SAMD21 SPI
7 posts / 0 new
I am trying to set up SPI data transfer between 2 SAMD21s on different boards. One acts as master and other as slave.
Created both projects using Atmel Start ( ASF4) and here is the code snippet.
Both are fed with generic clock of 24 MHz and selected a baudrate of 80000 in Atmel start.
Master
Config
    spi_m_sync_get_io_descriptor(&SPI_2, &io);
    spi_m_sync_enable(&SPI_2);
    spi_m_sync_set_mode(&SPI_2, SPI_MODE_0);
Send Data in Loop
static uint8_t buffer_tx_byte[1] = {0xAA};
static uint8_t buffer_rx_byte[1] = {0x00};
void sendReceive() {
    //Enable SS
    int32_t status = io_write(io, buffer_tx_byte, 1);
    delay_ms(20);
    memset(buffer_rx_byte,0x00,1);
    io_read(io, buffer_rx_byte, 1);
    //Disable CS pin
Slave
Config
    spi_s_sync_get_io_descriptor(&SPI_0, &io);
    spi_s_sync_enable(&SPI_0);
    spi_s_sync_set_mode(&SPI_0, SPI_MODE_0);
Data send/rcv loop
static uint8_t buf_tx_byte[1] = {0xAA};
static uint8_t buf_data_byte[1];
void spiReadWrite() {
    memset(buf_data_byte,0x00,1);
    int32_t status = io_read(io, buf_data_byte, 1);
    delay_ms(10);
    io_write(io, buf_tx_byte , 1);
Both at master and slave IO_READ returns status 1 , indicating 1 byte read successfully.
But when i print them , Slave always prints FF ( probably empty) , Master prints 7F.
Could any one help with this ?
Get yourself a logic analyser. Can be got for < $10usd of aliexpress and elsewhere.
Thanks. I managed to get one and here is how the signals look.
I am sending a byte (0xCD) from master. MOSI shows it correctly.
Current baud rate is 9600. I also tried 20000/80000 and different clock frequencies from 1MHz-24MHz.
Both master and slave are configured to SPI Mode 0 ( CPOL - 0, CPHA - 0 )
Slave receives the data and sends it out. It is on MISO and is wrong most of the time. (It works occasionally and reads CD though).
Not sure what you expect but if you need the more typical SPI bidirectional transfer then calling the spi_m_sync_transfer function directly will work better than io_write/io_read.
/Lars
Do you see anything wrong with the way i read or slave configuration. The transmitted "0xCD" seems to be read as "9B" , "0x DD" etc.
If I have to guess then the slave has a different SPI mode, i.e., in start under the SPI advanced config "Clock Polarity" and/or "Clock Phase" is different.
/Lars
Thanks. I did figure it out. Advanced Configuration for Slave had clock phase 1 selected by default. I thought setting SPI mode to 0 in code will change it. But it wasn't the case.
