Creating an Arcade gaming console from scratch (AVR / C & C++)
66 posts / 0 new
Hello everyone. Long time lurker here! I'm on my senior year at college and, in one subject, I have to create a working prototype of something (literelly anything, going from a capsule dispensor, to a AGV, to a working solar panel circuit, etc.). I got really interested in some projects (since it's basically the reason why I applied to this degree in the first place) and decided to go with a gaming console (my second choice was the AGV - Automated Guided Vehicle - but I figured that it would be more expensive and harder to understand - by this I mean I don't really have a clear idea of where to start or what to do - than the console).
With this, a gaming console is something I'm really hyped to build. I made a quick research in order to see if someone had already thought about this and found lots of information on this topic (my first step in this project is to write a research paper aka State of the Art and talk about similar projects and working prototypes).
Apart from that, my biggest "issue" is creating the project itself (not to mention the creation of PCB's and the working prototype). For my research paper, I'll write about a gaming console named MakerBuino by CircuitMess since this whole project is inspired on that.
From what I could tell, everything is open source since the company itself promotes a DIY approach from students (aswell as offering a purchasable console through their website). With this, I'm not going to copy everything and simply build it together. My idea is to code everything myself (I have no idea whether that's possible or not) and inspire my working prototype design on the MakerBuino one (I loved it!).
I would like to note that in order to build a MakerBuino, the company provides the PCB schematics as well as the console bootloader. I can't use the bootloader since it's something I didn't code. My idea would be to create a simple program (i.e. starting with a switch/case menu to alternate between games that, later on, I would code [I REALLY don't think creating games like Snake / Space Invaders / Tetris is something hard given that there are LOTS of examples in the internet but I could be massively wrong]).
After having the code ready, my idea would be to sketch my PCB's according to the MakerBuino ones (after understanding its' circuit and usage of components) and create the console itself. If what I said earlier (about beeing simple to code a switch/case menu with games) is true, I guess that my biggest issue (coding wise) is to make all this work in a monitor (it can be a computer monitor, a small LCD display, etc... MakerBuino uses a Nokia 5110 LCD).
I would also like to say that even though this my last college year, I'm by no means an expert in programming / creating circuits. I've never messed with PCB's nor created a working prototype like this. I mainly learn C at college though C++ isn't really that much different. I retained some HTML programming skills as well. Important to state that this whole project must run / use an ATMega (must also have a blinking LED - which is easily coded).
Would love some insight on how to start a big project like this and I'm all ears to ideas / suggestions about this or the above mentioned projects.
Note: Besides MakerBuino, I've also found a series of videos on how to create a gaming console (it only has one game from what I can see) on youtube. Part 1 link is here. There's a total of 4 parts. I have no idea if this the right approach / a different one than the one I talked about earlier. Worth nothing this was coded on C++.
Edit1:  I'm due to deliver this project on the first week of January. Besides that, when I say "gaming console" I'm talking about an Arcade Console to play simple games like Snake or Tetris. Nothing particularly pretty or in need of 3D graphics.
Welcome to the Forum.
What a great project.
I'll share a few thoughts, I'm sure others will pitch in.
1)  Make it doable within the timeframe and experience level you have.
2)  A Nokia 5110 is a great little display, and is easily interfaced to a Mega or Xmega.  There are plenty of libraries for writing to it, or you can write your own driver, which is in and of itself a reasonable undertaking.
3)  I would suggest you focus on making a one game console at the moment.  (See #1, above).
The micro has a limited amount of memory, it isn't a PC or an ARM.  So if you were to have multiple games one would need a method to load them off an SD card, (or whatever), and that is an entirely  new level of complexity if you don't have a lot of micro projects already under your belt.  "Loading" a new game is itself open to several different approaches, and again some would not be trivial.
4)  Once you have your project, single game version, up and running, then if you have additional time you can write a second game.  Then think about loading it on a second board, or think about project Version #2, and how to approach multiple games.
5)  Hardware wise you will need your GLCD and user interface buttons, (up/down/left/right/fire, etc.).
One can use individual push button switches, or one can use mini-"joystick" push button switches, (five function, directional and push).  Don't mess with trying to interface to a USB driven controller, that is itself another non-trivial task.
