Attiny85: Program to big. What can I do?
17 posts / 0 new
Hy
I am trying 2 build a controller for my parking heater with a attiny85 (digispark).
So far I got a encoder switch a i2c display and sensor working just fine, but now the flash memory is full.angry
I know about the 2 options to delete the bootloader or simply take a bigger chip (arduino nano already ordered to use as new controller or programmer for the 85 or both)laugh
I am also thinking about writing parts of my program in assembler, but i am using the libraries TinyWire and LiquidChristal_attiny and scince my code contains mainly calls to these libraries and not much other code, i fear that writing my code in assembler wont help much but i realy would need to rewrite the librariessurprise. Is this correct or do you have any other ideas?
Thx
Here the code
#include <util/delay.h>
#include <TinyWireM.h>
#include <LiquidCrystal_attiny.h>
#define LCD_ADDR     0x27
#define LCD_WIDTH    16
#define LCD_HEIGHT   2
#define TEMP_ADDR 0x40
#define ENC_A        1
#define ENC_B        4
#define OUT_1        3
#define OUT_2        5
#define delay_time 160 //in sec
#define delay_time_on 5  //in sec
#define menu_len 6
LiquidCrystal_I2C lcd(LCD_ADDR, LCD_WIDTH, LCD_HEIGHT); // set address & 16 chars / 2 lines
volatile int8_t enc_old = 2;  //encoder state memory
volatile int8_t Enc_turn = 0;   //how often encoder has been turned
volatile int8_t Enc_sw = 0;   //if encoder has been pushed
int16_t temp=999;  //ist-temp*10
uint8_t temp_retry=0,temp_state=0;
int16_t t_lim = 150, t_on=60,t_off=60; //soll-temp*10
uint8_t t_hyst=10;
uint8_t state=0;  //0=ports off, 1=1 port on, 2= 2 ports on
volatile unsigned long t_activ=millis();  //time of last encoder state change
int8_t pos_m=1;
char* Menu[menu_len] = {"Exit   ","Temp   ", "OnTime ", "OffTime", "Repeat ", "Hyst.  "};
uint8_t m_state[4]={1,0,0,0};
uint8_t i2c_w8(uint8_t addr,uint8_t data) //send i2c command
{ TinyWireM.beginTransmission(addr);
  TinyWireM.send(data);
  uint8_t r = TinyWireM.endTransmission();
  return r;
static inline void initTimer(void)
  TCCR1 |= (1 << CTC1);  // clear timer on compare match
  TCCR1 |= (1 << CS13) | (1 << CS12) | (1 << CS11) | (1 << CS10); //clock prescaler 8192
  OCR1C = 1; // compare match value
  TIMSK |= (1 << OCIE1A); // enable compare match interrupt
  sei();
ISR(TIMER1_COMPA_vect)  //timed interrupt to read encoder state
  enc_old = (enc_old & 0b110000) | (enc_old & 0b11) << 2 | ((PINB >> ENC_A & 1) << 1) | (PINB >> ENC_B & 1);
  if (enc_old == 0b001101)
  { Enc_turn++;
    enc_old |= 0b010000;
    t_activ=millis();
  else if (enc_old == 0b001110 )
  { Enc_turn--;
    t_activ=millis();
  else if (enc_old == 0b001100) {Enc_sw = 1;t_activ=millis();}
  else if ((enc_old & 0b110011) == 0b010000) enc_old &= 0b001111;
void setup(void)
{ //TinyWireM.begin();
  lcd.init();
  lcd.backlight();
  i2c_w8(TEMP_ADDR,0xFE); //sensor reset
  DDRB|=1<<ENC_A+1<<ENC_B;
  PORTB|=1<<ENC_A+1<<ENC_B;
  initTimer();
void show_val(int16_t val,uint8_t dec,char* unit)   //show int16 as float
{ uint8_t pos;
  int8_t rval;
  if (dec)
  { val=val/pow(10,dec);
    rval=val%(int16_t)pow(10,dec);
  if(val>99) pos=0;
  else if (val>9) pos=1;
  else pos=2;
  if (val<0) { pos--; rval=-rval;};
  while(pos--)
    lcd.print(" ");
  lcd.print(val);
  if (dec)
  { lcd.print(".");
    lcd.print(rval);
  lcd.print(unit);
uint16_t set_val(int16_t val,uint8_t dec, uint8_t step,char* unit)  //show and adjust a numerical value with encoder
{ while (true)
  { lcd.setCursor(4,1);
    show_val(val,dec,unit);
    if (Enc_sw)
    { Enc_sw=0;
      return val;
    { val+=step*Enc_turn;
      Enc_turn=0;
    delay(100);
inline uint8_t measure()   //read temperature sensor (call repeatedly until result)
