (1);
	.section .text
	.global fx32ypax
	;; int32_t muls334x(int32_t acc, long fract *x, long fract *y)
	.type fx32ypax,function
fx32ypax:
	push r28
	push r29
	movw Y,r18
	movw Z,r20
	adiw r28,1
	adiw r30,1
	;; (g:h:i:j) acc: (r25:r24:r23:r22)
	;; (a:b:c)  in: (r21:r20)
	;; (d:e:f)  in: (r19:r18)
	;;  _[a*d]
	;;     [a*e]
	;;     [d*b]
	;;       [b*e]
	;;       [a*f]
	;;       [d*c]
	;;         [b*f]
	;;         [e*f]
	;;           [c*f]
	;; (g:h:i:j) in (r25:r24:r23:r22)
	;; 0,1,2,18,19,20,21,22,23,24,25,28,29,30,31
	clr r26			; need a zero
	;; g[a*d]
	ldd r18,Y+2		; a
	ldd r19,Z+2		; d
	fmuls r18,r19 		; (a*d)<<1 => r1:r0
	adc r25,r26		; accum (only -1*-1)
	add r23,r0
	adc r24,r1
	sbrc r1,7		; sign extend
	com r26			;  r26:r1:r0
	adc r25,r26
	clr r26
	;; g:h[a*e]
	clr r20
	ldd r18,Y+2		; a
	ldd r19,Z+1		; e
	fmulsu r18,r19
	sbc r20,r26
	add r22,r0
	adc r23,r1
	adc r20,r26
	;; g:h[d*b]
	ldd r18,Z+2		; d
	ldd r19,Y+1		; b
	fmulsu r18,r19
	sbc r20,r26
	add r22,r0
	adc r23,r1
	adc r24,r20
	com r26			;  r2:r1:r0
	adc r25,r26
	clr r26
	;; g:h:i[b*e]
	clr r20
	ldd r18,Y+1		; b
	ldd r19,Z+1		; e
	fmul r18,r19		; r1:r0 <= (b*e)<<1
	adc r20,r26		; prop carry
	add r22,r1
	adc r20,r26
	;; g:h:i[a*f]
	ldd r18,Y+2		; a
	ldd r19,Z+0		; f
	fmulsu r18,r19		; a*f
	sbc r20,r26
	add r22,r1
	adc r20,r26
	;; g:h:i[d*c]
	ldd r18,Z+2		; d
	ldd r19,Y+0		; c
	fmulsu r18,r19
	sbc r20,r26
	add r22,r1
	adc r23,r20
	adc r24,r26
	com r26			;  r26:r1:r0
	adc r25,r26
	clr r26
	clr r1
	pop r29
	pop r28
	ret
Thanks!
MattRW wrote:
my fixed pt: ...
Could compare yours with the likely future C++ fixed point standard.
GitHub - johnmcfarlane/cnl: A Compositional Numeric Library for C++
A beauty of avr-g++.
via The Embedded Muse 361 - Tools and Tips
How optimized is the fixed point code for AVR?
A prior observation is that the (highly optimized) AVR floating point divide is usually similar in speed to an integer 32bit divide, since there is no HW division support and you end up looking at 32 bits worth of bitwise division vs only 24bits worth for the float.
If the gcc fixed point code isn't able to use the HW multiply capabilities (which wouldn't be that surprising), I'd expect it to compare badly :-(
The difference between floating point and fixed point is scaling.   After that division is a big job, so it does not surprise me that floating point and integer division is close in speed.  For example, on PowerPC float multiply is 1 cycle, float divide is 17 cycles, and that's all in hardware.
And I concur that multiply for float vs fixed is likely dominated by the 3-byte vs 4-byte multiply.  Another issue is rounding.  If the mulitply include rounding of the last bit, there is more overhead.
Similar for one AVR on a FPGA.
Floating Point Math - Xcelerator Block | Alorium Technology
MattRW wrote:
on PowerPC
Not familiat with PowerPC - do they all have hardware FP ?
It is certainly the case that FP on a Cortex-M with FP hardware can be faster than fixed-point ...
Good question!
Another question would be, "do you really need to use a general-purpose fixed-point library at all?"
Often, if you just use appropriate scaling, you can just do it all in straight integers ...
You can, but then you need to keep track of the decimal point (e.g., how much to shift after a multiply). I like being able to use fixed point literals (e.g., "0.123lr") in gcc.
Yes, of course - there's no such thing as a free lunch!
Generally, "keeping track of the decimal point" can be done in the source code - so you save on code size & execution cycles at run time.
ie, you are trading the coder's time & effort against code size & run time cycles.
Which is more valuable will, of course, depend on the specific requirements & constaints of the particular project.
