self balancing unicycle
6 posts / 0 new
Hi Guys,
Here's some details of what I have and what I'm trying to achieve
I made a self balancing unicycle a while back, it consists of a 3-axis gyro accelerometer sensor to compute the rate and angle, kalman filter is used to compute the gyro bias and angle error
all that works fine
i compute torque as follows using PID
torque = d*rate + p*angle
and motor PWM output
PWM += torque
my question is how to limit the PWM, I want to set some threshold, ie: 50% so if commanded PWM is greater than 50% I want the motor to give boost and slow me down, basically output something larger than 50% momentarily
would this be a second PID?
or what other methods could be used?
I can just add a buzzer too.
Thanks!
This seems rather strange ...you are programming Kalman filters which can be very complex mathematical beasts to understand & implement...but want to know how to limit the PWM?   PID seems reasonable, since you can play with the parameters.  If you are doing Kalman filters, programming to limit a value should be comparative cake.
are you suggesting to do the following?
if (pwm > 50) then pwm = 50
that obviously you cannot do or you will tip over
I need to boost the output to tilt back
so my pwm = balance_pwm + tiltback_pwm
but if there is a boost from tiltback_pwm then balance_pwm will automatically drop due to balance PID calc
I hope that makes sense
Offset the command to control, as your thought, or temporarily reduce the gain.
Variable gain must be limited and analyzed (frequency response analysis to determine if there's adequate gain and phase margins)
Temporarily reduced responsiveness may be enough for the operator.
An example of audible feedback :
FlySight GPS
via https://www.avrfreaks.net/forum/advice-needed-low-power-application#comment-717353
sounds like maybe gain scheduling needed ... if you are pretty stable, use PID to control the angle or whatever; if near falling over, use time-optimal control to get back to balanced.
and the KF to provide gyro bias and angle is not hard if you are designing constant gain (or stationary process)
Thanks, I think that will work
currently target angle is zero (up), and once I'm over speeding then I can alter this target angle to make it tilt back or opposite to direction of travel
