Defined Value Changing
12 posts / 0 new
I've been working to try and get some readable data from an IMU for awhile now (MPU-6050) but I've run into a really strange problem where it seems a defined value is changing.
This is causing all the code to not work because the value that's changing is the TWIE address on my XMEGA. (line 8 #define MPU_TWI &TWIE in mpu.h).
When I pause the program that's running, the port* value will be reported as 0x02a0 or 0x00a0 instead of the 0x04a0 that it should be.
I get the feeling it's probably the TWI code (See lines 42-46 of twi.c) doing some funky things so I'm going to use the atmel provided TWI example code and rewrite the MPU code to work with it instead, but I figured it might be worth it to post what I have here and see if someone might be able identify a silly mistake before I go about doing that.
Thank you!
You are NOT defining a "constant" or a "value". Remember, macros only result in text substitution. So, if TWIE changes, so will MPU_TWI. What happens will depend totally on how the macro expression is used.
Why would the address of TWIE change when it's a hardware constant? It's the address of the TWI on Port E as defined by device type (128A1U).
Just looked at the XMega E manual and could not find TWIE anywhere. On regular Mega chips, that is a BIT name and number.
Ooops, XMega128AU has a TWIE register. Sorry. Nothing further, here.
void XBeeSendStrInt(int16_t number)
	int16_t length = snprintf( NULL, 0, "%" PRId16, number );
	char temp[length];
	char* str = temp;
	snprintf( str, length + 1, "%" PRId16, number );
Writing length + 1 to an array of size length, so it's going to be overwriting something when it writes the null byte at the end of the string.
Make the array 1 longer.
Whether that is causing your specific problem I don't know, but I would fix it first. Likewise in the SendDbl function.
Definitely unrelated but thanks for the catch!
Astray wrote:
... and see if someone might be able identify a silly mistake before I go about doing that.
A linter somewhat finds my silly mistakes or produces a hint to follow through on.
How so sure?
Bizarre behaviour and values "magically" changing of their own accord are classic symptoms of a  buffer overrun!
Because the function it's from isn't called at all in that current version of the code before it breaks.
As already noted here and in your subsequent thread, that's clearly nonsense!
0x04a0 is the address of the port:
#define TWIE                  (*(TWI_t *) 0x04A0) /* Two-Wire Interface */
But port* is  not an address:- the '*' here is the pointer de-reference operator - it gives you the data found at that address.
I am happy to report that I have gotten the code working with defines by using volatile when passing the port.
I don't want to post 200+ lines of code here so I'll just include them in a file below. This will get raw and scaled data off an MPU6050 using TWI for xmega.
Jolly good.
Now please mark the solution - see Tip #5.
