I'm trying to compile the WINC1500 driver in atmel studio and I'm running into this error saying
"error "Need to define M2M_POINTER_SIZE_IN_BYTES"
I'm using the AT32UC3C1256C MCU and have it defined in the winc1500_driver_config.h file. I don't know how to solve this error, I've been following the instructions below to try getting the WINC1500 module to interface with the MCU.
// Set the size of host MCU pointer, in bytes. Pointer sizes vary depending on the MCU
// architecture. The pointer size can be determined by executing the code:
// int x = sizeof(int *);
#if defined(__PIC32MX__) || defined(__PIC32MZ__)
#define M2M_POINTER_SIZE_IN_BYTES 4
#elif defined(__C30__)
#define M2M_POINTER_SIZE_IN_BYTES 2 //2
#elif defined(__XC8)
#define M2M_POINTER_SIZE_IN_BYTES 3
#elif defined(__SAMD21J18A__)
#elif defined(__AT32UC3C1256C__)
#define M2M_POINTER_SIZE_IN_BYTES 4 // 32 bit microcontroller, the pointer size is 4 bytes
#else
#error "Need to define M2M_POINTER_SIZE_IN_BYTES"
#endif
