Timer1 Stops counting for no apparent reason
15 posts / 0 new
Hello Freaks,
I'm experiencing some strange problem on a project that I'm working on with an atmega328p.
I've configured timer1 as CTC mode with a 256 prescaller to generate the desired frequency to send to a stepper motor witch is given by a gyroscope angle (MPU6050) to be processed by PID controller implemented on while loop.
The problem is that the timer1 stops one second from time to time (not always at the same frequency, random like you can see on attached image) without any apparent reason.
Attached the code bellow:
       Language            :      C
       Year                :      2019/2020
       Class               :      LABSI
       Authors                    :      Luís Silva | João Loureiro
       E-mail              :      1101420@isep.ipp.pt | 1131109@isep.ipp.pt
#define F_CPU 16000000UL                                                  /* Define CPU clock Frequency e.g. here its 16MHz */
#include <avr/io.h>                                                              /* Include AVR std. library file */
#include <avr/interrupt.h>                                                /* Include AVR interrupt library file */
#include <util/delay.h>                                                          /* Include delay header file */
#include <inttypes.h>                                                            /* Include integer type header file */
#include <stdlib.h>                                                              /* Include standard library file */
#include <stdio.h>
#include <stdint.h>
#include <math.h>
#include "MPU6050_res_define.h"                                           /* Include MPU6050 register define file */
#include "I2C_Master_H_file.h"                                            /* Include I2C Master header file */
//unsigned char PWM=0;
volatile unsigned int c = 0;
char float_[10];
char TxBuffer[50];
float Acc_x,Acc_y,Acc_z,Temperature,Gyro_x,Gyro_y,Gyro_z;
float Acceleration_angle[2];
float Gyro_angle[2];
float Total_angle[2];
float elapsedTime;
float rad_to_deg = 180/3.141592654;
//volatile float PWM;//, error, previous_error;
//#define duty(val) (255*val)/100 //      % Duty Cicle
//#define dutym(valbom) (-67*valbom+1000)
/* Functions */
void inic()
       DDRC = (1<<DDC0) | (1<<DDC1); //0x0F;          // Set PC0 & PC1 as output to Motor direction & scope test probes
       DDRB = 0b00000110;         // Set PB1 and PB2 as output OC1A & OC1B
  //     DDRD = (1<<DDD6) | (1<<DDD5);     // Set PD5 & PD6 as output OC0A to test TIMER0
       /* Timer 0 */
   /*    TCCR0A = (1<<COM0A1) | (1<<COM0B1)| (1<<WGM01) | (1<<WGM00) ;      // Clear OC0A | Fast PWM
       TCCR0B = (1<<CS02) | (1<<CS00);                                                         // PRESCALER=1024
       TIMSK0 |= (1<<TOIE0);        // Overflow interrupt enable
       OCR0A=0;        // PWM = 0
       OCR0B=0;        // PWM = 0
       /* Timer 1 toggle LED*/
       TCCR1A = (1 << COM1A0) | (1 << COM1B0); // Enable OC1A e OC1B to motors
       TCCR1B = (1 << CS12) | (1 << WGM12);    // CLKIO/256 (From prescaler) | Mode CTC
      // TIMSK1 |= (1 << OCIE1A);                       // Enable TIMER1
       OCR1A = 62535;                                               // motor speed right
       OCR1B = 62535;                                               // motor speed left
       /* Timer 2 */
       TCCR2A =  (1<<WGM21);                                 // MODE CTC
       TCCR2B = (1 << CS21) | (1 << CS22);                                // CLKIO/256 (From prescaler)
       TIMSK2 |= (1 << OCIE2A);                       // Enable TIMER0
       OCR2A = 88;                                                  // ~0.001088s  ~900Hz    68
       /* USART */
      /* UBRR0H=0;
       UBRR0L=51;                                                         // BAUDRATE 38400
