Need help with I2C (Repeated Start)
22 posts / 0 new
I am using I2C protocol (AtMega2560) to write certain registers of the camera module OV7670. Need to implement a repeated start condition for that purpose. I have written the code for that but not sure whether it will work practically or not (i.e. there is no compilation errors).
Actually I have learned the theory of the protocol but implementing it for the first time.
Thanks.
#define F_CPU 16000000UL
#include <util/delay.h>
/*I2C Functions Start*/
void twi_init()
	TWBR = 0xC6;					/*SCL would be of 10MHz with Pre-scale of 1*/
	TWCR = (1 << TWEN);
	TWSR = 0x00;					/*Pre-scale is set to 1*/
void twiStart (void)
	TWCR = (1 << TWINT) | (1 << TWEN) | (1 << TWSTA);		/*(TWI interrupt cleared) | (TWI enabled) | (TWI start condition)*/
	while (!(TWCR & (1 << TWINT)));							/*Wait for the start condition to be transmitted*/
	TWCR |= (0 << TWSTA);									/*Clear the start bit*/
void twiStop (void)
	TWCR |= (1 << TWSTO);									/*Set the Stop bit*/
void twiWrite (uint8_t deta)
	TWDR = deta;											/*Data to be sent*/
	TWCR = (1 << TWINT) | (1 << TWEN);
/*I2C Functions End*/
/*Sart of the Main Function*/
int main()
	twi_init();
	twiStart();			/*Set the start condition*/
	twiWrite(0x42);		/*Slave address*/
	twiWrite(0x00);		/*Address of the first memory location*/
	twiWrite(0x02);		/*Gain setting*/
	_delay_us(500);
	twiStart();			/*Repeated Start*/
	twiWrite(0x84);		/*Blue setting*/
	_delay_us(500);
	twiWrite(0x84);		/*Red setting*/
	twiStop();			/*Set the Stop Condition*/
	while (1);
/*End of Main Function*/
Are you sure you need the repeated start? Usually when you write to consecutive addresses you do not need to send a restart, but this may be device dependend.
Other comments:
- You do not need to clear the start bit. This will happen on the next command.
- Also clear the interrupt and set the enable bit when you send the stop bit
- Check the status bit for errors. This may help to troubleshoot when it does not work
- Run the code to see if it works :-)
You should probably insert some delay at the start of main() to make sure that the camera is ready to receive I2C.
BTW I found this online:  https://circuitdigest.com/microcontroller-projects/how-to-use-ov7670-camera-module-with-arduino
Probably a good idea to use as a starting point for you (if that wasn't already the case?). I also like the way the code handles run-time errors (missing ACK).
/Jakob Selbing
If you use a Repeated Start you need to send the Slave Address e.g. 0x42 (W) (0x43 R)
Most I2C devices let you write data to contiguous registers i.e. the register self-increments.
Otherwise you have to ReStart address, set register, send data
You must study your datasheet.
It certainly may be - therefore, you should assume that it is, and verify in the datasheet.
That is the key!
Is also very important.
A repeated start is the same as a STOP followed by a START when there is only one Master on the I2C system.  You should do this:
twi_init();
	twiWrite(0x00);		/*Address of the I2C device's internal register for Gain setting */
	twiWrite(0x02);		/*Gain setting value? */
	twiStop();
        twiWrite(0x42)          /*  Slave address */
        twiWrite ( address of the I2C device's internal register that holds the Blue setting )
	twiWrite(0x84);		/*Blue setting value? */
	twiStop();
        twiWrite(0x42);         /* Slave address */
        twiWrite( address of the register that holds the Red setting )
	twiWrite(0x84);		/*Red setting value ? */
Total votes: 2
Where to begin, I2C void functions, no status checks or ack/nak checks, blind sending of data, use of delays rather than status checking, no reason this should not work....
Any chance there are pull up resistors on the bus?
Can I suggest you use a proven I2C lib like peter flurry’s, and drop the use of the above.
jim
I have made changes as per the suggestions, please check for the possible mistakes that remain.