6)  Pick a really big (pins and memory) micro.  Interfacing to the GLCD (Nokia 5110), multiple PB Switches, and a piezo beeper, and an LED or two or three, and whatever else gets added, will be much easier when you are not I/O pin constrained.  Likewise, you wants lots of memory.
7)  You might consider using an Arduino for your base hardware platform, if allowable.  You can still program it in any language you wish.  If you decide to go with your own circuit design and PCB, (both good learning experiences), you can certainly post your schematic here for lots of input before you get a board made.
8)  Good luck with your project!
Hi there. Thanks a lot for quick and helpful response!
 Will do! Is starting with a menu and coding a game (in C) the right approach (like explained in the OP)?
Already searched ebay / gearbest / amazon and found lots of components for pennies. My idea was to use individual PB switches rather than the joystick. Simpler (for me) to understand.
Any suggestions? I've only worked with versions 88, 128 and 328 of the ATMega component. Don't recall every datasheet but I have the idea that the 328 is faster (clock speed) and has more memory than the others. Nonetheless, there are thousands of versions that I don't know anything about.
  a piezo beeper
I forgot to add this since that would elevate the project into a new level. It's a really great idea though I'm not sure how to play audio with a C code (I guess that's something easily explained in 1 or 2 youtube videos).
I own an Arduino but I don't understand what you meant by this (probably translation issues). If you're talking about using the ARDUINO chip instead of the ATMega one, I can't since Arduino has already developed multiple functions that I can't use (i.e., in arduino I can read an analog value with a simple function, while in ATMega we don't do that that way). (At least, by talking to my teacher, this is what I understood... Arduino is allowable ONLY if you code the functions yourself).
If you're talking about the board itself, I also have the board with all its' pins (Arduino UNO).
This is an ambitious project, but if you break it down and tackle each part it is doable.
I would use an Arduino mega, as it gives you plenty of flash and ram, you will need it for the graphics!
find a display shield and your hardware is mostly complete, just add your buttons and speaker/ buzzer.
although you can not use Arduino libs for your final project, there is no problem using it to test your hardware and connections, this will remove much work and troubleshooting, as any problems will be in your code.
As suggested, pick one game, keep it simple, you can always expand if time permits.
come back here if you get stuck.
good luck
jim
jona_ wrote:
I guess that my biggest issue (coding wise) is to make all this work in a monitor (it can be a computer monitor, ... Important to state that this whole project must run / use an ATMega ...
May you consider XMEGA?
XMega cranks out NTSC color and digital stereo sound! | AVR Freaks by AtomicZombie
jona_ wrote:
I've never messed with PCB's ...
Some universities have some form of PCB fab; likewise, Makerspaces and some city libraries.
jona_ wrote:
... nor created a working prototype like this.
The first prototype is the first PCBA; its precursor is a proof-of-concept (PoC, iow a bench test)
PoC is off-the-shelf parts patched together; PoC is one way to do risk reduction.
jona_ wrote:
I mainly learn C at college ...
Excellent and thank you!
jona_ wrote:
... though C++ isn't really that much different.
Turing completeness is a characteristic of part of C++.
AVR metaprogramming (C++, article) | AVR Freaks
Learning C and C++ can begin in secondary education via a C/C++ interpreter, course work, and a course plan.
UC Davis Center for Integrated Computing and STEM Education
UC - University of California
Hi! Thanks for the quick reply.
I searched for shields on the internet like you mentioned but there are many models and they're all different. Mind linking a basic one or telling me what should I keep an eye on to differentiate each of them?
What's the difference between using an ATMega on a breadboard or, in this example, an Arduino Mega? What connections are you talking about?
From what I know, XMEGA's are more complete ports/pin wise. Besides that, is there a lot of difference programming ATMegas and XMEGAS? In terms of programming ports and creating loops / interrupts / messing with timers.
Exactly. Mine builds costum PCB's with the schematics we need. I've also seen some online stores (mainly one named JLCPCB, not sure what's the difference between ordering from them or ordering in my local college though).
Alright this is great! Thanks for specifying the different stages of the project. Will help me a lot with scheduling and knowing what to do within the time frame. It's also great since I'll need to make an article on the final prototype and I can now call the different prototypes by their actual name!