       UCSR0A=(1<<U2X0);                                            // Double Speed
       UCSR0B=(1<<RXCIE0)|(1<<RXEN0)|(1<<TXEN0);      // RX Complete Interrupt Enable, Receiver Enable; transmite Enable
       UCSR0C=(1<<UCSZ01)|(1<<UCSZ00);                       // 8 bits
       sei();
      // sprintf(TxBuffer, "Init successfully!!!\r\n");
      // SendMessage(TxBuffer);
void MPU6050_Init()                                                              /* Gyro initialization function */
       _delay_ms(250);        /* Power up time >100ms */
       I2C_Start_Wait(0xD0);                                                     /* Start with device write address */
       I2C_Write(SMPLRT_DIV);                                                    /* Write to sample rate register */
       I2C_Write(0x07);                                                          /* 1KHz sample rate */
       I2C_Stop();
       I2C_Write(PWR_MGMT_1);                                                    /* Write to power management register */
       I2C_Write(0x01);                                                          /* X axis gyroscope reference frequency */
       I2C_Stop();
       I2C_Write(CONFIG);                                                        /* Write to Configuration register */
       I2C_Write(0x00);                                                          /* Fs = 8KHz */
       I2C_Stop();
       I2C_Write(GYRO_CONFIG);                                                   /* Write to Gyro configuration register */
       I2C_Write(0x18);                                                          /* Full scale range +/- 2000 degree/C */
       I2C_Stop();
       I2C_Write(INT_ENABLE);                                                    /* Write to interrupt enable register */
       I2C_Write(0x01);
       I2C_Stop();
void MPU_Start_Loc()
       I2C_Start_Wait(0xD0);                                                     /* I2C start with device write address */
       I2C_Write(ACCEL_XOUT_H);                                           /* Write start location address from where to read */
       I2C_Repeated_Start(0xD1);                                          /* I2C start with device read address */
void Read_RawValue()
       MPU_Start_Loc();                                                          /* Read Gyro values */
       Acc_x = (((int)I2C_Read_Ack()<<8) | (int)I2C_Read_Ack());
       Acc_y = (((int)I2C_Read_Ack()<<8) | (int)I2C_Read_Ack());
       Acc_z = (((int)I2C_Read_Ack()<<8) | (int)I2C_Read_Ack());
       Gyro_x = (((int)I2C_Read_Ack()<<8) | (int)I2C_Read_Ack());
       Gyro_y = (((int)I2C_Read_Ack()<<8) | (int)I2C_Read_Ack());
       Gyro_z = (((int)I2C_Read_Ack()<<8) | (int)I2C_Read_Nack());
       I2C_Stop();
void AngleCalc()
       //---ACC X---
     //  Acceleration_angle[0] = atan((Acc_y/16384.0)/sqrt(pow((Acc_x/16384.0),2) + pow((Acc_z/16384.0),2)))*rad_to_deg;
       //---ACC  Y---
       Acceleration_angle[1] = atan(-1*(Acc_x/16384.0)/sqrt(pow((Acc_y/16384.0),2) + pow((Acc_z/16384.0),2)))*rad_to_deg;
       //---GYRO X---
      // Gyro_angle[0] = Gyro_x/131.0;
       //---GYRO Y---
       Gyro_angle[1] = Gyro_y/131.0;
       elapsedTime = 0.001408;           //tempo relativo à frequência de aquisição TIMER0
       //Filtro complementar
       //---X axis angle---
       //Total_angle[0] = 0.98 *(Total_angle[0] + Gyro_angle[0]*elapsedTime) + 0.02*Acceleration_angle[0];
       //---Y axis angle---
       Total_angle[1] = 0.98 *(Total_angle[1] + Gyro_angle[1]*elapsedTime) + 0.02*Acceleration_angle[1];
float sat(float _pid, int umin, int umax)
       if (_pid <= umin)
             _pid = umin;
       if (_pid >= umax)
             _pid = umax;
       return _pid;
void PID()
	  float desired_angle = 0;
	  float error = Total_angle[1] - desired_angle;
	  //Proporcional
	  float kp = 0.005; //Com este valor(0.04), só com a componente P, os motores (quase) não param, mas é sempre a dar brita!!
