Arduino inline assembly
16 posts / 0 new
For this lab experiment you will create a program that uses only inline assembly (See Listing
1). You will need to reference the Instruction Set Summary from the ATmega328P data sheet.
1. Your program must configure PB0 as an input with internal pull-up enabled.
2. Your program must configure PB1 as an output.
3. Implement the equivalent of the infinite while loop in assembly
4. Inside the infinite while loop read PB0 and write the same value to PB1.
what is wrong in my code?
// Includes
#include <stdint.h>
// Defines
int main()
  init();
  Serial.begin(9600);
  Serial.write("Start of program/n");
            asm volatile("ldi r16, 0x01    \n\t"
             "sts 0x25, r16    \n\t");// PORTB = 0000 0001 turn on internal pull-up on PB0
            asm volatile( "ldi r16, 0x01    \n\t"
                "sts 0x24, r16    \n\t");// DDRB = 000 0010)
        while(1){
           asm volatile( "lds r16, 0x23    \n\t"    // read PINB
                         "sbrc r16, 0  \n\t");
           asm volatile("movw r16,0x23  \n\t"   //copy from PINB
                        "sts 0x24,r17  \n\t");
az
Welcome to AVR Freaks!
I applaud the fact that you have written something first, on your own, before posing a question.
I do not see anything that focuses on the 0 bit of PORTB and uses that value for the 1 bit of PORTB. There are several ways that it can be done.
Also, you are not doing: "Implement the equivalent of the infinite while loop in assembly"  What you wrote is C.  Consider what a jmp or rjmp might do.
The movw instruction is wrong; I don't think it does what you think its doing...
You're writing PORTB with a full byte, without adjusting the B0/B1 as required.
You should PROBABLY be using IO instructions rather than LDS/STS instructions, depending on the emphasis of the class.
look at SBIC & SBIS commands
sbic PINB, frog
sbis PINB, legs
I got burned very badly by that once when someone else decided to 'refactor' my assembler code into C.  He treated all code segments as subroutines, as if they all returned.  Many didn't - they 'jmp'ed back - or 'jmp'ed somewhere else.  Can we say "Stack-Smashing"!?!  I knew you could...  My code didn't do that.  His did.  Guess who got to fix it...  *grrr*  (Sorry, pet peeve.  Have fun, all!)
smiley   S.
I was thinking of the jmp as part of the infinite loop structure.
Have you read?:
https://www.nongnu.org/avr-libc/user-manual/inline_asm.html
The code would be clearer (perhaps?) if it actually names PORTB, DDRB etc.
But anyway, here's a way to cheat...
Write exactly what you need to do in C, build with -save-temps, study the .s file it creates ;-) (this may be more difficult in the Arduino world than for normal C development!)
+1
Does Arduino allow linking-in separate Assembler modules?
ie, is this an option ?
As far as I know, yes it does allow .S to be added. So it would be "cleaner" than trying to use asm("") in C.
awneil wrote:
is this an option ?
Ah - not for this particular homework assignment:
And that is where, personally, I think this falls down as an assignment. While it's great to get students to understand the basics Asm, the tortuous inline syntax completely obfuscates the learning process (assuming you want to do it symbolically and not with magic numbers like 0x24 and 0x25 etc).
Agreed - if you want to learn/teach assembler, then do it properly in a proper assembler file.
Plus inline assembler is all entirely proprietary - so not really a very useful thing to learn, IMO.
EDIT
@ ard98 - Of course, you have to do the homework as set. Just bear in mind that it's (probably) not a great way to do things in Real Life ...
I dunno.  If it's a more generic "embedded programming" class, then going through the "inline asm without symbols", "passing symbols to inline asm", "using external asm" sequence might be useful to show...
There are several errors, let me just pick one. The numbers don't match:
Waiting for the original poster to come back and say something.
If my son is any indication, the assignment was probably due Sunday Night (and at 5pm+ they noticed that their code didn't work), and any help arriving after that is irrelevant.  Sigh.
The OP must be new to programming, he forgot to return   angel