Here is the improvised version of the code:
void  twiError ()
	DDRB = 0x80;
	PORTB ^= 0x80;
	_delay_ms(500);
void twi_init()
	TWCR = (1 << TWEN);
	if ((TWSR & 0xF8) != 0x08)								/*Start acknowledgment check*/
	twiError();
void twiStop (void)
void twiAddr (uint8_t addr)
	TWDR = addr;											/*Data to be sent*/
	while (!(TWCR & (1 << TWINT)));							/*Wait for the transmission*/
	if ((TWSR & 0xF8) != 0x18)								/*SLA+W acknowledgment check*/
	twiError();
void twiData (uint8_t deta)
	if ((TWSR & 0xF8) != 0x28)								/*Data acknowledgment check*/
	twiError();
int main()
	twi_init();
	twiAddr(0x42);		/*Slave address*/
	twiData(0x00);		/*Address of the first memory location*/
	twiData(0x02);		/*Gain setting*/
	twiStop();
	twiData(0x84);		/*Blue setting*/
	twiStop();
	twiData(0x84);		/*Red setting*/
	while (1);
Yes you can suggest whatever that is helpful. But I am trying to learn it all from the scratch and your help in that will be appreciated.
 I have read somewhere about it, but the reasons of doing so are vague.
Most I2C devices let you write data to contiguous registers i.e. the register self-increments. Otherwise you have to ReStart address, set register, send data You must study your datasheet.
Absolutely friend, but I couldn't find anywhere in the datasheet of the module whether the registers self-increment or not.
So, this part would go with trial and error.
Thanks for it friend. Please check the new version of the code I have uploaded. :)
I am already rusty at this, so a refresh is probably due.
https://en.wikipedia.org/wiki/I%C2%B2C
A repeated start occurs if the active master does not release the bus (e.g., stop condition). If the i2c link has one master, it does not need to worry about transaction interrupts. The repeated start is a way to hold onto the bus and make multiple transactions; thus, it blocks the other masters. Some slave devices require it for complex matters (e.g., reading more extensive memory collections).
The reference implementation I used for my AVR is
https://github.com/arduino/ArduinoCore-avr/blob/master/libraries/Wire/src/utility/twi.c
A few changes (e.g., digitalWrite can be changed to register manipulation), and it should work, at least it has for me so far (328p, 328pb, 1284p, 324pb).
I only looked at your code enough to see that you can probably understand the twi.c. I2C is not a good thing to reinvent, read the white papers (links on Wikipedia), and use a source that is known to (more or less) work.
For a few examples using twi.c, these were freshly brewed.
https://github.com/epccs/Gravimetric/blob/master/Applications/lib/rpu_mgr.c
Zarrar wrote:
I am trying to learn it all from scratch
EDIT: If your goal is really to learn I2C (aka "TWI") from scratch, then I would strongly suggest that you start with something a lot simpler than this camera!
Anyhow, to to learn I2C (aka "TWI") from scratch, you need to start here:
UM10204 I 2C-bus specification and user manualhttps://www.nxp.com/docs/en/user-guide/UM10204.pdf
This is the Official specification of the I2C protocol by NXP - who invented it, and "own" it.
It is a very well-established and widely-used standard - so there are plenty of references and tutorials available; eg,
https://i2c.info/
https://www.i2c-bus.org/
Having understood the basics of the protocol itself, you then need to study the particular implementation of it on the devices you are using
This will be described in the datasheets for the devices you are using. Usually, manufacturers will also provide Application Notes, examples, etc to illustrate & further describe what the datasheet says.
For your ATmega2560, start by going to the Product Page:
https://www.microchip.com/wwwproducts/en/ATmega2560
There you can see links for the datasheet.
The I2C is described in section 24, "2-wire Serial Interface" (note that Atmel, among others, refer to it as "2-Wire" or "Two-Wire" or "TWI").