Thank you!
I can’t recommend a display as I don’t know your gaming system specs!!
As for the diff between proven hardware ( Arduino Mega) and a bare chip on a bread board, night and day.
what is your degree of study?   hardware EE, or software CS?  Are you developing your hw design skills, or software dev skills?  If the latter, then using proven hw, ie Arduino mega with a compatible display shield gives you a working platform to start with, if the former, then study the proven design of the Arduino such as a Nano as the basis to start your journey.
jim
Right. Dumb question, sorry.
 I'm studying Electrotechnical Engineering which I'm not entirely sure that it's the same as EE. Nonetheless, it's something similar. Besides that, the course / degree is more oriented towards software rather than hardware. It's a mix of both given that I have to create both programs AND physical circuits. Perhaps that's the reason why I don't know in depth characteristic about certain things.
Suggest you discuss your wants with you professor, they can guide you to resources you will need for your project. Remember the ram size on an AVR is limited so a graphics display will be small, you can’t do 1024 x 4096 w/ 1M colors, do some Google  searching for similar projects, see what they used, download it and take it apart to see how they did it to get ideas on how your project can work, research can be fun!
Will do. Thanks a lot for your suggestions. I'll update later on this month but you've helped me massively. Cheers laugh
... and compute and memory and power (bounds : compute, memory, I/O, power)
XMEGA :
  • 32MHz CPU frequency (vs 20MHz)
  • 32KB local RAM (XMEGA384C3, XMEGA384D3 vs 16KB in mega1284P)
  • 24b addressing in program and data spaces
  • DMA (most XMEGA)
  • PicoPower is shared with P, PA, and PB megaAVR
jona_ wrote:
... is there a lot of difference programming ATMegas and XMEGAS?
Yes
jona_ wrote:
... not sure what's the difference between ordering from them or ordering in my local college though).
Regional PCB fabs typically have discounts for students.
A university's PCB fab may be zero price or very low price for students, faculty, and staff.
AN_8075 AVR1000: Getting Started Writing C-code for XMEGA via ATxmega384C3 - 8-bit AVR Microcontrollers
Universities have access to zero price IC (die fab, die packaging)
A university student can design and test a zero price IC.
MOSIS Integrated Circuit Fabrication Service | University Support Program
Alright. I'll discuss with my teacher whether or not using XMEGA's is a good idea given that, if programming is a lot different, I might not have the time to finish everything / will take longer to write my code since it won't be that simple.
Thank you for the suggestions. I'll update later on this month!
Gaming might not be the best thing to jump right into...depending on graphics...are you a graphics programmer? There's a lot to generating real-time graphics, also the processing memory needs, speed, working with displays in general & the game itself add up to quite an effort.  Do you need 3D effects? This would all be a tough job, even if you already had a lot of programming ,experience, display experience, etc.  This is not to scare you off, just realize that if you are creating your OWN software, then it is much tougher than making a burglar alarm, or automatic bird feeder. How much real time to you have to spend?  You may regret when you only have 2 days left & little to show.
Rule of thumb: Do something you think will take 2 weeks "if all goes well", then double that...if it is something you've never done even once, double it again!
That certainly is good for getting started
I should have said this in the main post, will edit it now.
I'm due to deliver this project on the first week of January. Besides that, when I say "gaming console" I'm talking about an Arcade Console to play simple games like Snake or Tetris. Nothing particularly pretty or in need of 3D graphics,
Yeah, this doesn't leave much time. I'd go for pong or snake, they are the simplest games I know.
Pong would be the simplest, I think. The controls would just be 2 potentiometers and one or two buttons, the display just needs a function to draw rectangles.
Regarding the display, apart from the Nokia 5110 there are also 128x64 graphic LCDs that are more or less standard. They have a parallel interface which is faster, maybe useful for games that need a fluid display refresh.
Not to knock pong, but maybe time to get creative .....make an automated can crusher...people will like that!  Or an arm-wrestling machine (basic motor-torque control) they can compete against.  If someone comes up and shows me a pong game, I might do a lot of yawning, if I didn't appreciate all the effort it takes to implement.
Keep it simple.
You're making a class project, to show what you have learned, and that you can apply it.
