Solved: Am I going crazy?!
10 posts / 0 new
I'm pretty well experienced in AVR and I have a 328 project with some odd behavior.  Any time I have an if statement that checks a pin, it will disable the port that is enabled with the pullup.  It's been a minute, but I've done this 100 times and can't figure this one out.
	DDRB = 0b00000001;    //Configure data directions (1 = output)
	DDRC = 0b00000000;
	DDRD = 0b00000000;
	PORTB = 0b11000000;   //Pullups on brightness controls
	PORTC = 0b00000000;
	PORTD = 0b00000000;
	PCICR |= 1<<PCIE0;    //enable Pin change interrupts controller 0
	PCMSK0 |= 1<<PCINT6;  //Enable interrupt on PCINT6
	PCMSK0 |= 1<<PCINT7;  // Enable Interrupt on PCINT7
	sei(); //set interrupts
	While (1)
ISR(PCINT0_vect)//interrupt routine
	  if (!(PINB &= 1<<PINB6)) //Brightness Down selected
	      _delay_ms(25);
		  if (!(PINB&= 1<<PINB6))
				if(BrightnessValue >= 5)
			      BrightnessValue = BrightnessValue - 5;
				   BrightnessValue = 0;
This results in the corresponding port going low.  I'm using debugwire and a 328p  I have narrowed it to the if statement.
I don't get it.
Are you saying the DDRB resets to 0x00?
No, When the if statement runs lets say for pinB6, PortB6 goes to 0. or from 0b11000000 to ob10000000
when the if statement is for PINB7, you end up with PortB = ob01000000.
it kills the pullup.
It doesn't make any sense.
It makes perfect sense. You are assigning to the PIN register which toggles the corresponding bit in the PORT register, toggling the state of the pullup.
github.com/apcountryman/build-avr-gcc: a script for building avr-gcc
github.com/apcountryman/toolchain-avr-gcc: a CMake toolchain for cross compiling for the Atmel AVR family of microcontrollers
They are 2 different registers.  You read from the pin, you assign the pullup from the port when the DDR is set as an input.
An if statement on the pin register should not change the register on the Port.
You are writing to the PIN register in your if statements (bitwise AND assignments which I'm geussing should have just been bitwise ANDs) which, as I said, toggles the masked bits in the PORT register. From the datasheet: "Writing a '1' to PINxn toggles the value of PORTxn, independent of the value of DDRxn. The SBI instruction can be used to toggle one single bit in a port."
You're right.  That fixed it.
Don't you ONLY want to read the pin?...why are you ALSO changing it ( &= in your if)? get rid of =
writing a logic one to a bit in the PINx Register, will result in a toggle in the corresponding bit in the Data Register.
Total votes: 2
Please do not modify the code in the OP, but post the corrected code in a new comment. Changing the OP code confuses the new reader as the comments after no longer make sense.
Also, modifying the title doesn't actually mark the topic as solved to the forum software.
@ chriscalandro : Please see Tip #5 (in my signature, below; may not be visible on mobile) for how to mark a topic as resolved ...
