Data Length vs CRC Length
25 posts / 0 new
hi
I think for every byte of data, we need one byte CRC
then if we have 64 byte data - we must have 64 byte CRC !!!   That doesn't sound logicallaugh
// this is the format of the CRC ( n < x )
data           : (x) bit
polynomial : (n) bit
CRC           : (n-1) bit
example ( decimal format, data 2byte ) :
data           : 12345   ( binary : 11 0000 0011 1001 )
polynomial : 305       ( binary :           1 0011 0001 )
CRC           : 255       ( binary :             1111 1111 )
but my problem is that > now for data=12345, crc=255 but for crc with this value ( 255 ), we have other data ( 2byte ) with this crc!!! for example : data=255 and ...
when we have several data with similar crc, ITS NOT GOOD indecision
What can we do now?
my answer is that, for set eror ( The probability of crc for several data (2byte ) being equal ) to zero, we must have CRC with number bits equal to Data
even for test, i wrote an softwer with c# ( for calculate all crc for data between 0 to 2 byte/65535 ) laugh
where is my problem? crc is not good idea or i mistake? I got a little confused cryingsad
http://www.ghsi.de/pages/subpage...
mahdi damirchilu, my blog : dmf313
No, you take the data, byte by byte. There is no correlation between the data size and the CRC length. CRC length has more to do with  the odds of missing an error or getting a false error.
CRCs are generally always 1, 2 or 4 bytes. That can even be true if it's checksumming GBs of data.
I'm sorry but I didn't understand.
what is the purpose of CRC? ---> receiver be able to detect the data is correct or not? --> yea?
can u write an example for 'FRAME' ? blush
You and Mr. Jim say :
1 Frame = 1byte Data + 1 byte CRC ---> then CRC length is not important so mutch ---> yea? enlightened
As Jim mentions, the value CRC is based on statistics. The larger the crc, the less likely you will have different sequences generating the same CRC. As well, CRCs are normally applied to serial data - the expectation is that you get bit errors and for a single bit error, the CRC generates a different number. So, it is not foolproof. Where you do have different sequences generate the same CRC value, you'll find the sequences are very different. Apply statistics to the likelihood of the expected error source to cause such a change.
CRCs are popular because they are easy to generate/check in hardware - they are a shift register with some xor gates.
Don't choose a random CRC polynomial - some work better than others. Best to choose a popular polynomial as it has been proven to work.
If you want something that is unlikely to have a collision, look at using cryptographic hashes.  Unfortunately, these are much more processor intensive unless your processor chip has special hardware to help.
Indeed.
You'd be surprised.
Volumes have been written.  Careers have been made.
https://en.wikipedia.org/wiki/Cyclic_redundancy_check
https://betterembsw.blogspot.com/2010/05/whats-best-crc-polynomial-to-use.html
https://betterembsw.blogspot.com/search/label/error%20detection
https://users.ece.cmu.edu/~koopman/pubs/ray06_crcalgorithms.pdf
https://www.google.com/search?q=koopman+crc
http://users.ece.cmu.edu/~koopman/crc/index.html
http://users.ece.cmu.edu/~koopman/crc/crc16.html
http://users.ece.cmu.edu/~koopman/crc/notes.html
https://en.wikipedia.org/wiki/Mathematics_of_cyclic_redundancy_checks
... to name but a tiny handful.
While popular polynomials do work, most were choosen before the polynomial space was surveyed and don't have the best error detection performance for their application. If you have the freedom to select your polynomial, you should refer to the research that has been done (nicely summarized here).
github.com/apcountryman/build-avr-gcc: a script for building avr-gcc
github.com/apcountryman/toolchain-avr-gcc: a CMake toolchain for cross compiling for the Atmel AVR family of microcontrollers
github.com/apcountryman/avr-libcpp: a partial implementation of the C++ standard library (C++17 only) for use with avr-gcc/avr-libc
github.com/apcountryman/picolibrary: a C++ microcontroller driver/utility library targeted for use with resource constrained microcontrollers
github.com/apcountryman/picolibrary-microchip-megaavr: picolibrary Hardware Interface Layer (HIL) for Microchip megaAVR microcontrollers
i dont choose random CRC polynomial ---> i chose 1 of them and test it with diffrent data ( 0-65535 ) and see for some Data, i have similar CRC ---> then i think if we have similar CRC for some data ( A, B ), then if we send "data A", but an error occur and reciver recive "data B", now with this niceeeee CRC, reciver can detect error? yea! u think right, answer is NO indecisioncrying   --->  my problem is thiisssssssssssssss ---> when crc is so weak, for what we must use it? we have no better method?
