(.text+0x0): multiple definition of `ui8ArRxTx'
8 posts / 0 new
  Hello
  I got to a halt and I can't go any further. I am porting a project written AS7 to Arduino. I get few errors saying the a variable is defined multiple times. It is only declared in one .h file like this:
uint8_t ui8ArRxTx[ui16GenBufSize];
  The specific error message is:
  There is not such variable in function SpiArCamR1. Here is the function:
uint8_t SpiArCamR1(uint8_t ui8RegAddr)
	uint8_t ui8A; // a temporary variable
	SPCR = (1 << SPE | 1 << MSTR);
	SPSR = 0;
	PORTD = PORTD & ~(1 << 7);
	ui8A = SPSR;
	ui8A = SPDR;
	SPDR = ui8RegAddr;
	while (!(SPSR & (1 << SPIF))) {}
	ui8A = SPDR; // read byte and discard
	SPDR = 0; // write dummy byte
	while (!(SPSR & (1 << SPIF))) {} // check if SPI received a dummy byte
	ui8A = SPDR;
	PORTD = PORTD | (1 << 7);
	return ui8A;
  And by the way, it also complains about ui8A that is initialized and never used. Is there a better way to read the SPDR (spi data register) and do nothing with that data ? Some programming languages allow
= SPDR
  Any help is well appreciated.
But how many times is this .h  file included in different .c/.cpp? Each of it counts as a new global variable with the same name.
Usual way is:
into .h file - declaration "there will be some super global variable somewhere" by using extern:
extern uint8_t ui8ArRxTx[ui16GenBufSize];
and in corresponding .c/.cpp there'll be actual variable:
Computers don't make errors - What they do they do on purpose.
  In two places. The reason is I have a variable that is used in the main.ino file and in one function that is is one .cpp file. Is this OK ? If I do not include that .h file in one of the locations it complains that the variable is not declared.
Use guard statements in the header file
#ifndef MYHEADER_H
#define MYHEADER_H
#endif
Well, it's not OK, as you've got one instance created in ino and second instance is created inside cpp. That's why I mentioned solution - "extern".
If you need more details, there is crapload of it on the internet, like:  c++ multiple definitions of a variable
  Thank you for both replies. However, none of those worked. Reading on Internet I understand that Arduino does not respond very well to preprocessor directives. I gave up and renamed my .cpp files as .ino . No need for any headers in these files and it works. Mine is a somehow off books situation in that I modify global variables inside functions in these files. I did include Peter's I2C library and it works.
  I still want to figure out how to read the SPDR when I actually don't need that data. Because I do not do anything with that data I get many warning.
SPDR;  // this will read SPDR and throw away the results
  Works like magic.
