Xmega 16E5 - ADC basics...
7 posts / 0 new
Hi everyone,
I'd like to write simple functions for configuring and reading ADC (by pooling). Could you look at them to make me sure that they are right? I ask you because I get wrong results when the resolution is 12 bits.  robiw
void ADCconfig(void)
	//ADC config: 8bit single ended, no curr limit, ref = VCC/1.6, gain = x1
	ADCA.CTRLA = ADC_ENABLE_bm;  //ADC Enabled
	ADCA.CTRLB = ADC_CURRLIMIT_NO_gc|ADC_RESOLUTION_8BIT_gc;  //300ksps max sampling rate
	ADCA.REFCTRL = ADC_REFSEL_INTVCC_gc;  //Internal VCC / 1.6
	ADCA.PRESCALER = ADC_PRESCALER_DIV32_gc;  //1MHz @ 32MHz
	ADCA.CH0.CTRL = ADC_CH_GAIN_1X_gc|ADC_CH_INPUTMODE_SINGLEENDED_gc;  //Single-ended input, no gain
	ADCA.CH0.MUXCTRL = ADC_CH_MUXPOS_PIN0_gc;  //pin PA0
uint8_t ADCread(void)
	ADCA.CTRLA |= ADC_START_bm;  //Start new conversion
	while(!(ADCA.CH0.INTFLAGS & ADC_CH_IF_bm));  //Wait for the end of the conversion
	ADCA.CH0.INTFLAGS = ADC_CH_IF_bm;  //Clear Channel Interrupt Flag (not cleared by hw)
	return ADCA.CH0RESL;  //Return 8-bit result
your function only returns an 8 bit value, so yes it will be the wrong value.
change it to return a 16 bit value, and return the whole result.
jim
Yes. It is obvious that the result type should be uint16 and I changed It...r
this line may also need changing
ie
return ADCA.CH0RES; // compiler knows how to read full register value
Yes, I knew about this butt still it seems to work wrong. What about the rest? r
it looks like this line needs changing too, why are you not seeing these?
I saw this and knew it needs changing. R
