Comparison 16bits ASM ATmega328
24 posts / 0 new
Guys, as I'm a student of AVR ATmega328 and I'm programming in ASM.
I have the following question
I have a value of 16bits (R10: R11) (High: Low) and would like to compare with another value of 16bits (R12: R13) (High: Low).
If R10: R11 Equals R12: R13 Does Nothing
If R10: R11 is larger than R12: R13 increments R14: R15
If R10: R11 is smaller than R12: R13 decrees R14: R15
I can't handle this routine, work with 16bits, 2 registers
Can someone help me
Well normally in a little endien processor like the AVR, the low byte is in the low reg, and the high byte is in the high reg, so are you sure about your values?
Then you need to know are the values signed or unsigned values?
Its been awhile since I did any ASM so I'll let the C compiler show how it does it in asm: using unsigned values
(0022)         if( A == B)
_main:
    0006D 9020 0102 LDS	R2,_B
    0006F 9030 0103 LDS	R3,_B+1
    00071 9040 0100 LDS	R4,_A
    00073 9050 0101 LDS	R5,_A+1
    00075 1442      CP	R4,R2
    00076 0453      CPC	R5,R3
    00077 F409      BNE	0x0079
(0023)             PORTB = A;
    00078 B845      OUT	0x05,R4
So in this example B is in R2:R3, A is in R4:R5, notice the low bytes are compared then the high bytes.
"compare the two high bytes, then compare the two low bytes using the barrow flag."
Are you sure about this order/sequence :)
Total votes: 2
When I started programming AMTmega8 in assembly, I made a list of the basic instructions and another for the I/O registers on excel.
I usually have a look at these two lists while writing a code, just to be sure since my memory is rather short lately (I am 70).
I attached the worksheet as it is. I hope you will like it even a little smiley
I will follow the AVR standard
If R10: R11 (L: H) is equal to R12: R13 (L: H) do nothing
If R10: R11 (L: H) is greater than R12: R13 (L: H) increments R14: R15 (low: High)
If R10: R11 (L: H) is less than R12: R13 (L: H) decrees R14: R15 (L: H)
Unsigned values
I usually wrote your lines as:
If R11:R10 (H:L) is equal to R13:R12 (H:L) do nothing
If R11:R10 (H:L) is greater than R13:R12 (H:L) increment R15:R14 (high:low)
If R11:R10 (H:L) is less than R13:R12 (H:L) decrease R15: R14 (H:L)
There are 2 compare instructions, CP and CPC (as on #2).
Also there are conditional instructions; as BREQ (branch if equal), BRSH (branch if same or higher) and BRLO (branch if lower). You will need to use them all (well just 2 conditional instructions... don't forget RJMP).
Any kind of compare is really just a subtraction. If Z is set at the end the two were equal if C is set the one being subtracted is larger than the one it us subtracted from. If neither us set it is larger.
Thing is that apart from SBIW (which doe not help here) the AVR doesn't do 16 but subtracts so you need to double up with a SUB then an SBC.
Exactly, CP and CPC are just like SUB and SBC, except that the result is discarded, and only the flags are changed.
So, comparing multibyte values is just like adding or subtracting, first you perform the regular operation (ADD/SUB/CP) on the lowest order byte, then the operation with carry (ADC/SBC/CPC) on the successive higher order bytes.
;Compare immediate a register pair with a value. registers r16-r30
.MACRO CPIW 		;Arguments: Register pair,  Data, scratch register (ie zl,zh,1234,temp),
		ldi	@3,high (@2)
		cpi	@0,low (@2)
		cpc	@1,@3
.ENDMACRO
;Compare 2 register pairs. any registers
.MACRO CPRW 		;Arguments: Register pairs (ie zl,zh,xl,xh), any register pair
		cp	@0,@2
		cpc	@1,@3
.ENDMACRO
To OP,
Please note (for the next time perhaps) that there are 2 main reasons for which you didn't get the full answer/code you are looking for:
[1] You didn't present here any code with which you started to solve your exercise.
[2] There are many ways to implement it.
aless2056 wrote:
compare
Is that just to see if they are equal or not, or also to determine which is largest/smallest ... ?