You aren't trying to sell a million of them.
The 5110 is a great little display, certainly adequate for a simple Snake or Pong game.
Yet it won't take up too much memory for a memory mapped array.
Remember you can write to the Nokia 5110, but you can't read back from it.
So one would generally keep a "copy" of the display in memory, update that, and then have a routine that writes the memory array to the GLCD.
Think small, and accomplish the task.
You can come back another day and do version 2 with upgraded features.
Edit: Typo
Will search and compare both displays. Thanks
 I really don't know whether or not a car crusher would be accepted as a project. Besides, I have no idea how it works or where to start :P. The arm wrestling machine looks fun. While I agree with you that making a Pong / Snake console is something common and not very breath taking, arm wrestling might be a little tough to do at this moment (according to my skills), no?
That's my plan. Showing the game to the LCD might be the last thing I'm gonna do since coding everything else might take a little while. It will all end up in the same place anyways. I'm already bookmarking some other projects / threads displayed in other avrfreaks sub-forums so I can backup my work!
Hey once again.
After having finished my SOA work I'm now focusing my time on building the project itself. I found lots of projects but decided to only follow "study" from what was done already 3 or 4 projects (1234).
I'm yet to decide what ATMega to choose but I'm leaning towards the ATMega32 version (will also use an external oscilator given that most of the projects require either 8 or 16Mhz speed because of the display).
Besides that, I'm having trouble actually starting the project. My idea is to start by interfacing a display with my ATMega32. Then again, I'm still unsure whether to choose an LCD - 16x2 - or a LED Matrix - something bigger. Since the game is Snake (for now, only 1 game), a 16x2 LCD display is probably a bad choice given that I would only have 2 rows / 16 columns to move (while talking to my teacher, he told me that we could code EACH pixel inside 1 character - i.e., in a 16x2 LCD with 50 pixels p/ character, I could code each pixel of each character - therefore having more resolution. The problem is that it seems way too hard and I really don't understand it well / not intuitive for me).
Given this, a X * Y led matrix will probably be our main choice (we're thinking about having something like 16x8).
My problem right now is how to actually code the matrix (and which one to choose as there are SO SO SO SO SO MANY and every project has a different kind of matrix with different sizes or manufacturers). Every project makes use of pre built libraries (not official ones but rather some created by somebody). I can't simply use them as I need to code them by myself (I can't just present something made by a guy across the world and explain it since it's something I should code - even though it's something I've never done).
I just feel lost on how to start this or what to do. Everything seems so hard to implement and the more I search the more confused it seems (since there are thousands of projects with thousands of atmega / displays / games / size of displays combinations).
Ok, so basically you are going for project number 2 on your list. I think it's a good choice, because using a LED matrix you will have total control over the display, that is, you need to write everything.
Learning about multiplexing, display memory and stuff like that is important. For this, you should buy LED matrices that do not come with a controller, this way you will need to implement the control stuff yourself using the ATMega.
Instead of a 16x8 display, it will be cheaper for sure to get 2x 8x8 LED matrices.
You will need a MCU with plenty of pins, so I guess a 40 pin DIP like the Mega32 is ok. If you want to be adventurous and try out the new generation of MCUs, the Mega4809 also comes in a 40 pin DIP version. But in this case I guess you should stick to the mega32, there is much more info.
Soon, you will discover that the MCU can't handle the necessary current for the display. The chip you will need is the ULN2803A.
Your display setup would be something like this, but with 16 columns instead of 5 (adapted from https://www.mikrocontroller.net/...):
Here you will drive each row , one -by-one
Careful with wording.....where do you thing the current comes from? (why its... the AVR). At least using the ULNxxxx cuts the return current (so chip heating cut in half).  A single AVR pin would't like the total return current from 5 leds (especially if they are old school 15ma types), so the ULN really helps out.
Alright. Most of the LED Matrix I see in local stores don't come with any datasheet attached so I can't really write which model I'm planning on buying. Anyways, here are some links: 1 2 3. Those don't come with any controller I suppose, so any of them should work (?).
We thought about this aswell. What drove us away was the fact that we thought it would be harder to code 2x8 matrix instead of a 1x16 one (given that, in the game Snake i.e., we would need to constantly send data to BOTH the matrix). Nonetheless, if that's your suggestion, I will happily take it!
