Solved: ATtiny 412 & Setting up TCB Timer
9 posts / 0 new
I'm going to apologize off the bat. I'm fairly new to AVR & C programming (started about 3-4 months ago). I'm trying to migrate some of the techniques I've learnt over the years from the Arduino language and apply it to AVR programming. More specifically, the ATtiny 412.
I now want to use a timing function so I can gather sample data points over a period of time. More specifically, I'd like to use TCB to do so since I'm already using TCA and TCD. I'm having a hard time getting it setup. I'm not even sure if I'm close. Reading some of the other posts, I think the best way is to utilize ISR(TCB0_INT_vect)?
I provided the code I'm using below. Hopefully it makes sense. I'm trying to gather analog data coming over period of time into PA7 so I can get smooth data vs. spikes up and down (Peak-to-Peak data).
If you have need any additional information, feel free to let me know.
Ankit
#define F_CPU 16000000UL
#include <util/atomic.h>
#include <inttypes.h>
#include <avr/interrupt.h>
#include <time.h>
#include <util/delay.h>
unsigned int peakToPeak;
unsigned int signalMax;
unsigned int signalMin;
const int sampleWindow = 50; // Sample window width in mS (50 mS = 20Hz)
unsigned int sample;
uint8_t _millis = 0;
uint8_t _1ms = 0;
uint8_t old_millis = 0;
ISR(TCB0_INT_vect)
	_1ms += 10;     // 10 ----> 160
		while (_1ms > 1000)
			_millis++;
			_1ms -=1000;
uint8_t millis()
	uint8_t m;
	cli();
	m = _millis;
	sei();
	return m;
void initADC()
    ADC0.CTRLC = ADC_REFSEL_INTREF_gc | ADC_PRESC_DIV8_gc;
    ADC0.MUXPOS = ADC_MUXPOS_AIN7_gc;
    ADC0.CTRLA = ADC_RESSEL_8BIT_gc | ADC_ENABLE_bm;
FUSES = {
    .WDTCFG     = FUSE_WDTCFG_DEFAULT,
    .BODCFG     = FUSE_BODCFG_DEFAULT,
    .OSCCFG     = FREQSEL_16MHZ_gc,     //Select 16MHz OSC
    .TCD0CFG    = FUSE_TCD0CFG_DEFAULT,
    .SYSCFG0    = FUSE_SYSCFG0_DEFAULT,
    .SYSCFG1    = FUSE_SYSCFG1_DEFAULT,
    .APPEND     = FUSE_APPEND_DEFAULT,
    .BOOTEND    = FUSE_BOOTEND_DEFAULT,
     	/* Set pins as i/o */
    PORTA.OUTCLR = PORTA.DIRCLR = PIN1_bm; // input.
	PORTA.OUTCLR = PORTA.DIRSET = PIN2_bm; // output.
//  PORTA.OUTCLR = PORTA.DIRCLR = PIN3_bm; // input. not used
	PORTA.OUTCLR = PORTA.DIRSET = PIN6_bm; // output.
	PORTA.OUTCLR = PORTA.DIRCLR = PIN7_bm; // input.
 {	 unsigned int peakToPeak = 0;   // peak-to-peak level
     unsigned long startMillis= millis();
	 unsigned int signalMax = 0;
	 unsigned int signalMin = 600;
     while (millis() - startMillis < sampleWindow)
		ADC0.MUXPOS|= 0x07;                   // ADC input in pin 7.