And I already said:
There is an AVR app note on 16-Bit Arithmetics.
https://www.microchip.com/wwwApp...
you can prob make  it better with bacon
	ldi ZL, low(1)
	ldi ZH, high(0)
	cp r11, r13
	cpc r10, r12
	breq be_done
	brsh do_sum
	ldi ZL, low(-1)
	ldi ZH, high(-1)
do_sum: add r15, ZL    ;does the add (or subtract) right here
        adc r16, ZH
be_done: blah blah blah
Nothing like having the latest version either.....cheeky
;* Title:        16-bit Arithmetics
;* Version:        1.1
;* Last updated:    97.07.04
;* Target:        AT90Sxxxx (All AVR Devices)
Now let's say that I have register R20 and I want to set bit 0 and bit 2 and after a while I want to set bit 4 as well and reset bit 2.
Don't have a command like SBI or CBI for registers R0 ~ R31?
I saw that you have SBR and CBR, but you don't have a specific command to set a bit in a general purpose register.
The I stands for I/O bits.
The R stands for register bits. However they only work with registers 16-31, see the  AVR Instruction Set Manual.
You can use  SBR/CBR in r16-r31... you can use and & or in registers r00-r15 (with an extra command to load the needed mask)
what do you consider general purpose:
Advanced RISC Architecture
– 131 Powerful Instructions – Most Single Clock Cycle Execution
– 32 x 8 General Purpose Working Registers
Specific? [where is that devil emoticon]
lol -- aren't there really about 78 instructions, and a bunch of pseudonyms?
[edit] 75 according to Cliff, but ralphd may not agree https://www.avrfreaks.net/commen... ]
SBR and CBR are aliases for ORI and ANDI, right?  Yes, the lower registers have some limitations, but conceptually isn't ORI and [~]ANDI to carry out
With regard to the instructionbs in question, has the AVR instruction set changed since the first databook?
That comment doesn't make sense.
Point is, SBR & CBR are the specific commands for at least half of the general purpose registers, the others require and & or.
The point is that there a  NO SBR & CBR instructions , SBR is just a ORI with the bit(s) you want to set and  CBR do a ANDI with the complement of the mask given !
Depending of what you want to do sometimes BST will do what you want if you preload T with 1 if you want to set and 0 for clr, and that is on all 256 (8*32) bits.
Yes none of the chips in the first databook 1996 was made, and some instructions (4 I think) was added.(I remember it had a AVR1300 a avr 1200 with 128 byte eeprom (and no avr1200))
I'm not sure if the MUL instructions was in the 1997 databook.
For instance, I usually use a lot of flags in my assembly codes.
I start with the bits of r25 then r24, r23... (sometimes, I use the bits of I/O registers if not needed)
; Bxxxxxxx for SBRC, SBRS
; Fxxxxxxx for SBR , CBR
;.def R1flags  = r25            ; general flags 1
#define B1doJob7 r25,7          ; 1 = do job 7
#define F1doJob7 r25,0x80       ;
#define B1doJob6 r25,6          ; 1 = do job 6
#define F1doJob6 r25,0x40       ;
#define B1doJob5 r25,5          ; 1 = do job 5
#define F1doJob5 r25,0x20       ;
#define B1doJob4 r25,4          ; 1 = do job 4
#define F1doJob4 r25,0x10       ;
#define B1doJob3 r25,3          ; 1 = do job 3
#define F1doJob3 r25,0x08       ;
#define B1doJob2 r25,2          ; 1 = do job 2
#define F1doJob2 r25,0x04       ;
#define B1doJob1 r25,1          ; 1 = do job 2
#define F1doJob1 r25,0x02       ;
#define B1doJob0 r25,0          ; 1 = do job 1
#define F1doJob0 r25,0x01       ;
; example
    SBRS  B1doJob2
    RJMP  Skip
Job2:
    CBR   B1doJob2
Skip:
That's worth mentioning...in either case those are specific commands to set general purpose register bits (and they all work ONLY on the 32 general purpose registers), so for OP to say there are no such commands is baloney
Maybe the real question is what does op mean by  "specific command" ..maybe he mean meant command controlling a single specific bit
The problem with AVR bit commands is that the specific bit has to be known at compile time, (no instruction that do something like set the bit r16 point at)
In the past I have used this type of code where 3 bits make this bit mask. (input r16 output r17)
0    00000001
1    00000010
2    00000100
3    00001000
4    00010000
5    00100000
6    01000000
7    10000000
    ldi r17,1
    sbrc r16,1
    ldi r17,4
    sbrc r16,0
    add r17,r17
    sbrc r16,2
    swap r17
For a bit lib I have used the top 3 bits of r30(ZL) as the bit number, and AND those 3 bit's off and you have the address.
