I implemented this application note to measure Vcc http://ww1.microchip.com/downloads/en/AppNotes/00002447A.pdf however I need to use 10bit resolution to be able to use it. If I use 8 bits resolution there are voltage levels where ADC doesn't change the ADC0.RES value and I can't understand why this happens.
Thank you
