Program uploading problem in atmega328
9 posts / 0 new
Can i upload program in atmega 328 directly through rs233 usb to ttl converter after uploading the boatloading program in it
Kunal Gupta
github.com/gkunalupta
YOu first have to use an ISP programmer to flash the bootloader, but then yes, you can use a serial usb to ttl cable connected to the usart pins to upload new programs.
See Arduino! In fact why not use an arduino hardware platform, so much easier then bare chips and most likely cheaper too!
Uno or for bread board use, a Nano or pro-micro (sometimes called Leonardo) works well.
Yes so i have uploaded bootloader program in ic from usbasp by connecting MOSI - MISO pins .
Then i want to use ftdi rs232 usb to ttl converter which uses serial communication pins (Rx and Tx pins) for programming my atmega 328 ...
So should it work.
Saying for Arduino platform i know about it and have worked on it now i want to use atmega 328 using embedded c
Also another question can we say that when we are uploading program in Arduino we use serial communication that is we connect rx tx pins of Arduino to laptop rx tx pins through usb cable????????
Kunal Gupta
Kunalgupta wrote:
should it work
YEs - that is the whole point of a bootloader!
Your code will, of course, have to be written to be compatible with any specific requirements of the chosen bootloader.
And you will need to follow the correct procedure to get the bootloader in "loader" mode ...
I know Arduino call it "UPloading", it should really be called downloading - going from the (usually more powerful) "Host" to the "Target" is conventionally called "down"
Essentially, yes.
Physically, the microcontroller's Tx & Rx pins connect to the Rx & Tx pins of the USB-to-UART converter; the laptop itself does not have real Rx & Tx pins - they are "virtual".
EDIT
If you did have a real COM port on the laptop - with real Rx & Tx pins - you should not connect them direct to a microcontroller!
A real COM port works at RS232 voltage levels - around +/-12V - which are not compatible with microcontroller pins!
Same applies to a USB-to-RS232 converter.
In that case, you would need an RS232 Transceiver - traditionally a MAX232 - to convert the voltage levels (among other things).
https://www.maximintegrated.com/en/design/technical-documents/tutorials/2/2020.html
https://learn.sparkfun.com/tutorials/serial-communication
When discussing hardware connections, it is BEST to show a schematic rather then try to explain the connections in words (1 picture is worth a thousand words), it is much faster to show a schematic as it does not suffer from language translation errors!!!
See Andy's tip #1 for how to post code and pictures.
When you say things like " rs233 usb to ttl converter " that makes no sense, as RS232, USB and TTL are three different things.
There are USB serial to RS232 converters, there are USB serial to TTL converters, there are RS232 to TTL converters, which of these three are you actually talking about?
Absolutely!
Indeed.
laugh
Indeed.
i am using rs232 usb to uart programer ...the screenshot of the programmer i have uploaded screenshot(118).
and i am getting this error when i am using this.(another screenshot(90)).
Kunal Gupta
The board you are using is not a ‘programmer’ it is simply a usb to serial board. Avrdude is obviously not happy, so where did you get your Avrdude from? And why are you choosing ttl232 as a programmer?
Use a USBASP, for instance from extremeelectronics, (good product).
I use the Arduino IDE with MCUDUDE's mighty/minicore to program bare Atmega8/328/16 or 32. Code can be uploaded using CTRL+Shift+U.