	  if (kp < 0) kp = 0;
	  float pid_p = kp * error;
	  //Integral
	  float ki = 0.0007;	 // Na casa dos 0.000K (acho eu)
	  if (ki < 0) ki = 0;
	  static float pid_i;
	  pid_i += error * ki;
	  pid_i = sat(pid_i,-100,100);
	 // if (pid_i > 1000) pid_i = 1000; //Limite wind-up
	 // if (pid_i < -1000) pid_i = -1000;
	  //Derivativo
	  static float previous_error = 0;
	  float kd = 1;
	  if (kd < 0) kd = 0;
	  float pid_d = (error - previous_error) * kd;
	  previous_error = error;
      float pid_tot = pid_p + pid_i + pid_d;                // Calcular saída temporária
      // PWM = sat(pid_tot,-20,20);	// saturação do atuador
       if (error < 0)
             PORTC = 0b00000000;
          // OCR0A = duty(abs(PWM)); //LED para simular PID
          // OCR0B = duty(0);		 //LED para simular PID
             OCR1B = abs(pid_tot);
             OCR1A = abs(pid_tot);
       if (error > 0)
             PORTC = 0b00000011;
          // OCR0A = duty(0);		 //LED para simular PID
          // OCR0B = duty(abs(PWM)); //LED para simular PID
       if (error == 0)
             PORTC = 0b00000000;
             OCR1B = 500; // Supostamente perto de parado
             OCR1A = 500; // Supostamente perto de parado
int main()
       inic();          // Main configurations
       I2C_Init();      // Initialize I2C
       MPU6050_Init();	// Initialize MPU6050
             if (c==1)
                    Read_RawValue();	// Read gyro and acc from MPU6050
                    AngleCalc();
                    PID();
                    c=0;
/* Interrupts */
ISR(TIMER2_COMPA_vect)
       if (c==0)
             c=1;
Thanks in advance for your help.
Best Regards.
lui54lb3rt0 | linkedin.com/in/Luis-Alberto-Silva | Creating robots from scratch
Total votes: 2
Try what happens if you fix it as follows:
             if (c==1)
                    AngleCalc();
                    PID();
                    cli();
                    c=0;
                    sei();
What makes you say the timer stops counting?   It is more likely you are setting an invalid PWM value.  What happens if you set a fixed amount  (say 222)...does it still mysteriously stop & start?
Also, why is your PWM float?  It can only take on a rather limited range of values ...some form of integer is best.
You have the overflow interrupt enabled on timer 0, but no ISR defined. Unpredictable things are going to happen.
You also have a USART interrupt enabled with no ISR defined.
You might want to make this a uint8_t and give it a useful name like 'timerFlag'.
Total votes: 3
Nothing to do with your problem but code like this:
is dangerous as the compiler is free to reorganize this. I'd probably do it as:
      Gyro_z = I2C_Read_Ack() << 8;
      Gyro_z |= I2C_Read_Nack();
Also what is the type returned by I2C_read_Ack() anyway?
 I2C_read_Ack()  is a char function.
char I2C_Read_Ack();                            /* I2C read ack function */
The code that you talk is commented....
Because something strange happens and on the timer pin OC1A and stops to generate the frequency for one second like you can see on the attached image of the first post.
If I set a fixed value on OCR1A or B works like a charm...
I could be wrong, but it seems to me like you are trying to use both ocr1a/ocr1b in a ctc mode where ocr1a is used as TOP. Any time TOP is greater than ocr1b, there is no oc1b output changes since there will be no match, and I imagine oc1a will just toggle at TOP.
Switch to CTC mode 12 where ICR1 is used as TOP ?
Maybe I am misunderstanding what is intended, as the posted code sets both ocr1a/b to the same value.
Thanks for help but doesn't solve the question...
Several things can stop a timer. A big one, though, is TOP value of zero.
Total votes: 3
CTC mode is not double buffered, so if you miss a 'match' because you are changing ocr1a to a value less than tcnt1, then you have to wait until the overflow, then back to the match value. At 16MHz / 256, that is 62.5khz, about a seconds worth of timer1 max time (or rather up to a little over a second).
Maybe use a pwm mode where double buffer is in effect, or stop the counter while changing ocr1a, or check tcnt1 and if is beyond ocr1a set it to 0, or whatever needs to be done to make sure tcnt1 does not end up beyond ocr1a.
If oc1a/b are to be the same output, you could switch to ctc mode 12, use icr1 as the value to set (the half period), and ocr1a/b would be fixed to 0. You would still have to deal with changing icr1 to make sure the counter is not beyond it-
ICR1 = abs(pid_tot);
TCNT1 = 0;
//or
//if( TCNT1 > ICR1 ) TCNT1  = 0;
Thanks for you reply...
You are absolutely right... I'll test it tomorrow and give you a feedback. 👌🏽
Hey curtvm thank you very much for your help, the solution that you provide works like a charm... I own a dinner (or a beer if you prefer laugh) when you came to Portugal laugh