I tried this:
https://crccalc.com
I get different results for 41 and 42 hex. So what is the issue? You say CRC is weak, but where is your evidence?
Eg: CRC-8 poly
41 hex gives C0 result
42 hex gives C9 result
As well, don't write strange English when it is not your native language - it only makes it harder for us to understand. Keep your language simple and state facts, this will allow us to help you better.
Using the online calculator,
The sequence 3031 hex gives a crc of CD hex using the maxim poly of 31 hex. I can only assume you are calculating the CRC incorrectly.
Since you are using the Maxim polynomial, this suggests you are using 1wire devices. If so, tell us first, don't let us guess.
I think, the polynomial itself doesn't matter, the number of bits polynomial are important for decrease the number of duplicate CRCs. ( I don't know, but I think I'm right, maybe ... )
i see that link, what is " HD " ? ( Max lengthat HD /Polynomial ... )
HD is 'hamming distance'.
Kartman wrote:
I tried this:
https://crccalc.com
Eg: CRC-8 poly
u use  polynomial FOR 1 byte DATA or several byte DATA ?
in Frame ( data + crc ), we send 1_byte_data with 1_byte_CRC or several_BYTE_data with 1_byte_CRC?
u = You. You can type a couple extra letters to make it easier for us to read.
Give us an example of the problem you are facing. I gave you examples that you can try. Do they not work for you?
Kartman wrote:
I tried this:
https://crccalc.com
Eg: CRC-8 poly
for " CRC-8 " in that link, for "Data = 41 hex" and "poly = 0x07", how "result = 0xC0"  ??? Can you explain the calculation procedure?
i use this method : data / poly = result ( we use XOR )
THAT is NOT crc! Look it up instead of pretending that you are doing the right thing.
You haven't done the reading, then?
Nope.  Definitely haven't done the reading.
CRC is not perfect.  No error detection method is.  CRC is, however, very good, and very efficient.  It excels at detecting common types of errors in many situations.  In particular, it can be very good at detecting burst errors.
You cannot select a random polynomial (even a 'good' one) without first determining what your needs are.  What is the expected BER (bit error rate) of your application?  Is it subject to burst errors (such as for data transmission), or just random bit errors?
If you expect 100% error detection from any method, you will be forever disappointed.
// Compute a Dallas Semiconductor 8 bit CRC directly.
// this is much slower, but much smaller, than the lookup table.
uint8_t crc8(const uint8_t *addr, uint8_t len)
	uint8_t crc = 0;
	while (len--) {
		uint8_t inbyte = *addr++;
		for (uint8_t i = 8; i; i--) {
			uint8_t mix = (crc ^ inbyte) & 0x01;
			crc >>= 1;
			if (mix) crc ^= 0x8C;
			inbyte >>= 1;
	return crc;
source: https://github.com/adafruit/MAX3...
Just doing an xor is a checksum, not a CRC. CRCs are bit orientated, so you need to shift then xor for each bit.
You still haven't told us precisely what you're trying to achieve - all we've got so far is obscure references to CRC and little evidence. Tell what what you want to achieve and what you've done so far - then we can move forward. At the moment we're going around in circles because you aren't asking a clear question.
i use this method for calculate crc, its not correct? ops, then i must go and read more about correct method calculate crc...
Why are you making this so hard? Why do you post a random app note page with no reference?
Just show us your code.
That hides the way that CRC is normally done. Serially, bit by bit.
surprise ops, tyyyyyyyyyyy ( sorry, thank YOU friends laughyes ) - i think u say my main problem.
Next time you have a question - rather than try to tell us CRCs don't work, tell us
1. what you want to achieve
2. what you've tried
3. the results you got
4. the results you expect
If you had done this, your problem would've been solved in one post rather than 22
hi again, 1 question, this code for calculate crc is correct or not? ( C# code )
public byte Compute_CRC8_Simple(byte[] bytes, byte polynomial)
	byte crc = 0; // start with 0 so first byte can be 'xored' in
	foreach (byte currByte in bytes)
		crc ^= currByte; // XOR-in the next input byte
		for (int i = 0; i < 8; i++)
			if ((crc & 0x80) == 0) // if last bit = 0
				crc <<= 1;
				crc = (byte)((crc << 1) ^ polynomial);
	return crc;
And is this image below, the correct crc calculation method?,        image below and top code, is equal, yea?
Some example algorithms here...
https://www.nongnu.org/avr-libc/...
