I question came to my mind when i was designing a pcb for a home project which includes a lcd (16*2 lcd connected in 4 - bit mode) and an atmega32 i had connected that in this manner:
RS - PB4, E - PB5, RW - GND and D0 to D7 connected to PB0 to PB3 respectively.
Now let's come to the problem i want to interchange the data lines connected to PORTB i.e. I want to connect them in reverse order like this:-
D0 to D7 should now connect to PB7 to PB4 and RS to PB1 , and E to PB2. I can change the position of RS and E but i don't know how can i change the code to send data in this manner to the lcd. Here is the code that i am using for lcd interfacing.
#define F_CPU 8000000UL /* Define CPU Frequency e.g. here 8MHz */ #include <avr/io.h> /* Include AVR std. library file */ #include <util/delay.h> /* Include Delay header file */ #define LCD_Dir DDRB /* Define LCD data port direction */ #define LCD_Port PORTB /* Define LCD data port */ #define RS PB0 /* Define Register Select pin */ #define EN PB1 /* Define Enable signal pin */ void LCD_Command( unsigned char cmnd ) { LCD_Port = (LCD_Port & 0x0F) | (cmnd & 0xF0); /* sending upper nibble */ LCD_Port &= ~ (1<<RS); /* RS=0, command reg. */ LCD_Port |= (1<<EN); /* Enable pulse */ _delay_us(1); LCD_Port &= ~ (1<<EN); _delay_us(200); LCD_Port = (LCD_Port & 0x0F) | (cmnd << 4); /* sending lower nibble */ LCD_Port |= (1<<EN); _delay_us(1); LCD_Port &= ~ (1<<EN); _delay_ms(2); } void LCD_Char( unsigned char data ) { LCD_Port = (LCD_Port & 0x0F) | (data & 0xF0); /* sending upper nibble */ LCD_Port |= (1<<RS); /* RS=1, data reg. */ LCD_Port|= (1<<EN); _delay_us(1); LCD_Port &= ~ (1<<EN); _delay_us(200); LCD_Port = (LCD_Port & 0x0F) | (data << 4); /* sending lower nibble */ LCD_Port |= (1<<EN); _delay_us(1); LCD_Port &= ~ (1<<EN); _delay_ms(2); } void LCD_Init (void) /* LCD Initialize function */ { LCD_Dir = 0xFF; /* Make LCD port direction as o/p */ _delay_ms(20); /* LCD Power ON delay always >15ms */ LCD_Command(0x02); /* send for 4 bit initialization of LCD */ LCD_Command(0x28); /* 2 line, 5*7 matrix in 4-bit mode */ LCD_Command(0x0c); /* Display on cursor off*/ LCD_Command(0x06); /* Increment cursor (shift cursor to right)*/ LCD_Command(0x01); /* Clear display screen*/ _delay_ms(2); } void LCD_String (char *str) /* Send string to LCD function */ { int i; for(i=0;str[i]!=0;i++) /* Send each char of string till the NULL */ { LCD_Char (str[i]); } } void LCD_String_xy (char row, char pos, char *str) /* Send string to LCD with xy position */ { if (row == 0 && pos<16) LCD_Command((pos & 0x0F)|0x80); /* Command of first row and required position<16 */ else if (row == 1 && pos<16) LCD_Command((pos & 0x0F)|0xC0); /* Command of first row and required position<16 */ LCD_String(str); /* Call LCD string function */ } void LCD_Clear() { LCD_Command (0x01); /* Clear display */ _delay_ms(2); LCD_Command (0x80); /* Cursor at home position */ } int main() { LCD_Init(); /* Initialization of LCD*/ LCD_String_xy(0, 10, "Hello World"); while(1); }
