Problem with .eeprom sections
4 posts / 0 new
Using Studio 7 on Windows:
Atmel Studio 7 (Version: 7.0.1931 - )
© 2015 Atmel Corp.
All rights reserved.
OS Version: Microsoft Windows NT 6.1.7601 Service Pack 1
Platform: Win32NT
Installed Packages: Shell VSIX manifest - 7.0
Shell VSIX manifest
Version: 7.0
Package GUID: e874ffe4-fbe3-4624-9a17-61014ede02d0
Company: Atmel Corporation
Installed Packages: Atmel Start - 1.0.161.0
Atmel Start
Version: 1.0.161.0
Package GUID: F8853255-9C7B-4DC2-8E0F-64D9324AEB0E
Company: Atmel
Installed Packages: Atmel Software Framework - 3.45.0.1425
ASF
Version: 3.45.0
Package GUID: 4CE20911-D794-4550-8B94-6C66A93228B8
Company: Atmel
HelpUrl: http://asf.atmel.com/3.45.0
Release Description: ASF - 3.45.0 Release
ASF
Version: 3.44.1
Company: Atmel
HelpUrl: http://asf.atmel.com/3.44.1
Release Description: ASF - 3.44.1 Release
ASF
Version: 3.44.0
Company: Atmel
HelpUrl: http://asf.atmel.com/3.44.0
Release Description: ASF - 3.44.0 Release
ASF
Version: 3.43.0
Company: Atmel
HelpUrl: http://asf.atmel.com/3.43.0
Release Description: ASF - 3.43.0 Release
ASF
Version: 3.42.0
Company: Atmel
HelpUrl: http://asf.atmel.com/3.42.0
Release Description: ASF - 3.42.0 Release
ASF
Version: 3.41.0
Company: Atmel
HelpUrl: http://asf.atmel.com/3.41.0
Release Description: ASF - 3.41.0 Release
ASF
Version: 3.40.0
Company: Atmel
HelpUrl: http://asf.atmel.com/3.40.0
Release Description: ASF - 3.40.0 Release
ASF
Version: 3.39.0
Company: Atmel
HelpUrl: http://asf.atmel.com/3.39.0
Release Description: ASF - 3.39.0 Release
ASF
Version: 3.38.0
Company: Atmel
HelpUrl: http://asf.atmel.com/3.38.0
Release Description: ASF - 3.38.0 Release
ASF
Version: 3.37
Company: Atmel
HelpUrl: http://asf.atmel.com/3.37
Release Description: ASF - 3.37 Release
Installed Packages: LiveWatch - 2.0.65
LiveWatch
Version: 2.0.65
Package GUID: 7DF6DCFD-2BCA-41C7-9C0E-1B7F606B008E
Company: Atmel
Installed Packages: GdbConsole - 7.0.188
GdbConsole
Version: 7.0.188
Package GUID: 49258291-0FED-4501-881B-6BAA91BEBCA8
Company: Atmel
Installed Packages: Atmel Kits - 7.0.122
Atmel Kits
Version: 7.0.122
Package GUID: 6F4B8FE4-C464-4916-8B43-AC92431C1CDF
Company: Atmel
Installed Packages: AtmelToolchainProvider - 7.0.895
Version: 7.0.895
Package GUID: AtmelToolchainProvider.Atmel.10EF9C74-D8DA-4872-85F5-D8BB3101E245
Company: Atmel
Installed Packages: Data Visualizer Extension - 2.20.735
Version: 2.20.735
Package GUID: 25dc067d-df31-4e22-be7f-cc6a77ccc7f3
Company: Atmel
Installed Packages: Microchip Gallery - 8.1.0
Microchip Gallery
Version: 8.1.0
Package GUID: AtmelStudio7ExtensionManager
Company: Microchip
Installed Packages: MemoryLogger - 7.0.1
MemoryLogger
Version: 7.0.1
Package GUID: A12E158F-08A0-48D9-B4DF-189B86C0AA02
Company: Atmel
Installed Packages: Visual Assist for Atmel Studio - 10.9.2093.2
Version: 10.9.2093.2
Package GUID: 7997A33C-B154-4b75-B2AC658CD58C9510
Company: Whole Tomato Software
Installed Packages: XFeatures - Beta - 1.6
XFeatures - Beta
Version: 1.6