{   uint8_t s;
    temp_retry++;
    if (temp_retry%20==0)
    { i2c_w8(TEMP_ADDR,0xFE); //reset
      temp_state=0;};
    if (temp_state==0)
    {  i2c_w8(TEMP_ADDR,0xF3);  //start measurement
      temp_state=1;}
    else temp_state=TinyWireM.requestFrom(TEMP_ADDR,2); //read temperature
    if(!temp_state)
    { uint16_t hi=TinyWireM.receive()<<8;
      hi+=TinyWireM.receive();
      temp=(int16_t)(0.026813*hi-468.5);
      temp_retry=0;
      return 0;
    else if(temp_retry>60)
    { temp=-999;
      temp_state=0;
      temp_retry=0;
      return 2;};
     return 1;
void show_tt()    //display actual temperature, set temperature and timing
{ lcd.setCursor(0,0);
  lcd.print((int)state);
  lcd.print(" T");
  show_val(temp,1,"");
  if (m_state[0])
  { lcd.print(" >");
    show_val(t_lim,1,"C");};
  if (m_state[1])
  { lcd.setCursor(2,1);
    lcd.print("t1");
    show_val(t_on,0,"m");};
  if (m_state[2])
    lcd.print("t2");
inline void set_state()     //swich state/ports according to temperature
{ if (temp <= t_lim) state=1;
  if (temp<=t_lim-t_hyst) state=2;
  else if (temp>=t_lim+t_hyst) state=0;
  //PORTB|=(PORTMASK&(state|state<<1));
void loop() {
  measure();
  show_tt();
  set_state();
  if(Enc_sw or Enc_turn)    //if user input
  { Enc_sw=0;
    if (pos_m<0)    //if display was off, display on
    {lcd.init(); lcd.backlight(); pos_m=0; }
    else if(Enc_turn)   //if encoder turned adjust temperatuer setting
      t_lim+=5*Enc_turn;
      Enc_turn=0;
    else                //if encoder pushed show menu
    { lcd.clear();
      while (1)
      { lcd.setCursor(3, 0);
        lcd.print(Menu[pos_m]); //show menu item in line 1
        lcd.setCursor(13, 0);
        if(pos_m>0 && pos_m<5)
        { if(m_state[pos_m-1] && pos_m<5) lcd.print(" On");   //show state of menu item
          else lcd.print("Off");}
        else lcd.print("   ");
        lcd.setCursor(3, 1);
        if(pos_m<menu_len-1) lcd.print(Menu[pos_m+1]);    //show menu item of line 2
        delay(100);
        if (Enc_sw)   //if pushbutton execute menuitem
        { Enc_sw=0;
          lcd.clear();
          if(pos_m==0) break;       //quit menu
          else if (pos_m<5)
             m_state[pos_m-1]^=1;   //toggle options (temp mode, time mode,...)
          else if(pos_m==5)
          { lcd.setCursor(13, 0);   //adjust hysteresis
            set_val(t_hyst,1,1,"C");
            if(t_hyst<0) t_hyst=-t_hyst;}
          Enc_turn=pos_m;
          lcd.clear();
        else      //if Enc_turn is out of limits (number of menu itims)
        { pos_m=Enc_turn;
          if (pos_m<0) pos_m=0;
          else if (pos_m>menu_len-1) pos_m=menu_len-1;
        Enc_turn=pos_m;
     if(millis()-t_activ>5000) break; //
      lcd.clear();
  delay(100);
  if(millis()-t_activ>20000) //backlight off if inactive
   { lcd.noBacklight();
     lcd.init();
     pos_m=-1;
This is worthy of refactoring:
  if (dec)
If you are just after the integers 1, 10, 100 etc. a lookup table or even switch-case could be shorter that pow().
blubbersprudel wrote:
...  to delete the bootloader ...
or an alternate bootloader :
Ralph's, 64B or 256B
TinySafeBoot, 550B
V-USB, 1418B
... or do you have any other ideas?
  • Try other AVR C compilers to squeeze (MPLAB XC8 AVR is an alternate AVR GCC, FSF AVR GCC v<something>, etc)
  • IAR EWAVR Kickstart though may be two 4KB applications (trampoline, function pointers, other?) or, if fortunate, bootloader+application
GitHub - nerdralph/picoboot: Automatically exported from code.google.com/p/picoboot
TinySafeBoot - A tiny, safe and flexible AVR-Bootloader for ATtinys and ATmegas
GitHub - micronucleus/micronucleus: ATTiny usb bootloader with a strong emphasis on bootloader compactness.
