Watch string through char pointer?
9 posts / 0 new
I have a static struct declared in a header file, one of the members is a char array.
There's a function that returns a pointer to that array, my question is how can I watch & later use the content of the array since when passing the pointer the length information is gone.
char* get_open_file_name (void)
	return fno.fname;
and I use it inside main() as:
char* temp = get_open_file_name();
Currently when I add temp to the watch window I can see the ASCII value of the 1st letter of the file name (obviously).
I realized the question was related to debugging so my answer was irrelevant...
/Jakob Selbing
something similar to this?
So that is also not supported in Studio?!
The ,s modifier in the MSVC/AS7 debugger prints characters until 0x00 so does not need strlen as it effectively does that (handles 0x00) anyway.
Yes, however it is not terminated.
Then for the purposes of debug do so. You can only watch "strings" with ,s if they really are strings.
Or, watch it as an array of chars (even if you declare it as a pointer to chat), by adding ,n where n is the amount of chars to read...
:: Morten
:: Morten
