Trouble with Bootloader PC Tool Windows 10
6 posts / 0 new
Hi there,
I use Bootloader PC Tool 1.2.2 build 227​ for flashing SerialNet on Zigbit modules. Under Windows 10 the connection combo box only listed TCP/IP. I tried with different Windows 10  PCs, but it was the same problem.
Under Windows 7 I had no problems, the connection combo box listed TCP/IP, Serial, ...
How can I get the connection combo box, which listed TCP/IP, Serial, ... under Windows 10 ?
Thanks!
BR
SteMue
Hi SteMue!
I have the same problem with the bootloader and I don´t know how to solve it... :-(
Best regards,
Fabio
Windows 10 USB was improved with some defects corrected but did have a redesign.
Microsoft logo
Microsoft Windows USB Core Team Blog
What is new with Serial in Windows 10
July 29, 2015
https://blogs.msdn.microsoft.com/usbcoreblog/2015/07/29/what-is-new-with-serial-in-windows-10/
Windows 10 Anniversary Update (version 1607) had issues with some second party USB devices.
That may have been corrected (have not followed that), or there's a work-around (sometimes as simple as a driver uninstall and reinstall).
P.S.
There is an apparent issue for this on Windows 10 due to use of FLIP.
Atmel Corporation
Workaround: Flip software for Windows 10 64-bit
http://atmel.force.com/support/articles/en_US/Workaround/Flip-software-for-Windows-10-64-bit
Warning: The latest version of the Flip is not officially tested in Windows10.
via
http://atmel.force.com/support?q=%22Windows%2010%22
Edits : P.S., Windows 10 and Java
Microsoft
Windows 10 release information - current branch, build history
https://technet.microsoft.com/en-us/windows/mt679505.aspx
 Atmel Logo
Atmel
ZigBit USB Stick User Guide
How to Install the "Bootloader PC tool"
http://www.atmel.com/webdoc/zigbitusb/How_to_install_the_Bootloader_PC_tool.html
http://www.atmel.com/Images/Atmel-8390-WIRELESS-AVR2054-Serial-Bootloader-User-Guide_Application-Note.pdf
http://www.java.com/en/download/faq/win10_faq.xml (Windows 10 and Java)
I downloaded the full AVR 2054 package, read the Application note and all looked good. I wanted to
build a serial bootloader to my atmega2561 project.
When I started the Bootloader PC on my Windows 10 machine, I got the same problem as mentioned here.
Only the TCP/IP option was available.
I was not able to find any solutions in the Windows nor Atmel links provided.
If someone has found a solution to this, I really will like to know it ..
/Leif  E.
Leif Erik
v1.2.2.214 still works.  I have the same issue in Windows 10 with 1.2.2.235 which is the latest version.
Pc Bootloader tool was developed to support Windows 7, however with the below workaround the tool can work on a Windows 10 OS machine.
-> Set an environment variable "_JAVA_OPTIONS" to "-Dorg.osgi.framework.os.name=win32" in the system as shown below.
For my testing i have used Windows OS V10.0.16299.192 running Java Version 1.8.0_77 as seen below
a phoenix will rise from the ashes at the right time and at the right place
