ADC: joystick interface using Atmega328P
2 posts / 0 new
The code isn’t working and what should i do next i need to show the joystick movement on lcd but this code isn’t working can somebody help.
; Replace with your application code
LDI R16,LOW(RAMEND);
OUT SPL,R16;
LDI R16,HIGH(RAMEND);
OUT SPH,R16;
Start:
LDI R16,0XFF;
OUT DDRD,R16;
OUT DDRB,R16;
LDI R16,0X00;
OUT DDRC,R16;
LDI R16,(1<<ADEN)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);
STS ADCSRA,R16;
LDI R16,(1<<REFS0)|(1<<ADLAR)|(0<<MUX3)|(0<<MUX2)|(0<<MUX1)|(0<<MUX0);
STS ADMUX,R16;
Read_channel:
LDS R16,(1<<ADSC);
STS ADCSRA,R16;
Keep_Poling:
LDS R16,ADCSRA;
SBRC R16,ADSC;
RJMP Keep_Poling;
LDS R16,ADCSRA;
SBR R16,ADIF;
LDS R16,ADCL;
OUT PORTD,R16;
LDS R16,ADCH;
OUT PORTB,R16;
RJMP Read_channel;
M
mhmd wrote:
Read_channel:
LDS R16,(1<<ADSC);
STS ADCSRA,R16;
Isn't doing what you think it's doing.
You need to load ADCSRA with LDS, then modify with ORI and STS back to ADCSRA
There are a few other problems as well.
Which device?  What clock speed?
