Atmega instead PC program
23 posts / 0 new
I have a device that be controlled by a simple program on my PC via com port.
I want to omit PC and do this work by a keyboard and Atmega. Is it practical or I have to use PC and program all time?
ps: By Codevision I could read the Hex code which was sent from pc to my device so i know what I need to sent.
Welcome to AVRFreaks Majid.
I guess the answer to your question depends...
So you wish to replace the PC and its code with a microcontroller which will then "talk" with the device that needs to be controlled. Have I got it right?
Practicality can depend very much upon an individual's perception of the term. Doing it for a single site might be seen to be impractical, but for 100's of sites a great advance.
When you mention HEX code I understand this to mean the serial data strings that pass from the PC to and from the device. I would not describe this as code. And Codevision presumably has been used simply to capture and record these serial data exchanges.
Have you captured ALL the possible serial data exchanges? Including the error conditions?
Back to you.
Ross
Hi dear,
As you see in below, it is a simple program on my PC which just set the frequency of device. I type my desire frequency then select "program" button. If my device`s frequency is set correctly so I will see a message as "Done" otherwise we will see "Problem in programming" message.
The codes which have been sent by PC via TX port of RS232 and the message from device to PC via RX port of RS232 have been seen by connect this ports to another COM port and read the HEX codes by Codevision (see the below picture and red wire). Each frequency has the unique code that if I can send it by Atmega I think we can use microcontroller instead PC.
Seems straight forward.
Commands are sent to your device via an RS232 serial line.
If the inputs are just digits (0...9) and two other keys ("Program" and "Exit"), you would not need a full qwerty keyboard.
Is the manual covering the commands for the "device" available? Make model perhaps?
extra: Is the decimal "." required? And a backspace for corrections?
I would probably do it with a 4 x 4 keypad and a 16 x LCD on an arduino
Gotta love the CNC machined enclosure!
Yes you are right I can use simple keyboard but Unfortunately there isn’t manual for device, Can I trust the HEX codes which I have gained from Codevision and write it on Atmega and send them to device?
Can you trust the HEX codes? We don't know! The unit does not know if there is a PC or whatever connected to it - send the right data and it should work. Only you know the right data!
Well we don't know your skill level to be able to conclude if you are capable of doing this... do we?
To prove that your captured code is correct, could you enter it into a program like "Realterm" and then manually send it to the device and confirm, or otherwise if it works. That is how I would start if it was my project. What baud rate does it operate at?
extra: 7.95 GHz is not a trivial operating frequency. Is this a programmable oscillator? Do you have a means of confirming that the device has changed to the commanded frequency?
What baud rate does it operate at? Baud rate is 9600.
Is this a programmable oscillator? My device is a programmable synthesizer.
Do you have a means of confirming that the device has changed to the commanded frequency? Yes I can see the result by two way, first by read message which comes back from synthesizer and second by looking at a spectrum analyzer.
Excellent. So now you have a means of testing if the captured commands are sufficient. Use Realterm to send the captured command at 9600 and see that you receive the synthesizer's correct response. Easy peasy... as the saying goes.
Are you using an older PS2 keyboard  (purple connector - 6 pins), or a newer USB keyboard?   The PS2 keyboard is straightforward, but the USB is difficult.
Hi again,
 I tried to sent the codes by ' Realterm '. I had captured this codes from PC to Atmega16 via "Realterm".
Not only it didn't been programmed but also i couldn't connect to its by previous software again. sad
Do you think there is an important thing that I hadn't considered that?
Hi again,
I tried to send the codes by "Realterm". I had captured this codes from PC to Atmega16 via "Realterm" in advance.
Not only it didn't been programmed but also I couldn't connect to it by previous software again. sad
There's an echo in here!
As noted in your duplicate thread - https://www.avrfreaks.net/forum/... - you've clearly sent something "invalid" to the device, and that has "broken" it!
Clearly - YES!
I don’t think so
Because I don’t change the program of Atmega16 in synthesizer. I have just sent wrong commands to it's usart port.
majid.conf wrote:
I don’t think so
In reference to what?
Again, in reference to what?
When I changed the interface board with another one, the synthesizer worked properly. So all problem related to Atmega16 on the interface board.
Still no idea what you're referring to, or how it relates to previous posts.
I wrote a tutorial on how to reply in the forum:
https://www.avrfreaks.net/forum/man-forum-how-reply-post-forum
Thank you dear.
Well, so now you know the interface board has a protection scheme that self-destructs when hacking attempts are detected.
Personally, I'm not a fan of self-destruct protection, it reminds me of that time with FTDI: https://arstechnica.com/informat...
But, it's the manufacturer 's decision. You should use a logic analyser to capture the transaction instead of something crude like a serial terminal program. And then have a good look at it, maybe it just seems serial data but has some "anomalies" hidden.
Indeed.
A terminal may not show non-printing codes
A terminal will not show timing.
If OP used just one terminal to just monitor what the PC sends - that would not show if there are any important responses from the unit.
etc, etc, etc ...
