Help? CTC compare interrupt won't be visited by execution even if compare flag is set
6 posts / 0 new
    TCCR1A=0b00000000;
    TCCR1B=0b00001010; //clock /8 and CTC with OCR1A as TOP
    TIMSK =0b01000000; //compare interrupt enable
    OCR1A=62500; //62500*8 gives 500000 which translates to 0.5s when an 1MHz clock is used
    DDRB    = 0b00000001;
    PORTB    = 0b11111111; //blinking pin 0 at port B
    TCNT1=0; //timer initialazation
    while (1)
ISR (TIMER1_COMPA_vect)
    PORTB    ^= 0x01; //ISR should be called every 0.5s
The compare match happens. The flag OCF1A is set but the interrupt is never executed. These are things I saw in the emulator.
I also tried a led at the PB0 but it won't blink. The chip is an ATtiny2313a. Help me I am lost :S
TO THE FINDER... THE ISLE OF KOHOLINT, IS BUT AN ILLUSION... HUMAN, MONSTER, SEA, SKY... A SCENE ON THE LID OF A SLEEPER'S EYE... AWAKE THE DREAMER, AND KOHOLINT WILL VANISH MUCH LIKE A BUBBLE ON A NEEDLE... CAST-AWAY, YOU SHOULD KNOW THE TRUTH!
try adding "sei();" to enable cpu interrupts
Ok I guess I should hav used sei(); ... Now it works. I thought sei(); meant external interrupts so I didn't use it.
Yeah exactly -_- thank you so much.
Can I set the "I" bit in the  SREG register in stead of using sei(); ?? Is it the same?
it's the same