Package GUID: 3ac9d6e9-a3dc-4a27-a048-f4bb7fe5889b
Company: Gramcha
Installed Packages: Data Size Viewer - 0.12
Data Size Viewer
Version: 0.12
Package GUID: 3e30bc56-2280-4652-ace4-c22cf8830515
Company: Dean Camera & Morten Olsen
Installed Packages: Terminal for Atmel Studio - 2.8.4
Version: 2.8.4
Package GUID: EFC4C002-63A3-4BB9-981F-0C1ACAF81E03
Company: Atmel
Installed Packages: FreeRTOS Viewer - 1.2.45.0
FreeRTOS Viewer
Version: 1.2.45.0
Package GUID: 98399DB5-40DF-467A-A9CB-3401A7090C88
Company: Atmel
Installed Packages: Doxygen Integrator - 7.0.1
Doxygen Integrator
Version: 7.0.1
Package GUID: 0CC72B7A-5750-4E23-90A8-70555D4FE154
Company: Atmel
Processor is ATTiny404.
I have two arrays in eeprom (to save precious RAM)
This version worked fine:
const TProgmemRGBPalette16 RainbowColors_p[16] EEMEM =
  static_cast <HTMLColorCode_t> (0xFF0000),
#define MAXOF2TABLELEN  24
const uint8_t MaxOf2Table [MAXOF2TABLELEN] EEMEM = {
  0x01,
No problems.
In a second version of the code I modified this to
#define CHASEPATTERNLEN  NUM_OF_DRIVERS*LP5036_NUM_LEDs
const ChasePair_t ChasePatTable [CHASEPATTERNLEN] EEMEM  =
	  {0, 2},
Where the second table is now a table of structures, each of which has two elements. Ok, it compiles fine but I get the dreaded
" RainbowColors_p causes a section type conflict with ChasePatTable "
Ok, so I look around for solutions for this, but there appears to be nothing better than modifying the linker script.
So, after much research to find out where the default linker script is, where to put a custom script, and how to properly modify it:
const TProgmemRGBPalette16 RainbowColors_p[16] __attribute__((section("eepromT1"))) =
const ChasePair_t ChasePatTable [CHASEPATTERNLEN] __attribute__((section("eepromT2"))) =
	  {0, 2},
with a slight modification to the avrxmega3.xn file (now in the \release directory, and properly pointed to with a linker -T command)
  .eeprom  :
    /* See .data above...  */
	*(eepromT1)
	KEEP(*(eepromT1))
	*(eepromT2)
	KEEP(*(eepromT2))
    KEEP(*(.eeprom*))
     __eeprom_end = . ;
  }  > eeprom
But now, the linker stubbornly refuses to put the first array, section eepromT1, into .eeprom!
The .map file shows:
.eeprom         0x00810000       0x30
 *(eepromT1)
 *(eepromT1)
 *(eepromT2)
 eepromT2       0x00810000       0x30 V3_LED_PatternGenerator.o      << The second array properly goes into .eeprom
 *(eepromT2)
 *(.eeprom*)
                0x00810030                __eeprom_end = .
and it puts the first array into the .data section
 *(.progmem*)
 .progmem.data  0x00000058       0x40 V3_LED_PatternGenerator.o
                0x00000058                RainbowColors_p
                0x00000098                . = ALIGN (0x2)
Any suggestions would be greatly appreciated.
You sure .xn not just simply .x is used by default?
I have -verbose on the linker, and it says that it's using that one.
If you name your sections .eeprom.T1 and .eeprom.T2 then I think they should be picked up by the .eeprom* pattern in the linker script...
:: Morten
