SPIC and SPID not works!
8 posts / 0 new
Hey there,
I have been enable and set SPI registers by codewizaed codevision
But SPIC works fine but SPID not works
It means the pin state doesn't change .
I check with digital analyser.
What is the problem??
For now, the biggest problem is not knowing what chip it is talking about.
Thank you kabasan
It is atxmega32a4u
Do you need to set the port pin direction (in/out) or does enabling the spi do that for you?
Yes the mosi and clk are output and miso is input ,
In normally the output pins work well
But the can not show SPI on them
Only registers is need?
I have been set them too.
The standard reply here is to write a small complete program that demos the problem and post it here using the code editor "<>" in the menu above, so others can see what your doing and make corrections, in most cases doing this exercise, you will discover your problem.
Also Codevision have their own excellent support group, just in case you may have somr older and buggy version.
You might want to post the code that CV generated too.
