atmel ice programming
26 posts / 0 new
Hi guys,
I use atmel ice programmer and Atmel Studio.
I designed a new board which use Atmega2560.Everything was ok.I compile program with arduino IDE and copy hex file and paste it memories tab that located in atmel studio.
Finally i load the program to the my circuit.The circuit is working but it works very slowly.For example the buzzer would be high for 1 second but it loud for 8-10 seconds.
my fuses and lock bits;
extended 0xFD
high 0xD9
low 0xFF
Lock bit 0xFC
CKSEL 8.0mhz 16k+65ms
First programming everything is ok(but slow).But when i try it second time it gives a fault(Failed to enter programming mode. ispEnterProgMode: Error status received: Got 0xc0, expected 0x00 (Command has failed to execute on the tool))
I choose in device programming )atmel-ice,Atmega2560,ISP and apply it.It seems ISP clock 125khz.
And i press read button and it gives same error.It doesnt recognize my microprocessor.
I remove my chip and put new one.When i program it first time everything is ok(but still slow working).Then i try second time it gives same error like disposable chip:))Just one programming.
What is the problem?
P.s: my crystal is 16 mhz and ground capacitors are 18 pf.And everything is correctly connection.Anyway i can program it for 1 time otherwise i think i would never programm it if i have a connection fail.
Make sure that the CVDIV8 fuse is unchecked.
Yes it is uncheck.Anyway when i choose this fuse setting it has already uncheck
Your fuses enable the BOD, is your VCC level above 4.5v?
yes my VCC is 5.0 or 5.1V.
What means BOD?
BOD= Brown Out Detector, I think yours was set for 2.7V anyway.
Maybe you should show us now how you have programmed your delay. Is it just a simple _delay_ms() or a timer delay?
It is just a simple delay command.
But now my problem is different.I can programm my chip just one time.Second time it gives error and not recognize my chip.First of all i would be solve this problem.
Please do not double-post! You probably programmed fuses for "External Oscillator" rather than for a crystal or ceramic resonator.
Your problem is with setting the lock bits. You're selecting LB Mode 3 which prevents further programming.
Show us what you have actually got.  e.g. photo
I am brave enough to solder an SMD once (with a soldering iron).   There is no way that I could replace it without destroying the pcb traces.
Even if you have SMD equipment,  pcbs don't like being reworked too many times.
If you have a permanent Serial link on your pcb,  it is worth installing a bootloader.   Then you can bury the external programmer.
If you want to use an external programmer-debugger e.g. ATMEL-ICE,  it is wise to use JTAG header.   And be very careful not to disable JTAGEN fuse.
Regarding your Lock Bits.
In AS7.0 Device Programming->Memories tab tick the [Erase device before programming]
This ensures that the Lock Bits are cleared.   Or select the [Erase Now] button.
If your chip has debug capability, it is folly not to give access to it!
Why tie your hands behind your back?!
The Arduino MEGA2560 uses the JTAG pins as Analog A4-A7 and so it disables JTAGEN fuse.
It depends very much on what the OP wants to do.   If it is running Arduino sketches,  it seems wise to buy a MEGA2560 clone board.   Cheaper than making your own board.
Dear guys,
I am programming another my board for 2 years like same fuse settings and i have no problem with atmel ice ISP.But now i try 3 board and 3 atmega2560 chip all of them are working first programming no problem.But when i try second programming it does not recognize my chip.It reads target voltage 5 volts but when i press read button of device signature it gives fault.
I try that without external 16mhz crystal.
I try R8 0 ohm instead of 22 ohm.
The other big board has got same schematic.It is working.
Now last time i try that just place atmega,crystal,c4,c5,c7,c8,c9,c10,r3,c3 and 5 volt power supply.I dont use the other compnents of the board everything is empty.I want to localized problem that hardware or software.But same thing occurs first programming everything is ok second one it is broken i think.When i place new chip  its working just one time.I dont understand.Please help me. it is working like disposable chip :)
R11 decreases the crystal oscillator's safety factor.
edit :
AVR042: AVR Hardware Design Considerations
But i use R11 for 2 years my the other board same system.It is working.
edit :
Now i place 0 ohm instead of 27r .Still it does not recognize my chip
Have you used [Erase] ?
Your schematic looks fine to me.  I doubt if R11 = 22R would make any difference.
However some crystals may be less active than others.   Older AVRs are generally pretty good to oscillate.
I would try with 8MHz RC or with a real 16MHz External Clock Signal.
Programming once, with fuses set to external xtal, and then not able to program, or read sig, means your xtal is not oscillating!  Why, there are many reasons, poor soldering, bad xtal, wrong caps(mfd,nfd,instead of pfd).
you can recover by injecting an external clock into xtal1 pin, and resetting fuses back to default values.
this also proves no clock above.  Check your soldering, if using water soluable flux, wash the board, the flux is conducive and must be removed by washing and drying the board.
hope this helps.
jim
i cant use ERASE it also gives fault because it is not recognized my chip.just  read a target voltage. I try 2 different xtal one of them RALTRON 16mhz the other one is WÜRTH 16 mhz.Same result :(
Search in tutorals forum here for how to unbrick your AVR, for how to recover, but it's the same advise as #20 above!
It is not a problem unbrick my chip.I can replace it easily.But i have to find real problem.Why  can i  program the chip just one time? why second time it gives a fault?
it quite simple, you changed the chips clock source, but the new source is not working!
Why, see reasons above, but common reasons have already been discussed.
we can not see your set up, at least you have not provided a clear picture, so you will need to research each possible cause and eliminate each one.  Most likely a soldering error or bad component.
jim
According to your schematics, the Reset capacitor is 18 pF (same as the crystal caps), which might not be sufficient for reliable ISP.
Normally 100 nF are recommended.
Or the given 18 pF are simply a copy&paste mistake in your schematics ...
That would be:
If you follow my advice there then if you supply a clock and can do ISP again then before you reset fuses, read the current setting back which might explain why the chip had become un-contactable.