	    ADC0.COMMAND |= 1; // start running ADC
        if (ADC0.INTFLAGS)                    // if an ADC result is ready
	    {sample = ADC0.RES;}//input reading
        if (sample < 600)  // toss out spurious readings
		  if (sample > signalMax)
		  { signalMax = sample;}  // save just the max levels
		   else if (sample < signalMin)
		   { signalMin = sample;}// save just the min levels
peakToPeak = signalMax - signalMin;  // max - min = peak-peak amplitude
So, where is the initialization code for the timer?
hmmm, that would probably help...It has been a steep learning curve. I wasn't entirely sure how to set the initialization for the timer, but here's what I got based on other forums/discussions (new code that I added in):
void initTimerB()
    TCB0.CCMP = 8200;
    TCB0.CTRLA = TCB_CLKSEL_CLKDIV2_gc | TCA_SINGLE_ENABLE_bp;
    TCB0.INTCTRL = 1 << TCB_CAPT_bp;
{ initTimerB;}
Ankit
Here you would need to use TCA_SINGLE_ENABLE_bm (bit mask) instead of _bp (bit position). At this point I think I should direct you to the AVR 0/1 tutorial thread:
Read in particular TB3214 - Getting Started with TCB and AVR1000: Getting Started with Writing C-Code for XMEGA.
I interpreted the purpose of making a 1ms tick by TCB.
I would write initialization and interrupts like this:
volatile uint8_t _millis;           // It must be volatile to share with interrupt handling.
void initTimerB(){
    TCB0.CCMP = 15999;              // Premise of 16MHz operation
    TCB0.CTRLA = TCB_CLKSEL_CLKDIV1_gc | TCB_ENABLE_bm;
    TCB0.INTCTRL = TCB_CAPT_bm;     // Understand the difference between _bp and _bm.
ISR(TCB0_INT_vect){                 // 1ms interval interrupt
    _millis++;
    TCB0.INTFLAGS = TCB_CAPT_bm;    // Clear interrupt flag
I hope I can help you understand.
Here is a simple led blinker on a tiny416 nano board using tcb periodic mode and interrupt-
(FYI- if you do not clear the flag in the interrupt, you will be stuck there)
#include <xc.h>
#include <stdint.h>
volatile uint32_t systick_ms;
ISR(TCB0_INT_vect){
    systick_ms++;
uint32_t systime(){
    uint32_t t1;
    volatile uint8_t* t2 = (volatile uint8_t*)&systick_ms;
    for(;;){
        t1 = systick_ms; //get time
        if( (uint8_t)t1 == *t2 ) break; //if byte0 same, good
    return t1;
int main(){
    VPORTB.OUT |= PIN5_bm;  //high is off
    VPORTB.DIR |= PIN5_bm;  //led on PB5
    CCP = CCP_IOREG_gc;     //unlock
    CLKCTRL.MCLKCTRLB = 0;  //no prescale
    //tcb periodic, div1, irq on ccmp, on
    //using 20Mhz in this case
    //TCB0.CCMP = 16000-1;        //16000/16000000 = 1ms
    TCB0.CCMP = 20000-1;        //20000/20000000 = 1ms
    TCB0.INTCTRL = TCB_CAPT_bm; //irq enable
    TCB0.CTRLA = TCB_ENABLE_bm; //enable, div1
    sei();
    for(;;){
        uint32_t start_time = systime();
        uint32_t delay = 500; //ms
        while( systime() - start_time < delay );
        VPORTB.IN = PIN5_bm; //toggle pin (via IN when using vport)
As "_millis" is shared between the ISR and foreground code it MUST be volatile.
Also do not use symbols that start with either "_" or "__". The C library reserves names starting with "_" for it's own use (like _delay_ms()) and the C compiler reserves names that start with two "__" (like __builtin_avr_delay_cycles()). This is done to prevent name pollution so that all of the compiler, C library and your code could all (if they want) have something called __counter, _counter or counter.
If you do want to use some mark to say "internal variable" or "interrupt variable" or something (such as _millis and _1ms) then you could use it as a suffix so millis_, ms1_ etc - but clearly you could not have 1ms_ as that breaks the rules of C symbol naming (can't start with a digit).
Much appreciated guys. The info above is a great start. I'm going to go through all of this today and over the weekend. It's starting to make more and more sense as I go over it.
I'll keep you updated once I get a good foothold.
Cheers,
Ankit
Got the timer to work as intended, big thanks again for all the help. I've been reading through the tutorial's link provided by El Tangas - these have been a life saver. All the info above helped tremendously.
Cheers,
Ankit