We noticed that (the fact that we needed lots of pins), that's why we didn't choose our default ATMega328p and instead went with the 32 version.
Will search about it tomorrow. Had no idea about that!
About the image, how do I connect 16 data lines to the ATMega32 (given that I don't have those much pins)?
Also, I asked my teacher about a protocol named SPI (in order to connect the display to the ATMega, many projects referenced the use of this protocol). What he told me was that I could use the SPI library if I know what the code does (since I need to explain and present the work to my class, I will need to explain each line in case someone has any doubt). With this, he also told me that he would not take this part of the code into account when giving us our grade (it basically counts for nothing). I'm still unsure if that's bad or if it doesn't matter much. Any way of getting around that (from what I read / heard, creating an SPI protocol by myself isn't something THAT easy).
Option 1 is charlieplexed, this is a somewhat complex scheme so you better avoid it. Option 3 is RGB, again, not the best choice for you. I'd go with option 2, which is pretty standard.
What do you mean?  I think there are enough pins. You need 16 + 8 pins total for display control. There are still 8 more left for other things, like control buttons and UART interface if needed. If you load a bootloader on the chip, the UART can also be used to upload firmware.
I thought that I could only connect my display to the ADC pins on the ATMega (every project I've seen connects it this way so I thought that it was needed). With this, can I simply connect the 24 pins needed in any ATMega Pin I want? (besides the ones in which I'll place my external oscilator, vcc, aref, etc,etc)
The most famous implementation of "snake" ever was almost undoubtedly:
You scan still get those Nokia displays and they are fairly easy to interface to AVRs:
https://www.dharmanitech.com/2008/09/nokia-3310-lcd-interfacing-with-atmega8.html
https://learn.adafruit.com/nokia-5110-3310-monochrome-lcd
Well, not exactly, you need to respect the current limits indicated in the datasheet, since the AVR is sourcing all the current. The current then sinks through the ULN chip, which can handle lots of current, so that shouldn't be a problem.
For example, if each LED needs 10mA, you may need a maximum of 160mA (only one row is on at any moment in the multiplexing scheme). This is within the total limit (200mA), but you need to source half from port A and the other half from one of ports B, C or D to be within the 100mA port group limit.
edit: in practice, there will be problems with voltage drops on the AVR and ULN pins possibly causing uneven LED brightness. These are real world problems that I think you, as a student, need to experience yourself, that's how humans learn best. Analysing these kind of things will also help to beef up your report later and maybe get a better gradewink.
Just to noted that the Nokia 3310 display is 84x84 pixels. It looks like in the game there is a bit of a border so maybe call the active area 80x80 then the snake/etc are about 4 pixels wide so reduce that by /4 and the active area is 20x20. I do wonder if 16x8 (done as LED) will be enough "pixels" ?
I've seen multiple projects using the Nokia 5510 display (I think one of them was linked in my previous response) but I kinda forgot it as I didn't find any datasheets / thought the LED Matrix was easier to code. It can also be a solution though!
 Got it, that makes sense. I'll have to pay attention to both the micro and the LCD datasheet and figure that out before actually building the IRL project. Thanks a lot for the simple explanation!
Agreed. Will take that into consideration while building the project and making the actual work afterwards.
Thanks a lot!
 Not sure whether or not it's enough. The idea (if I choose to go with the LED matrix) will be to implement a 16x16 matrix (2* 8x8 LED Matrix) or one 16x16. Otherwise, like others suggested, I could use a nokia 5510 (or another model like you mentioned) and figure that out then.
Worst part about this kindof project is when you're finished and proudly show it to somebody, and they say, "so," or "lousy graphics."
Update:
After buying my microcontroller (ATMega32) and some other components I was missing, I'm now at this stage (Image 1):
  • Created a simple voltage regulator circuit (since I have a 12V battery, I'm using a LM7805 voltage regulator in order to supply 5V to my micro).
  • Added a 10Mhz crystal in order to get more accurate time measurements. This means that TimerCounters / Interrupts will be more precise.
With this, I still haven't connected my LED Matrix. I'm going to use 4x(5*8) Led Matrix (TA16-11GWA by Kingbright). Read the datasheet and understood what was needed in order for each LED to work.
