SPI function on AVR START
13 posts / 0 new
I am trying to ping a slave. With the following code.
uint8_t Read25r3911b (uint8_t commandaddress)
{   uint8_t data;
	uint8_t TEMP;
	TEMP=commandaddress;
	data=0xFF;
	PORTC_set_pin_level(3,low);
	SPI_0_write_block(&TEMP,1);
     while ((SPI0.INTFLAGS & SPI_RXCIF_bm) == 0) ;
  //  while (SPI_0_status_done());
    //    SPI0.INTFLAGS &= ~(1<<INTERUPT_FLAG);
     	//PORTC_set_pin_level(3,high);
	SPI_0_read_block(&data,1);
		return data;
The first part of the code tells the slave to give a value in the following byte.  The issue is that read block is not reading the value.
Daniel Morley
See Tip #1 for how to do that!
awneil I don't understand the message.   Could you clarify.   Is there something incorrect in the way I posted the question.
Daniel Morley
It would be helpful if you would post the picture in your post.  Tip #1 in Andys signature has a link on how to do this.
JIm
Daniel Morley
As you can see the function SPI_0_write_block is working by sending the code 43 to the slave.   This is a read  and address of the register.   It's value is 8 by default.   The read function does not return this value.
Daniel Morley
Post your read function and teh associated screenshot of your analyser.
The code is the default created by AVR start.
void SPI_0_read_block(void *block, uint8_t size)
	SPI_0_desc.data   = (uint8_t *)block;
	SPI_0_desc.size   = size;
	SPI_0_desc.type   = SPI_READ;
	SPI_0_desc.status = SPI_BUSY;
	SPI0.DATA = 0;
Daniel Morley
Surely the Slave is returning 0x08 from the 0x00 write
Of course you will need to read the documentation for Start.   I suspect you are simply reading the response from the 0x43 write.   The next read will return the response from the 0x00 write.
I suggest that you initialise data with a unique value e.g 0x55.   Then you will see whether you are receiving 0xFF or 0x08.
What target device are you using?
{   uint8_t data;
	uint8_t TEMP;
	data=0xFF;
		return data;
Daniel Morley
The target device is a 25r3911 or a NFC board.   The byte 0x43 should return the register value on the next byte after the slave receives the command.   The 0xFF is just don't cares.
Daniel Morley
x-nucleo-nfc05a1 using a TINY416 as mcu spi master.
Daniel Morley
I'll remind you again that folks using mobiles and tablets won't be seeing any "signature" so saying "see tip #1" will be largely meaningless if they can't see the #N's ! ;-)
(I'd maybe say "see tip #1 in my signature below (only visible on PC, not tablet/mobile)" or something similar perhaps?)