Also, go to the 'Documents' tab. There you will find a large number of application notes - including several relating to I2C; eg,
AN_1981 - AVR155: Accessing an I2C LCD Display using the AVR 2-Wire Serial Interface
AN_2565 - AVR311: Using the TWI module as I2C slave on tinyAVR and megaAVR devices
AN2480 - AVR315: Using the TWI Module as I2C Master
What datasheet are you using? Please give a link.
I didn't find it on the OmniVision site, but there are loads of 3rd-party sites with things they call an "OV7670 datasheet"; eg,
https://www.voti.nl/docs/OV7670.pdf
In that, it says it has an "SCCB" interface - which, it says, is "compatible with" I2C.
So it's not just plain, vanilla, straightforward I2C;  it's something "compatible with" I2C - whatever that means!
So you're going to need to do some more googling to find out about this "SCCB" interface - and exactly how "compatible" it is with I2C.
I found this:
SCCB seems to be similar to I2C but you will definitely have to learn a thing or two about it before making your camera work.
https://www.robotshop.com/commun...
Again, If your goal is really to learn I2C (aka "TWI") from scratch, then I would strongly suggest that you start with something a lot simpler than this camera!
Total votes: 2
eg, Microchip have this:
https://www.microchip.com/DevelopmentTools/ProductDetails/PKSERIAL-I2C1
It is a simple demo board with a few simple, standard, common I2C devices on it all ready assembled with LEDs, etc, to demonstrate their operation.
I always think of Philips as being the inventor, since I was using their I2c books way back in the 80's...looks like they were bought out in 2006:
Aug 2006:  With a change of ownership from Royal Philips Electronics to a consortium of private equity investment companies, Philips Semiconductors will simply become NXP.
NXP stands for the consumer's "next experience," according to CEO Frans van Houten. NXP is also associated with Philips Semiconductors' Nexperia platform where audio and video processing technologies reside.
The NXP trademark will include a "Founded by Philips" tagline as part of its branding.
Yes, to learn I2C coding, work your way up from the simplest chips.  A good scope or logic analyzer is extremely useful (especially analyzers that include I2C decoders).
Yes, historically that's true.
But Philips became NXP - as you noted.
No, it's not.
A Repeated START (Sr) is where you have a START without a preceding STOP; ie, a START while the bus is still in the Busy state.
Whether a particular slave cares about this is another matter ...
Peter Fleury's library has the repeated start just being a start:
char i2c_rep_start(char address)
    return i2c_start( address );
}/* i2c_rep_start */
char i2c_start(char address)
    uint8_t   twst;
	// send START condition
	TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN);
	// wait until transmission completed
	while(!(TWCR & (1<<TWINT)));
	// check value of TWI Status Register. Mask prescaler bits.
	twst = TW_STATUS & 0xF8;
	if ( (twst != TW_START) && (twst != TW_REP_START)) return 1;
	// send device address
	TWDR = address;
	TWCR = (1<<TWINT) | (1<<TWEN);
	// wail until transmission completed and ACK/NACK has been received
	if ( (twst != TW_MT_SLA_ACK) && (twst != TW_MR_SLA_ACK) ) return 1;
	return 0;
}/* i2c_start */
The START condition itself  is identical - whether it's  "regular" or "repeated"
The difference is in what precedes it ...
From my oscilloscope observations:  A repeated START occurs when:
-the Master has sent START and SLA+w___ and the Slave has sent ACK,
-the Master has sent at least one data byte___ and the Slave has sent ACK for that byte.
   The Slave has released both SDA and SCL and the Master is asserting both SDA and SCL.  The Slave is expecting another data byte.
-the Master releases SCL, and it floats to logic high.  The Slave expects this to be the rising edge of the bit7 clock for the next data byte. The Slave expects the SDA to be unchanged in the interval that the SCL is released by the Master.  If the Master asserts SCL, then the Slave expects seven more data bits to be forthcoming, and will issue an ACK when they have finished.
-However, the Master asserts SDA.  The Slave, if properly designed, stops expecting a data byte from the Master and instead expects the Master to begin sending a new 8-bit Slave Address (7-bit shifted SLA and read/write in bit 0).