Given this, my idea is to connect all 4x14 pins (there are 14 pins in each Led Matrix) to my ATMega32 (with the help of 4x[14*1k] resistors in order to protect the matrix). I would then set each pin to a high level (no LED is turned on given that there's no voltage drop between the anode and the cathode of the LED). With this, whenever I want to turn a specific LED on, I would simply need to set the respective cathode pin to 0 (low). I'm still brainstorming on how to do this but my idea is to create a function which recieves, by parameters, the number of the line and the column of that specific LED. With this, I would know which led is it and set the pins in order to turn it on / off.
Is something like this a good approach or am I on a constant stupidity loop?
This seems really confusing and I'm not even thinking on how to build the game yet.. Just interfacing the matrix lol.
One question as well:
Given that I'll be using an external 10 Mhz crystal, do I need to turn off my micro's internal oscillator / mess with its' fuses?
EDIT1: Thinking about it, I can't even connect 4*14 pins to my ATMega32. Am I beeing stupid or is it really impossible to connect 4 matrix to this ATMega (given the number of pins avaliable)? Can stick with just 2 led matrix if needed.
An Atmega32 in 2019? You may find a (pin compatible) ATmega324P is a "nicer" chip to work with - moer bells and whistles which were added in the many years since mega32.
Bough this micro because of the number of pins tbh. I really don't know much about each micro besides the basic features like memory, speed, pins, etc...
Would the 324P be a massive improvement over this? I have some on school (can rent them basically). Sad that I bought this one online though
The 324P has some nice features. Of particular interest if you have any plans to make this battery powered is the P in 324P. That means "Picopower" and indicates the chip has added goodies to aid in lowering power consumption making it perfect for battery use. It is a 32 pin DIP like the mega32 is.
But if you already have the 32 then I guess just persevere with that - if, however you later "grow out of it" (that can happen in things like games machines!) then you could still switch over the 324P and what's particularly nice about it is that there's also 644P and 1284P "above" it. So if you run out of flash (or perhaps more likely RAM) then you would have the chance to trade up to 644P or the monster 1284P which, until recently, was the only AVR8 with 16K of SRAM.
Got it. Will take that into account and if needed, I'll make the switch. Beeing fully compatible is a big plus in this scenario. Thanks for the suggestion!
You need to understand how multiplexing works, maybe it would be a good idea to ask help from your teacher/supervisor about that.
So, if you look at that datasheet, actually, all the "Rx" pins of the 4 LED matrices may be connected together (that is, all the "R1" have a single line, all the "R2" another line, etc) so you just need 8 MCU pins for that (via the ULN2803A don't forget it!), plus 20 MCU pins to connect the "C" pins on the matrices (via current limiting resistors!).
edit: it is said, a picture is worth a thousand words, so:
El Tangas wrote:
You need to understand how multiplexing works ... a picture is worth a thousand words
Here's one I prepared earlier:
http://www.8052mcu.com/forum/read/142043
EDIT
now with animation
Oh alright. That makes sense. I had one subject in which we talked about multiplexing and such but to be honest, it was one of my least favourite subject (I was also struggling to get a decent grade at it) and I haven't used any of that for 2 years now.
Anyways, I understood what you meant and the picture helped a lot.
I will design the circuit with the 4 matrix + the ULN and build it IRL and then proceed to code.
When I first studied micros, I had an atmega board with a 7 segment display just like that. I controlled all 4 digits and I never knew how it was wired/connected on the inside. I guess I now know.
Thanks for clearing it up and helping me understand how multiplexing / interfacing these kind of displays works.
How could you have written software to drive it without knowing the layout? Or are you saying it just came with some pre-made display_7seg(...) or similar that you just called without knowing what was going on inside?
The key thing about multiplexing (esp if not current limiting) is often "never stop" ! If you don't keep hopping from one to the next and only illuminating each for a short time (essentially "PWM") then you can stop with one fixed  pattern that sucks huge current and lets the smoke dragon out of its cave !
When I had that subject, everything was already built. Everything was connected inside so all we had to do was code the pins. I attatched an image so you could understand what I was dealing with. The teacher would ask us to make a led blink or things like that so we would only have to worry about coding. Wiring, building and interfacing the ATMega + the components was already done.
