renaming functions causes system not to function correctly
7 posts / 0 new
he guys, I'm trying to tidy up my function naming for a FAT32 (long file name and legacy) and exFAT.  However the system does not function correctly when I do so.
Just to clarify, when I say it does not function correctly I'm running a system test to create folders and files and opens folders and files and write data to the files performing wildcard operations on folder....
HELP!!!   Any sugestions welcome.
Is this just the same as your previous thread: https://www.avrfreaks.net/forum/... ?
As noted there, you never did establish the problem - so, as explained there, you probably didn't fix it!
Fianawarrior wrote:
Any suggestions welcome
See the other thread!
You haven't given any new information to go on, so you might as well continues in that other "weird behaviour" thread.
Again, as we write over and over, what do you mean by "not to function correctly"?
Are you using an IDE that can do proper refactoring?
I'm using DS-5 community edition clawson
I have a backup folder that appears to accept editing...  I do understand what you mean about bugs and not looking for them but to trying instead to work around them.  Well...  I'm around the fire tonight!!!
Topic locked
