ATXmega E-series ADC settings.
4 posts / 0 new
Hi everyone.
First, I have been using Mega/Tiny devices for many years but now I'd like to start using ATXmega devices E -series. But I don't know how to set the ADC to make it working automatically (triggered by event system chanel 0).
Question are:
- what do we use the bit FLUSH for?
- which bits should we set within EVCTRL register to have the ADC triggered by event system - only  EVSEL  or/and EVACT?
Thank you in advance. robiw
Could you check my settings:
//ADC config: 12bit single ended, curr limit high, ref = 1V, gain = x1, trigger - event ch0
ADCA.CTRLA = ADC_ENABLE_bm;  //ADC Enabled
ADCA.CTRLB = ADC_CURRLIMIT_HIGH_gc|ADC_RESOLUTION_12BIT_gc;
ADCA.REFCTRL = ADC_REFSEL_INT1V_gc;
ADCA.EVCTRL = ADC_EVSEL_0_gc|ADC_EVACT_CH0_gc;  //First event triggers channel conversion
ADCA.PRESCALER = ADC_PRESCALER_DIV64_gc;  //500kHz @ 32MHz
ADCA.CH0.CTRL = ADC_CH_GAIN_1X_gc|ADC_CH_INPUTMODE_SINGLEENDED_gc;
ADCA.CH0.MUXCTRL = ADC_CH_MUXPOS_PIN0_gc;  //pin PA0
robiw
There are six ADC app notes:
Could you check my ADC settings above. robiw