To be honest, it was hard at first because I had never coded anything like that but I would have prefered to know how to wire a micro with other components (i.e., the 7 segment display, a buzzer, etc.) since it would have helped me massively at the moment. Nonetheless, I try my best to study and understand it alone.
Will pay attention while doing the routines / using the interruptions. Thank you!
Jonaas18 wrote:
(...) and then proceed to code
Remember that the game logic and the hardware control are 2 separate things, and should be separated in code (in different files). The "Snake" game consists just of reading inputs and drawing and erasing snake segments and "snake food" as needed. In this case, they are just LED dots, but you should write the game logic separately as if you don't know what is the underlying hardware.
The game should only use functions like draw_segment(), draw_ food() or something general like that, so that it can be plugged in to a variety of hardware.
The hardware part should provide functions like set_pixel(), clear_pixel(), get_screen_x_size() and stuff like that, while handling all the screen related stuff in a more or less invisible way (to the game logic section), so that it could be use by other application instead of the "Snake" game.
Then, all that is left is writing the "middle", that is, implementing for example draw_ food() which in this case is just set_pixel().
You should get used to writing code like this, because of maintainability and code reuse.
That means, for example, creating a LED.c file in order to interface the matrix with the atmega and such + a Snake.C in which I code the actual game itself, right?
I was planning on starting by creating the LED.c file, that means, interfacing the display and the micro.
That is always true of learning any new skill!
By definition, if it's a new skill - then you haven't done it before!
This is why it's important to start with the basics, lay good foundations, practice, etc to build up your skills - rather than just leaping into some over-ambitious project.
Sure. That's the obvious starting point and it's fine. I was just pointing out that you could start at either end. For example, if this was a team, each person could be working on a different section.
I was designing my schematic (in order to build the circuit properly IRL afterwards) and I got stuck. When you suggest connecting the 8 Rx pins (matrix rows) from the LED Matrix to the ULN chip and then to the MCU, do you mean:
  • Connecting 8 MCU pins to 8 ULN2803 inputs (1B, 2B, 3B, 4B, 5B, 6B, 7B, 8B); then connect 8 ULN2803 outputs (1C, 2C, 3C, 4C, 5C, 6C, 7C, 8C) to the 8 Led Matrix's pins.
  • Connecting 8 MCU pins to 8 ULN2803 outputs (1C, 2C, 3C, 4C, 5C, 6C, 7C, 8C); then connect 8 ULN2803 inputs (1B, 2B, 3B, 4B, 5B, 6B, 7B, 8B) to the 8 Led Matrix's pins.
In my head, it makes sense to connect the MCU pins to the ULN chip (in order to amplify and stabilize the current) and only then connect it to the matrix. At least that's what I understood when you first suggested the use of the chip (~a month ago). However, by the image you sent, it says "To driver chip, then to MCU", which makes it seem like I would connect the matrix pins on the input pins of the ULN chip and only then connect it to the MCU.
This one, of course. Sorry if I mislead you.
No, all fine. All you're doing is helping!
Worth mentioning that I'll be using 3 matrix instead of 4 (23 pins vs 28 pins). Doing this because I still want to connect a joystick (or push buttons) + I have to have a blinking LED as a requirement to this project. If I use 4 matrixs, I'll only have 1 or 2 free pins.
Considering what was suggested before (and hoping I didn't make any errors), this is the general schematic of the whole circuit:
I'm still missing connecting the required LED (for blinking purposes) and the push buttons / joystick in order to control the menus / ingame movements. Besides that, I think that everything else required is already connected.
If you are using 3 matrices, then that's 15 "C" pins, you can connect using just 2 ports. Trust me, it will make life easier later. I suggest you use PA and PB.
edit: that's because you image data can then be an array of 8 uint16_t integers (each represents one line), and you can just copy that to PA and PB without much processing.
But if I connect all of them to portA I would "lose" my ADC (I'm not sure if I need it for the joystick but still). As for portB, I'll be using the USBasp in order to transfer the code into the ATMega. Can I still use those ports for circuitry? (Kind of a dumb question but to be honest my first time using usbasp was barely 2 months ago).