MPLAB- XC Compilers | Microchip Technology
IAR Embedded Workbench - AVR
edit : typo
Holy shit! replacing pow() saved more than 1K!cheeky
Wouldnt have thought that!
Thanks a lot!
int8_t rval,dec1=dec;
  uint8_t pot=1;
  while (dec1--)
  { val=val/10;
    pot*=10;
  rval=val%pot;
An alternat bootloader is a great idea also!
Didnt know they existed.surprise I certainly will look into it.
Thx.
Don't use floating point, and I would think you will save another big chunk, assuming nowhere else uses floating point now you got rid of the pow() function.
which compiler options do you use ?
try both -O2 and -Os
how big is the code (I assume it compile just with a size more than 100%).
in general don't use float,
0.026813
is close to :
7/256 = 0,02734375
or better
1757/65536 = 0,02680969
so first multiply with 7 and then div with 256 (which is nothing other than a offset of a byte).
(just make sure that the multiply don't overflow )
Nice!! another 800 Bytes. Thxlaugh
Und ich benutze die Arduino IDE, da hab ich bisher noch keine Compilereinstellungen gefunden.
I'm glad to hear that you freed up some more memory for your program.
I think, however, that the real learning point is this:
Start with a big micro when you start a new project!
It is very frustrating to have a project mostly done, and run out of memory, (or I/O Pins, or processor speed, or, or, or....).
If you are only building a few boards, then the cost difference is minimal, and it saves you running into this problem.
If you are going to manufacture a large number of boards, then after you have a working prototype you can begin to optimize the hardware, i.e. see if you can fit it into a less expensive (presumably smaller) micro.
If you are building an in-the-ear hearing aid, size matters.
If you are building a heating controller, size likely doesn't matter.
Good Luck with your project!
Absolutely!
Premature optimisation is a root of all kinds of evils.
come on the job OP need should take less than 2K of flash.
Is the next suggestion to start with a file system  and linux kernel, and therefor need 512K+ flash and about same amount of RAM before it can turn a LED on.
I like to not get too excessive, maybe allow a 2x factor for some elbow room....having too much room tends to lead to sloppiness..of course, I'm willing to admit, we might agree to say "who cares", the chip will just be $1.23 even if it is 10x of the space we need.
A company called me about some LCD menus they had developed & now needed to fix some bugs,  add additional menus,  and code new features to go with them.  They were already using 95% of the space & wanted to know if I'd take it on, select a new (bigger) chip & take care of everything.    I called a week later to let them know I had found & fixed their bugs.  They asked how the new chip selection was going & I told them I was able to reduce code space by almost 50%.  They asked if that might leave enough room to include all of the new things (and avoid a possible board update).  They were amazed to learn that all the new menus & features were already implemented & the whole thing took less than half of the code space they started with.
My current project is a 4 digit seven segment driver. Included in the code is a demo counter from 0 to 9999 , a delay loop plus a simple dimming control for the LEDs, timer1 for demo counter incrementing every 200ms or so, a 74hc595 for the segments. All of  this in 300 bytes...    So 8k  is huge, just depends on your overhead.  I use ASM only because I'm not smart enough to use C, but I do like the benefits.  The libraries (especially in arduino code for example) are convenient but large.  Just sayin... not trying to start a war
These days you need a Cortex M7 @600MHz to blink LEDs.
https://www.pjrc.com/store/teens...
I'd give students a schematic diagram with about 15 various gates & flip-flops & ask them to study what it did & build it up to verify.  I also mentioned that they should simplify wherever possible.  Most jumped right on it and soon had a breadboard overflowing with parts and connections.  The more thoughtful students were able to build it using only 2 wires and nothing else.   I think software often follows a similar path.
Are you using the Arduino IDE to do the compiles?   you've got setup() and loop(), but also utils/delay.cm si it's not obvious.
The Arduino libraries have gotten to the point where you need to have -ffunction-sections -fdata-sections -Wl,-gc-sections in your compile/link...
I am using Arduino IDE and after a lot of searching i found out were the compiler options arre hidden. ( [Arduino Install Dir]/hardware/arduino/avr/platform.txt )
Turns out the options you metioned are set by default.
Thanks for the hint though, learned something new again :-)
