sanity check on pd7 atmega32u4
11 posts / 0 new
I set up my ports like so
    DDRD &= ~0x80;// in
    DDRD &= ~0x40;// in
    DDRD  |= 0x20;// out
    PORTD |= 0x40;//latch
    PORTD |= 0x80;//clock
    PORTD |= 0x20;//data
I can & PIND with 0x40 just fine but 0x80 thinks its always low. I can clearly see on the analyzer that it goes high when expected and hits 5 volts.  but the code has another option. I thought maybe the pins had two states but from the data sheet it clearly is a i/o pin and with the same capabilities as pd6. Happy to provide more relevant code here but am I missing something.
Should probably add I'm using this but I did check the pin on the chip to breakout point and its good.
Also I do not have an external pull up but looks to be ok without, maybe I'm wrong. I attached what I see on the wire.
Top line is PD7 second is PD6, blue is debug. When the debug goes high, it is put in to a WHILE_CLOCK_IS_LO loop. You can see the line is high and even goes lo but debug runs its loop anyways.
T
Instead of all those read-modify-write oprations, why don't you just do:
DDRD = ....
PORTD = ....
I can do that for a test but other then the fact of "human error" I see no advantage.
For the record I tried with
    DDRD = 0;
    PORTD = 0xff;
but get the same results. Also added some debug info above.
What is connected to PD7?  Is this a board of your own creation?
Its is a Nintendo console (the original one) I'm connecting to a controller port on the system that uses a very well known C,L,D paradigm.  That top line in the image is the clock, the one that  works is the latch.
I tried to eliminate that by manual holding the pin high and low and I'm still in the same situation.
Here is the relevant code but I really dont see what is wrong here?
#define MAX_TIME 32000
#define WHILE_CLOCK_IS_HI while ( timer < MAX_TIME &&(PIND & 0x80)        ) {timer++;};
#define WHILE_CLOCK_IS_LO while ( timer < MAX_TIME &&(PIND & 0x80)==0x00) {timer++;};
#define WHILE_LATCH_IS_LO while ( timer < MAX_TIME &&(PIND & 0x40)==0x00) {timer++;};
#define WHILE_LATCH_IS_HI while ( timer < MAX_TIME &&(PIND & 0x40)         ) {timer++;};
    DDRD &= ~0x80;// in
    DDRD &= ~0x40;// in
    DDRD  |= 0x20;// out
    int   timer = 1;
    WHILE_LATCH_IS_LO// this works as it should
        timer = 1;
        PORTF |= 0x01;//debug hi
        WHILE_CLOCK_IS_LO   //<-- should break when HI but the loop keeps going
        PORTF &= ~0x01;//debug lo
        while(1);//debug halt
This intend code it to do this
        timer = 1;
        WHILE_CLOCK_IS_HI   //<-- but this causes the loop to exit right a way, when clearly it should loop until the clock falls or max time.
Why are you fooling around with timers and such?...first just make a program that ONLY looks at PIND & see if that works & detects hi/lo.
You neglect to mention what chip you have.
Also, it is better to specify the number of bits  for  timer1 (8 or 16)  so you don't get fooled.
I have pretty much have taken it all down to motoring PIND at this point and the chip simply will not see any state on PIND  ( 7th bit ) other than low. I can however, set out and the bit on PORTD will go high or low as seen on my scope. It seems only the reading condition fails.
I also have swapped chips (atmegas32_u4) with the same results.
Do you have both avcc pins tied to VCC on your board?
jim
This is a dev board but I think that was the issue. Both dev boards had the problem but pressing down on the chip fixes it. A reheat of the chip fixed it permanently.
You ordered the temperature sensing option on PD7 !