Ok. What kind of joystick do you want to use? I will admit my knowledge of joystics is zero.
I haven't decided yet (if I'm going for the simple push buttons or the joystick). Nonetheless, I'm not at home so I can't really link the one I saw. If, i.e., I would choose to go with push buttons (up, down, left, right), wouldn't need the adc right?
Alright. As for the other pins (MOSI, MISO, etc..) can I still use them for circuitry (given that I'll need them in order to connect my usbasp)? I've seen projects where these pins have nothing connected (which I'm not sure if it's because of this issue or if it was a simple coincidence) while others use them for circuitry (though most of them don't even show how they programmed the micro).
Yes
ATmega32A Datasheet
[page 269]
27.8 SPI Serial Downloading
Both the Flash and EEPROM memory arrays can be programmed using the serial SPI bus while RESET is pulled to GND. The serial interface consists of pins SCK, MOSI (input), and MISO (output). ...
Having connected everything on the same port (using PA and PB for the LED Matrix columns), I now have the following circuit:
I also connected 4 push buttons in order to control the game (though the usage of a joystick could still be a possibility later on). Anyways, will build the circuit on 2 breadboards and proceed to code the led matrix and the game.
After building the circuit, I started coding the basic informations (void init, etc. etc.). I wrote a basic loop code in order to check if everything was alright but something seems off:
#include <avr/interrupt.h>
#include <stdio.h>
void inic(void) {
    DDRA = 0xFF;    // PORTA defined as outputs
    DDRB = 0xF7;    // PORTB defined as outputs excluding PB3
    DDRC = 0xFF;    // PORTC defined as outputs
int main(void) {
    PORTA = (1<<PA0);
    PORTC = (0<<PC0);
In my mind, what this is supposed to do is turn on the top left corner LED of the 1st matrix (I also used another matrix and connected PIN13 to the VCC and PIN9 to the Ground - this is the procedure to turn on the top left corner led - and it worked). Is something wrong with my circuit or am I coding this wrong?
I might be dumb by thinking that saying PC0 = 0 is the same as connecting it to the ground (and therefore, creating a positive voltage drop between the anode and the cathode, which would turn the led on).
EDIT1: Also, I was having issues understading what the COM pin meant on the ULN chip. I read the datasheet and understood that it the pin was supposed to be connected to the Voltage Supply and, therefore, I connected it to the VCC pin (5V). When sending the code from the AVR Studio software to the breadboard, some leds - 3rd matix only -  turn on (very softly) and then nothing happens, like explained above.
I hope you didn't connect it directly without the current limiting resistor. You risk burning the LED if you connect it directly as described.
PC0=0 is connecting PC0 to GND. However, the ULN chip is a kind of inverter, to connect the output of the ULN to GND, you need to connect the ULN input PCx to VDD, that is, PCx=1.
In fact you can see it described in the datasheet with the inverter symbol:
The COM pin is a return path for current when driving inductive loads (via internal diodes), so you only need to connect it when driving such loads, like motors. For LEDs, you can leave COM unconnected.
Quoting from the datasheet:
8.4.2 Resistive Load Drive
(...)The COM pin can be left floating for these applications.
Finally, you initialization function doesn't execute automatically. You need to call it from main():
int main(void) {
    inic();
    PORTA = (1<<PA0);
    PORTC = (0<<PC0);
No worries, I used a 2.2k resistor in order to avoid that!
 I didn't understand. I was right about coding PC0 = 0 in order to force the cathode to 0 and the anode to 1 (therefore, turning the led on). However, I didn't understand what you mean by connecting the ULN Input to VDD. Does this mean that I should code PC0 = 1 AS WELL AS PA0 = 1 in order to have a voltage drop (which only makes sense if, as you said, the value inverts itself to 0). Sorry if I'm beeing really dumb.
Alright. I read somewhere that connecting the pin was optional but I didn't know / notice that it wasn't required for these kind of applications. Thanks!
 My bad, that's a dumb mistake lol. Thanks for spotting it man!
Yes.
Alright...  So, given this, in order to have a voltage drop between the anode and the cathode, both pins should be set to 1 and to turn the respective led off, the cathode should be set to 0 right? Will try it tomorrow.
