Build error in atmel studio
14 posts / 0 new
So, I wrote a simple program to blink an led in atmel studio.
Whenever I want to build the code. I receive an error message .
- recipe for target 'main.o' failed
- 'bit_is_clear' was not declared in this scope
- macro "bit_is_clear" requires 2 arguments, but only 1 given
'_delay&ms' was not declared in this scope
'else without a previous 'if'
- '_delay_ms' was not declared in this scope
Kindly check the picture to see this message.
Note am using AS 7.0
Regards
Oyekunle Quadri
So you need to provide the macro bit_is_clear and also define your F_CPU speed and include the delay.h lib.
Just as the error msg says....
Please see Tip #1 for how to take a screenshot, and how to post it!
And how to do that as am still practically new to atmel studio
Oyekunle Quadri
How do I do that @Jim
Oyekunle Quadri
I just wrote a tutorial on how to do replies in the forum: https://www.avrfreaks.net/forum/... - including how the forum shows what you're replying to.
There's not really anything special about Atmel Studio here - it's standard 'C' programming stuff.
There's a load of introductory videos to get you started with Atmel Studio on the Atmel Studio page:
https://www.microchip.com/mplab/avr-support/atmel-studio-7 - scroll down to the end
How to set Project Defines - such as F_CPU - in Atmel Studio:
Advantage of using the Project Defines over #defines in the source code:
https://www.avrfreaks.net/commen... (not specific to Atmel Studio)
Thank you for your response.
So, I uninstall the AS 7.0 as the VASSIST is grayed out and I installed AS6.0
writing the following code
#define F_CPU 8000000UL
#include <util/delay.h>
    DDRB |= (1<<0);
    DDRB &= ~ (1<<1);
    PORTB |= (1<<1);
        PORTB ^= (1<<0);
        if (bit_is_clear (PINB, 1))
        _delay_ms(100);
        _delay_ms(10);
        //TODO:: Please write your application code
But I get the following errors
    'else' without a previous 'if'
Oyekunle Quadri
https://www.tutorialspoint.com/c...
Thank you.
Issue sorted!
Oyekunle Quadri
Quadril wrote:
 I uninstall the AS 7.0 ... and I installed AS6.0
That's really not a good idea!
7 is definitely superior to 6.
The errors you are reporting are not due to installation problems.
Please see Tip #1 for how to properly post source code, and Tip #5 for how to mark a thread as solved.
As side from that.
I can't access the Vassist X feature of the atmel studio 7
Oyekunle Quadri
That's a separate issue - it wouldn't have helped with any of the errors reported above.
It would certainly be better to use AS7 instead of 6.
You could start a separate thread if you want help to get it working ...
Sorry I have been busy working at my day job, looks like Andy answered your questions.
Thanks Andy!
