Atmega328 controlling led with usart and pyserial
11 posts / 0 new
Hello together,
I want to control a simple led via pyserial.
If pyserial sends a 0, the led should go off, if a 1 is sent the led should go on again.
So I start with setting the pin to high, so the led is on.
As soon as I sent a 1 via pyserial the led goes off for about 1-2 second but then turns on again. It does not stay off.
Here are my files:
main.c
#include <util/setbaud.h>
#define BAUD 9600
#define F_CPU 16000000UL
volatile uint8_t loopVar = 1;
void setup() {
    UBRR0H = UBRRH_VALUE;
	UBRR0L = UBRRL_VALUE;
	UCSR0B = (1<<RXEN0)|(1<<TXEN0); //enable uart
    UCSR0C = (1<<UCSZ01)|(1<<UCSZ00); // 8bit dataframe
int main(){
    setup();
    DDRD |= (1 << PIND4); // set pin4 as output
    PORTD |= (1<<4); // set high
    while(loopVar) {
        if (UCSR0A & (1<<RXC0)){
           if (UDR0 >0){
              PORTD |= (1<<4);
           }else{
              PORTD &= ~(1<<4);
Pyython file:
import serial
import struct
import binascii
ser = serial.Serial()
ser.baudrate = 9600
ser.port = 'COM4'
ser.open()
print(ser.name)
value = 0
s = struct.pack('B', value)
ser.write(s)
ser.close()
So again the problem is, that when I execute the python script, the led goes off but after 1-2 second goes on again.
Can anyone detect an error or is there something wrong of my understanding with USART?
Thanks for any help:)
You need to clarify, do you want to send 0 as in 0x00 (NUL) or "0" as in 0x30(ascii 0 char), and 1 as in 0x01(SOH) or "1" as in 0x31(ascii 1 char) ???
What other characters are in your data stream, cr? lf? cr & lf?
Atually it doesn't matter for me.
But let's say I want to sent integer values 0 and 1.
Sorry, what do you mean with cr? lf ? cr & lf?
cr is carrage return
lf is line feed
I'm not familiar with pyserial, so I don't know what is sent when it is called.
Does it convert the value passed into a single character, or as string of characters or what???
run a terminal emulator and connect it to your pyserial device and see what comes out when you run your program, or use a logic analyzer to see what is on the wire.
When working with two unknowns, your pyserial device, and your AVR device, you don't know which one is the problem.
so we need to know what the pyserial device actually sends on the wire when you run the program above, once you know that, then you can troubleshoot the avr end if needed.
As far as i know:
To send a single, unsigned byte the format character should be 'B' (in which case endianism does not apply) so struct.pack("B", value) should be enough:/
Don't know if it is, but turning back on could be explained by
1) the ser.close does something which appears to AVR as another received (and non zero) character, or
2) the AVR is resetting
A logic analyzer or DSO would help show what is actually on the line.
Your code only tests for zero to turn LED on, all other characters ( >0) will turn the LED off.  So not real robust test, it may be better to use a switch case with 0, and 1, all else (default) are ignored.
Is indeed sending an unsigned byte, you might want to try this:
michac1995 wrote:
ser.flushOutput()
ser.flushOutput()
value = 0
ser.write(s)
ser.flushOutput()
ser.close()
Your test run is horrible.... pyserial should send a "1" then wait, then send a "0" then wait & repeat everything, say 5 times....do you then see your led blinking on & off?
That will tell you a lot about whether things are proper between the systems...your test run tells basically nothing.
Absolutely.
I'm not very familiar with python but even I can do somethihg like
while 1:
    s = raw_input('enter ')
    if s == 'q':
        break
    elif s == '0':
        print 'sent 0'
        # ser.write
    elif s == '1':
        print 'sent 1'
        # ser.write
    else:
        print 'ignored'
Probably all different now with python 3.
Rather than try to debug 2 bits of software at once, wouldn't it be simpler to just start by using a terminal on the PC to get the AVR working?
Then, once you know the AVR is working, move on to automating the PC end in Python.
Alternatively, get the Python working first by connecting to a terminal.
Using printable ASCII would make this a whole lot easier ...
